Webcast-Catalyst9k
is it possible? channel-bundle between switch and router
Hi mates :)
I'll appreciate your help on below configuration:
I got a multilayerswitch (3750) and a router (2800series).
PCs--------------> 3750 switch ===========> 2800 Router ------------------>WAN
one cable two cables
EIGRP is running on both devices (multilayer switch and router). I want a redundant link between the switch and the router.
Question:
Can I bundle two cables in anyway (for example performing ether-channel PAGP between the router and the switch? (switch's ports to the router will be L3 ports with different IPs?)
I know I can do it with layer 2 ports on two switches but can I bundle cables between router and switch?
thanks in for helping :)
Re: is it possible? channel-bundle between switch and router
yes you can create the the ether-channel between your switch and router but you have to checkit out your router will have the facility or not...
and your router is i think support the modular for that even though you can check it out on the following link...
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8028d15f.html
reate this post if it helps
regards
Devang
hello,
I think you are looking for something like:
Configuring EtherChannel and 802.1Q Trunking Between Catalyst L2 Fixed Configuration Switches and a Router (InterVLAN Routing)
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml
Hope this help,
if it does please rate this post.
if not let me know,
Vlad
Hi Friend,
If you want to configure the router ports as layer 2 ports and want to create an ether-channel, It will work for you. But when you are creating the switch ports are L3 switch ports, you have to create a L3 port channel between the switch and the router.
HTH, please rate if it does.
-amit singh
597
