Is it possible to aggregate Gigabit Ethernet links at different
switches (Cat2950G) in stack into GigaEtherChanel for uplink to a core switch?
Re: Is it possible to aggregate Gigabit Ethernet links at differ
if you are asking "can you run Gigabit Etherchannel between a core switch, and then to two different dist switches then the answer is no. This would create a loop. As far as I am aware, you must run Etherchannel between two switches as the switch at each end treats the links as one physical link, two switches would not be able to do this
Daniel,
Yes, I hoped then ther was a way to distribute trank allot dist switches in order to increase reliability.
Thank you very much.
124
