Is it possible to connect a remote PC (Windows) to a LAN using router's AUX port with an analog modem? We want access to LAN, not telnet to router.
We are testing a remote access connection with a USR modem connected to AUX port of a 7206 router.
We try to connect from a PC (Windows dial-up) with a modem. Connection is established, and we can even gain access to router management (using hyperterminal), but we cannot enter the remote LAN. It seems that ppp negotiation is not started.
  • Other Network Infrastructure Subjects
1 REPLY
Anonymous
N/A
Re: Is it possible to connect a remote PC (Windows) to a LAN usi
You can use the AUX port as a statndard async
port which supports dial-in services and
ppp encapsulation.
Use standard sample configs for dial-in support
and apply them to async interface associated to the
AUX port.
98
