Is it possible to LACP between Cisco 7513Router & Riverstone RS3000
7513=== riverstone switch
dual fast ethernet line connecting....
7513 router support LACP?
if 7513 router support LACP, Please speak sample-config url to me..
7513-Router#sh ver
IOS (tm) RSP Software (RSP-PV-M), Version 12.1(11b)E1, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 21-Mar-02 15:51 by eaarmas
Image text-base: 0x60010958, data-base: 0x6116E000
ROM: System Bootstrap, Version 11.1(2) [nitin 2], RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.1(11b)E1, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
icu-router uptime is 4 weeks, 4 days, 10 hours, 14 minutes
System returned to ROM by reload at 05:20:04 UTC Fri Apr 26 2002
System image file is "slot0:rsp-pv-mz.121-11b.E1.bin"
cisco RSP2 (R4700) processor with 131072K/2072K bytes of memory.
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
Chassis Interface.
1 FSIP controller (4 Serial).
1 GEIP controller (1 GigabitEthernet).
1 FEIP2 controller (2 FastEthernet).
1 VIP4-80 RM7000 controller (2 Serial).
2 FastEthernet/IEEE 802.3 interface(s)
1 Gigabit Ethernet/IEEE 802.3 interface(s)
6 Serial network interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
20480K bytes of Flash PCMCIA card at slot 1 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 7.
7513-Router#
thank you
1 REPLY
Re: Is it possible to LACP between Cisco 7513Router & Riverstone
You should be able to configure etherchannel on your 7513 router. Try this and let me know
http://www.cisco.com/warp/public/473/158.html#config2
LACP and PAGP are done at layer 2 and the router should not differenciate these protocols
150
