Webcast-Catalyst9k
Is it possible to make a trunk between two switches over a remote bridge and media converter (100 baseTx <->100 Base Fx)?
I have two switches in different buildings 20 Km distant and with a FO pair between them. I need to share the vlans and I'm going to use a media converter from UTP do FO. Both switches supports TRUNK in their 100 baseTx ports. Does the media converter needs to be transparent or is it possible to use a bridge to stablish a TRUNK between them?
1 REPLY
Anonymous
N/A
Re: Is it possible to make a trunk between two switches over a r
Yes. It should work.
As long as you use only media converters which
are not interpreting the Ethernet frames
the switches must "see" each other as connected
back to back.
129
