Webcast-Catalyst9k
Is it possible to use multilink on a Cisco 803 and dial to two locations.
Is it possible to use multilink on a Cisco 803 and at the same time dial to a other location so that one multilink channel is disabled and is used for a connection to the other location.
1 REPLY
Anonymous
N/A
Re: Is it possible to use multilink on a Cisco 803 and dial to t
Yes. Configure 2 dialer maps (or
two dialer profiles), and then use the
"dialer fast-idle" command to control
when the second channel in the MPPP
bundle will be torn down so that a
call to the second location can be made.
This command controls the timing when
there is dialing contention like this.
90
