Is MLS enabled by default on 6509 with sup1a+msfc?
Is MLS enabled by default on a 6509 Sup1a with MSFC, or does it need to be enabled in switch configuration?
Thanks..
1 ACCEPTED SOLUTION
Silver
Re: Is MLS enabled by default on 6509 with sup1a+msfc?
Its enabled by default for IP and IPX. "sho mls" will show you the information for your cat, assuming you're running CatOS.
Hope this helps,
Don
Silver
Hope this helps,
Don
Thanks, yes wer're running CatOS.
104
