Is PXE/Wake on LAN routable????
I'm trying to find out if wake on LAN / PXE packets are routable. I have not been able to locate the RFC that covers this subject. If any one could point me in the right direction I'd appreciate it
1 REPLY
Re: Is PXE/Wake on LAN routable????
PXE is still a draft.
http://www.ietf.org/internet-drafts/draft-ietf-dhc-pxe-options-00.txt
You should be able to route the BOOTP packets using ip-helper addresses (ie, helper to the PXE server) on the router interfaces that are not on the PXE server vlan.
640
