Is "dialer pool" only for point to point?
I have the followiong configuration on a test plan:
interface serial 1/0:15
dialer pool-member 1
interface serial 1/1:15
interface dialer 1
dialer pool 1
interface dialer 2
dialer pool 2
with this configuration, when more remote routers try to access one dialer interface, the first router gets connected and all the other routers fail to connect.
So my question is: if I configure dialer pool-member do I have to configure one dialer interface for each remote site or can I use single dialer interface as a multipoint access?
Many thanks
Silver
Re: Is "dialer pool" only for point to point?
The dialer profile is a point-to-point interface, this requires a Layer 3 to Layer 2 map & so will need a seperate dialer interface to bind to each remote site.
The concept of dialer remote-name / dialer caller is used.
Each dialer interface is a member of a single dialer pool; the pool is a group of one or more physical interfaces.
Please refer to the below link for concepts on dialer profiles:
http://www.cisco.com/warp/public/129/23.html
Thanks, Mak.
Bronze
For your application, where its all inbound dialing on this test plan , yes you do need one dialer interface per remote site.
~Zulfi
91
