Is there a debug or show option that will display ipx frame types being received at the router ?
The show IPX traffic command displays a large amount of "format errors".
I suspect there are a number of devices on the network that are set to "auto-negotiate" the frame type.
Is there a debug or show command that would display ipx frame received that are not 802.3 ?
1 REPLY
Anonymous
N/A
Re: Is there a debug or show option that will display ipx frame
There is indeed a way to do that.
You have to first configure on your ethernet interface,
4 sub-interfaces. Each of them with a different IPX encap and a different network number:
int et 0.1
ipx network 1 encap snap
int ethe 0.2
ipx netw 2 encap ...
Then you enbable "debug ipx packet" and you will see
all the IPX packets whatever the encapsulation is.
83
