12-19-2002 03:05 AM - edited 03-02-2019 03:42 AM
Is there a way to configure a 1-Port 4-wire 56/64 -kbps DSU/CSU to run on a 64k frame relay circuit ?
12-19-2002 07:12 AM
You'll need to check with the Telco to see how it was built. If we are talking about a 64k Clear channel then yes.
If we are talking a T1 access using a single DS0 as the port speed (64k) then no, you will need to upgrade to the T1 DSU.
Happy Routing & Merry Christmas,
~rlc
CCNP, CCDA, CNE
12-19-2002 09:54 PM
Thanks for the suggestions.
I will let you know how I make out.
Happy returns to you.
12-19-2002 09:46 AM
Definitely u can run,I have tried back to back on 64 k frame-relay link.clear channel u can configure.
Munit
12-19-2002 09:58 PM
Good to know you had success. Can you share the config statements?
Thanks.
