Webcast-Catalyst9k
Is there an advantage to hard code fast ethernet to 100 full as opposed to auto half?
I have a 2620 fast ethernet dirrectly connected to 2912xl fast ethernet switch and right now it is set for :
interface FastEthernet0/0
ip address 10.10.x.x 255.255.255.128
no ip directed-broadcast
speed auto
half-duplex
Is there any reason why I could not or should not hard code the router's fast ethernet interface to
speed 100
and
duplex full
Anonymous
N/A
Re: Is there an advantage to hard code fast ethernet to 100 full
No, no reason at all. If your switch
is 100M, then you should go ahead and
configure it.
2600 and 2924XL should be able to auto-negotiate speed/duplex. So I suggest let it auto-negotiate to 100-full. IF the 260 is a router on a stick and all inter-vlan traffic has to go through this link, half-duplex would result in excessive collision which would slow down the traffic. So always use full duplex setting regardless what the speed is.
Green
Auto-negotiate is not always reliable. For ANY critical link (or IMHO, EVERY link), you should hard code the parameters. If it's a 100 meg link, unless you have a specific reason not to, you should be at full duplex.
Do you really want to leave the operation of your network in the hands of a PROGRAMMER (the guy that wrote the op code for your equipment)?
Auto is for people to lazy or stupid to know what is plugging into their network (IMHO).
FWIW
Scott
between cisco devices auto-negotiating should work unless you are hitting into a bug !! I agree you can't beat the hard-coding part unless ofcource the admin makes a mistake. I think the probabilty of you hitting into auto-neg bug between two cisoc devices in this case is far far less then an accidental mistake.
I typically leave cisco to cisco to auto. :)
Green
Auto is for people too lazy or stupid to know what is plugging into their network (IMHO).
FWIW
Scott
765
