Is there an easy way of creating an ACL for denying users?
Hi All,
I like to create an ACL that would prevent about 50 users from accessing a particular network in our MPLS network.  I do not want to create another vlan for this.
Let's say I want to deny this range 10.12.16.20 - 50   from accessing 10.3.0.0 network but allow then access to everthing else.  Is this how to do it?
Access-list 101 deny 10.12.16.20  0.0.0.0  10.3.0.0  0.0.255.255
Access-list 101 deny 10.12.16.21  0.0.0.0  10.3.0.0  0.0.255.255
Access-list 101 deny 10.12.16.22  0.0.0.0  10.3.0.0  0.0.255.255
-- this will go continue down to .50
Access-list 101 permit ip any any
Can I do something like this?
Access-list 101 deny 10.12.16.20 - 50  0.0.0.0 10.3.0.0  0.0.255.255
Access-list 101 permit any any
1 ACCEPTED SOLUTION
VIP Purple
Re: Is there an easy way of creating an ACL for denying users?
with traditional ACLs it can't be done, but it will work with the help of objects-groups:
object-group network CLIENTS
  range 10.12.16.20 10.12.16.50
ip access-list extended TEST
  deny   ip object-group CLIENTS 10.3.0.0 0.0.255.255
  permit ip any any
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Hall of Fame Super Silver
While it would be very convenient to be able to specify a range as the original poster suggests, Paulo is correct that this does not work. But it is not necessary to have individual lines to deny each specific host. It is possible to use ranges if they are set up on binary bit boundaries. So something like this should work and be a bit less tedious
!  deny 20 through 23
Access-list 101 deny 10.12.16.20  0.0.0.3  10.3.0.0  0.0.255.255
!  deny 24 through 31
Access-list 101 deny 10.12.16.24  0.0.0.7  10.3.0.0  0.0.255.255
!  deny 32 through 47
Access-list 101 deny 10.12.16.32  0.0.0.15  10.3.0.0  0.0.255.255
!  deny 48 and 49
Access-list 101 deny 10.12.16.48  0.0.0.1  10.3.0.0  0.0.255.255
!  deny 50
Access-list 101 deny 10.12.16.50  0.0.0.0  10.3.0.0  0.0.255.255
! now permit all other traffic
Rick
VIP Purple
  permit ip any any
The response from Karsten is excellent. Object groups are a relatively recent addition to IOS and I had not remembered that they do give the ability to specify an arbitrary range of addresses and are not restricted to bit boundaries as access lists are as mentioned in my response.
Rick
Thanks to all.  I will give this a try when time permits.
Super Bronze
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What Karsten has suggested, would be the "cleanest" approach, but if the IOS doesn't support it, what Rick suggested would be the way to do it using the fewest ACEs.
If using Rick's approach, as he mentioned you can set ACEs on binary boundaries, variations on the "theme" might be to include a bigger block than needed, if the overage isn't harmful.  For example, when trying to exclude hosts 20 .. 50 one ACE could block 0 .. 63.
Also remember you can mix permits and denies.  So say you wanted to block just 8 .. 63, you could permit 0..7, block 0..63 and then permit any.  Depending on your requirement, mixing permits and denies might require the fewest ACEs in your ACL.
Of course the disadvange of a complicated ACL, it's harder to understand.  However, on a sofware based router, the shorter ACL might perform better.
343
