Community Member
Is there any way to replace a cisco Line card with another Model?
We bought a Cisco line card WS-X4648-RJ45-E for Cisco 4507 R-E. Later on I found that this module is not working with the chassis becuase supervisor engine 4 we are using. Supervisor Engine 6 is required for WS-X4648-RJ45-E. Now I want to go for WS-X4548-RJ45. Is it possible to return the line card? Is there any possible way to exchange? I am responsible for the mistake. I dont know what to do.
Posted Image
By the way, I am from Saudi Arabia
Hall of Fame Super Blue
You'll need to contact your authorized Cisco Reseller.
Community Member
Thanks for advise. I contacted the reseller. they said it is considered as spare parts so not possible to exchange or replace with another model. Is it true?
Unfortunately, yes.  That is true.
However, did YOU specify the part number or did the reseller did?  Did they ask relevant questions as to the specific model of your chassis and/or your supervisor card or not?
Community Member
I did chooe the part number not the reseller
I don't know what else to say.  I think you know what my answer is and there's nothing else you can do about it.
Silver
Put it on eBay and make at least some of your money back before buying your replacement card.
425
