Is there such thing as 'enabling' an IPX SAP that is not filtered?
Svr1??--- RtrA ----z-------RtrB--Svr2
|-----z-------RtrC--Svr3
I'm a reseller. I have a customer with the following issue: they have implemented a new backup service. The service/software is TapeWare. TapeWare service works between Svr1 and other servers on that side of RtrA. Svr2 and Svr3 will talk to each other (through RtrA). Svr1 will not talk to either Svr2 or Svr3. All three routers see all three servers (sho ipx servers) and networks (sho ipx route). My customer insists I need to 'enable' the SAP type that TapeWare utilizes - 0x7589. There is a SAP filter on the Fa interface of RtrA. It is allowing the proper network. I removed the filter, the customer tested and it still didn't work. I don't believe this is a routing/network issue. I need either a fix for them or proof that this is not a router issue. The WAN is ATM (RtrA) to Frame (RtrB&C) and we are using EIGRP to route IPX. There are things (routers/switches) between Svr1 and RtrA that are not under my control and that I do not have access to. Help!
Re: Is there such thing as 'enabling' an IPX SAP that is not fil
Can you provide a config for RTR A & B please ?
Here are partial configs for both. The main backup server is on network A3D2, residing somewhere out the Fa interface of RTRA.
RTR_A#sho run
Building configuration...
Current configuration:
! Last configuration change at 14:06:35 pdt Thu Aug 15 2002
! NVRAM config last updated at 16:41:48 pdt Tue Aug 13 2002
hostname RTR_A
enable secret XXXXXXX/
username XXX password XXXXXXXX
clock timezone pst -8
clock summer-time pdt recurring
clock calendar-valid
ip subnet-zero
ip tcp synwait-time 5
no ip domain-lookup
ip host netop X.X.X.X
ip name-server X.X.X.X
ip cef
lane client flush
ipx routing X.X.X
isdn switch-type primary-dms100
cns event-service server
interface ATM0/0/0
no ip address
no ip route-cache distributed
atm clock INTERNAL
atm ilmi-keepalive
interface ATM0/0/0.13 point-to-point
description ATM PVC to RTR_B FL1 DS1#1
bandwidth 1544
ip address 10.249.1.13 255.255.255.252
ip ospf network broadcast
pvc RTR_B 5/35
protocol ipx 3D13.0050.549c.14a0
protocol ip 10.249.1.14 broadcast
vbr-nrt 1544 1152 32
ipx network 3D13
ipx output-gns-filter 1006
interface ATM0/0/0.17 point-to-point
description ATM PVC to RTR_B FL2 DS1#2
bandwidth 1544
ip address 10.249.1.17 255.255.255.252
pvc RTR_B 5/36
protocol ipx 3D17.0050.549c.14a0
protocol ip 10.249.1.18 broadcast
ipx network 3D17
interface FastEthernet1/0
ip address X.X.X.X 255.255.255.0
full-duplex
ipx input-sap-filter 1004
ipx network 2D8
ipx type-20-propagation
no mop enabled
router eigrp 302
network 10.0.0.0
network X.X.X.X
no auto-summary
router ospf 69
router-id 149.142.169.1
redistribute connected subnets
redistribute ospf 65223 subnets
network 10.249.1.0 0.0.0.255 area 0
network X.X.X.X 0.0.0.0 area 0
default-information originate always
router ospf 65223
summary-address X.X.X.X 255.255.255.0
redistribute static subnets
redistribute eigrp 302 subnets
redistribute ospf 69 subnets
network X.X.X.X 0.0.0.0 area 1
ip default-gateway X.X.X.X
ip classless
ip route XXXXXXXXX
ip route XXXXXXXXX
logging X.X.X.X
logging X.X.X.X
access-list 1004 permit 22895.0000.0000.0001
access-list 1004 permit 3140510E.0000.0000.0001
access-list 1004 permit A2501.0000.0000.0001
access-list 1004 permit A2502.0000.0000.0001
access-list 1004 permit A2504.0000.0000.0001
access-list 1004 permit A2505.0000.0000.0001
access-list 1004 permit A261.0000.0000.0001
access-list 1004 permit A2602.0000.0000.0001
access-list 1004 permit A262.0000.0000.0001
access-list 1004 permit A263.0000.0000.0001
access-list 1004 permit A3D1.0000.0000.0001
access-list 1004 permit A3D2.0000.0000.0001
access-list 1004 permit A3D3.0000.0000.0001
access-list 1004 permit A3F00060.0000.0000.0001
access-list 1004 permit A3F0015.0000.0000.0001
access-list 1004 permit A3F008.0000.0000.0001
access-list 1004 permit A3F040.0000.0000.0001
access-list 1004 permit A4F009.0000.0000.0001
access-list 1004 permit A3D9.0000.0000.0001
access-list 1004 permit A3D5.0000.0000.0001
access-list 1004 deny FFFFFFFF
access-list 1006 permit A3D2.0000.0000.0001
access-list 1006 permit A3D9.0000.0000.0001
access-list 1006 permit A3D5.0000.0000.0001
access-list 1006 permit A3D1.0000.0000.0001
access-list 1006 permit A3D3.0000.0000.0001
access-list 1006 permit 22895.0000.0000.0001
access-list 1006 permit 33FDEA4B.0000.0000.0001 130
access-list 1006 permit A261.0000.0000.0001
access-list 1006 deny FFFFFFFF
ipx router eigrp 100
network 2D8
ipx router eigrp 301
network 2D9
network 2D8
network 3D13
network 3D17
end
RTR_B#sho run
! Last configuration change at 15:41:02 pdt Tue Jul 9 2002
! NVRAM config last updated at 15:41:41 pdt Tue Jul 9 2002
hostname RTR_B
logging buffered 4096 debugging
no ip subnet-zero
ip domain-name XXX
ip dhcp-server X.X.X.X
ipx routing XXX
ipx gns-response-delay 20
ipx gns-round-robin
interface Ethernet0/0
ip address X.X.X.X 255.255.255.224 secondary
ip address X.X.X.X 255.255.255.192 secondary
ip address 10.249.202.1 255.255.255.0
ip helper-address X.X.X.X
no ip directed-broadcast
ipx network 2D39
interface Serial0/0
mtu 4470
bandwidth 1544
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
description Verizon Ckt ID: XXX
bandwidth 1544
ip address 10.249.1.14 255.255.255.252
ip broadcast-address 10.249.1.15
ip ospf priority 0
ipx network 3D13
frame-relay interface-dlci 535
interface Serial0/1
mtu 4470
no ip address
interface Serial0/1.1 point-to-point
description Verizon Ckt XX
bandwidth 1544
ip address 10.249.1.18 255.255.255.252
ip broadcast-address 10.249.1.19
ip ospf priority 0
frame-relay interface-dlci 536
router eigrp 302
network 10.0.0.0
network X.X.X.X no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.249.1.13
logging X.X.X.X
network 2D39
network 3D13
end
!!! I finally talked to a rep at TapeWare and he agrees that this is not a networking/routing issue. Problem solved!!!
85
