Is VLAN routing supported by 2950 switches ???
Anyone please guide; I have one 2950 switch at each floor as my user desktop switch and from each of these 2950 switch ,there is a fiber backbone back to a core chassis 4003.
If I am creating VLANs over the 2950 switches, can the 2950 switch do the inter switch routing ? Is 2950 a layer 3 switch ?
Please help out.
Re: Is VLAN routing supported by 2950 switches ???
i can confirm the WS-c2950-24, ws-c2950-c24 and the ws-c2950T-24 do not perform intervLAN routing. They will trunk to the 4003 so let it do the routing.
Hi Sir, do you mean that under my above hardware specification, I still can create VLANs over my 2950 (WS-C2950G-48-EI) switches but just let the 4003 to perform the inter-VLAN routing ?
Do you have any configuration sample for it ? Please help out . Thank you and much appreciated.
You can create multiple VLANs on your 2950. Does your 4003 have a Layer 3 blade to do inter-VLAN routing?. The following pages on CCO should help
http://www.cisco.com/warp/public/473/140.html
http://www.cisco.com/warp/public/473/28.html
269
