ISDN 2b+1d support on incoming connection.
I'm planning to put in a Cisco1721 with 2 ISDN card to support for 15 incoming ISDN call from remote site.Can it be done?each of my remote site has only a few users.
1 REPLY
Re: ISDN 2b+1d support on incoming connection.
Can you explain this a little better? At the most, you can support 4 64k calls simultaneously. That doesn't take into account how many remote sites you have or the possibility as to how many might try to dial in at the same time.
If your question is if theoretically tou can configure 15 interfaces for the remote sites in the 1721 the answer is yes.
Use dialer profiles and put the BRI's in the same pool
Interface BRI0/0
encap ppp
ppp authen chap
no ip address
dialer pool-member 4 priority 255
isdn switch-type whatever
isdn spid1 whatever
isdn spid2 whatever
interface Dialer1
bandwidth 64
ip address whatever
encapsulation ppp
dialer pool 4
dialer-group 1
no peer neighbor-route
ppp authentication chap
233
