ISDN active and clearing traps
We use the ISDN traps generated when the BRI is activated and deactivated to log ISDN usage. It appears that sometimes we receive a "call active" trap with a call duration value greater than zero which can't be right.
What you would expect to see would be ISDN Trap Received - Call is Active with a call duration of 0 seconds, followed by ISDN Trap Received - Call is Clearing with the associated Call duration. But this does not happen as a matter of course, is this a known problem with certain versions of code or is there anyway for me to resolve this problem?
Below is a dump of some of the traps that I have been receiving.
Call active traps:
1052390459 8 Thu May 08 11:40:59 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 0, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052391066 8 Thu May 08 11:51:06 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
1052391242 8 Thu May 08 11:54:02 2003 192.168.1.21 - ISDN trap received, device RO-RM1-1003, isdn number 01554746544, cal
1052391614 8 Thu May 08 12:00:14 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
l duration 10781, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052391773 8 Thu May 08 12:02:53 2003 192.168.1.21 - ISDN trap received, device RO-DAR-1601, isdn number 01325469773, cal
l duration 299, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052391832 8 Thu May 08 12:03:52 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
l duration 22, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052393421 8 Thu May 08 12:30:21 2003 192.168.1.21 - ISDN trap received, device RO-DAR-1601, isdn number 01325469773, cal
1052393863 8 Thu May 08 12:37:43 2003 192.168.1.21 - ISDN trap received, device RO-DAR-1601, isdn number 01325469773, cal
1052394213 8 Thu May 08 12:43:33 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
1052394582 8 Thu May 08 12:49:42 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
1052394899 8 Thu May 08 12:54:59 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 193, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052395485 8 Thu May 08 13:04:45 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 23, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052395593 8 Thu May 08 13:06:33 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 20, status = Call is Active;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052395786 8 Thu May 08 13:09:46 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
Call cleared traps:
1052389336 8 Thu May 08 11:22:16 2003 192.168.1.21 - ISDN trap received, device RO-RM1-1003, isdn number 01554746544, cal
l duration 2130, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052390547 8 Thu May 08 11:42:27 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 93, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052391631 8 Thu May 08 12:00:31 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
l duration 22, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052391873 8 Thu May 08 12:04:33 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
l duration 46, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052392067 8 Thu May 08 12:07:47 2003 192.168.1.21 - ISDN trap received, device RO-DAR-1601, isdn number 01325469773, cal
l duration 299, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052393715 8 Thu May 08 12:35:15 2003 192.168.1.21 - ISDN trap received, device RO-DAR-1601, isdn number 01325469773, cal
1052394099 8 Thu May 08 12:41:39 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 3039, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052394237 8 Thu May 08 12:43:57 2003 192.168.1.21 - ISDN trap received, device RO-DAR-1601, isdn number 01325469773, cal
l duration 379, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052394680 8 Thu May 08 12:51:20 2003 192.168.1.22 - ISDN trap received, device RO-SCA-1603, isdn number 01723585410, cal
l duration 472, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052394770 8 Thu May 08 12:52:50 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 193, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052394916 8 Thu May 08 12:55:16 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 23, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052395500 8 Thu May 08 13:05:00 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
l duration 20, status = Normal call clearing;1 .1.3.6.1.4.1.9.9.26.2.0.2 0
1052395608 8 Thu May 08 13:06:48 2003 192.168.1.22 - ISDN trap received, device RO-DUN-1603, isdn number 02887748956, cal
Thanks, Nick.
1 REPLY
Silver
Re: ISDN active and clearing traps
I think the issue is due to the bug CSCdk83288 .You will be able to see more details in the Cisco Bug Toolkit.
92
