ISDN addressing for BRI and PRI
When we assign an IP address to a BRI / PRI interface, I trust, the IP address gets assigned to the D channel of the BRI / PRI interface.
Since the BRI / PRI has more than one B channel, can these B channels connect to more than one destinations at the same time ?
If yes, then does it mean more than one B channel will share the same IP address though they might have a circuit established with different destinations ?
Thanks and regards
S. Vijayendran
1 REPLY
Bronze
Re: ISDN addressing for BRI and PRI
Your assumption is correct. If you thing of the ISDN cloud as a network, your hub will have a single IP address, and it will map other IP addresses on the ISDN network to other locations according to dialer maps.
Mark
88
