Community Member
ISDN backup for Frame Relay Network
What would be the best method to backup FR with ISDN. My scenario is the following: FR connection to all remote offices, using sub-interfaces, and OSPF protocol. I have read all the options but I still can't decide. Backup Interface or Dialer watcher? I also want to keep it simple yet effective. Thank you.
1 REPLY
Re: ISDN backup for Frame Relay Network
Since I am not familiar with your network setup and any special requirements that you may have, I will refrain from recommending one particular method over another.
Check out this link
http://www.cisco.com/warp/public/123/backup-main.html
This gives an evaluation of all the methods available and their pros and cons. You should be able to decide after reading this document.
Hope this helps
107
