Isdn Backup problem
Here is the diagram
| frame-relay |
| cloud |
| with RIP |
|T1 LINE
| 3662 Router |
| with 8 port |
| bri |
| WITH RIP |
|T1 LINE =====>192.168.12.0/252
| ISDN BACKUP ===========> 192.168.13.0/252
| 2660 router |
| with 4 port bri |
| WITH RIP |
network on 3660
192.168.10.0/24
192.168.20.0/24
network on 2660
192.168.11.0 /24
NY 3660 ROUTER CONFIG IS
ROUTER RIP
redistribute connected
redistribute static
network 192.168.10.0
network 192.168.20.0
int bri 2/0 have been correctly configured
I config a floating static route like the fllowing
ip route 0.0.0.0 0.0.0.0 192.168.13.2(the 2660 isdn bri1/0 ip address) 250
my 2660 router config is
ROUTER RIP
redistribute static
network 192.168.11.0
int bri 1/0 have been correctly configured
ip route 0.0.0.0 0.0.0.0 192.168.13.1 (the 3660 isdn bri2/0 ip address) 250
after I test , I found something wrong
the bri 1/0 on 2660 has dial to 3660 router successfully via the floating route
0.0.0.0 0.0.0.0 192.168.13.1 250
but in 3660 , the RIP routing protocol do not tear down , so the
floating route on 3660
ip route 0.0.0.0 0.0.0.0 192.168.13.2 250
does not work
How do I config the c3660 router and 2660 router
ps: Do I need to key the command like network 192.168.13.0 on both router ???
  • Other Network Infrastructure Subjects
1 REPLY
Re: Isdn Backup problem
YES..you need to have network of isdn lines included under the RIP.
Visit following links for more information on config and troubleshooting backup using floating static routes
http://www.cisco.com/warp/public/125/fr_isdn_backup.html
http://www.cisco.com/warp/public/125/19.html
http://www.cisco.com/warp/public/123/5.html
82
