ISDN backup using floating static routes
admin_2
Level 3
Level 3
I am configuring an ISDN dialer backup, all works ok with the following static route
Ip route 0.0.0.0 0.0.0.0 172.16.40.5
But will not work with the following static route
Ip route 0.0.0.0 0.0.0.0 bri0
I get do a debug ip packet and get an encapsulation failed message, why will this not work with the second static route, is it possible to get this working so I can standardise all our remote office configs.
Not applicable
The issue concerns one of mapping layer
3 addresses to layer 2 (DDR), which is
a multipoint (ie can dial multiple sites)
interface. When you have
ip route 0.0.0.0 0.0.0.0 172.16.40.5
Every packet will be given a next hop
destination address of 172.16.40.5; if
this points to a DDR interface, and
that DDR interface has a dialer map for
the IP address 172.16.40.5 then all is
well.
However, if you have
ip route 0.0.0.0 0.0.0.0 bri 0
Then (let's say) we receive an IP
packet with a destination address of
10.1.1.1; the routing table points us
to BRI0, and unless BRI0 has a dialer
map for 10.1.1.1 we will get an encapsulation
error.
With DDR interfaces the preferred approach
is to use a specific next hop address; if
that is a problem, and you are only dialing
to one site, use dialer profiles (which
are point to point interfaces) and the
BRI static route should work.
