ISDN Backup With Dialer Interface, and ip unnumbered
I am having some trouble connecting the two with isdn you will find floating interface routes for the isdn. when running debug I get on the WHSE-TO-MAIN Router "cause I =no route to network", and on MAIN-TO-WHSE i get "cause i = host rejected"
any thoughts here are the configs
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname MAIN-TO-WHSE
boot system flash 1:aaa1308.bin
enable password 7 091C175A4E0914071F
username WHSE-TO-MAIN password 7 055B5F5C76404D1C0D
memory-size iomem 15
ip subnet-zero
ip name-server 208.229.42.8
isdn switch-type basic-5ess
isdn voice-call-failure 0
interface FastEthernet0/0
ip address 172.19.0.1 255.255.0.0
no ip directed-broadcast
duplex auto
speed auto
interface Serial0/0
description connected to WHSE-TO-MAIN
ip unnumbered FastEthernet0/1
service-module t1 remote-alarm-enable
interface BRI0/0
no ip address
encapsulation ppp
shutdown
dialer rotary-group 1
dialer-group 1
no cdp enable
ppp authentication pap
ppp multilink
interface FastEthernet0/1
description connected to Westbury
ip address 208.229.42.251 255.255.255.0
no keepalive
duplex auto
speed auto
interface FastEthernet0/1.1
interface Dialer1
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map ip 172.16.0.1 name WHSE-TO-MAIN broadcast 16092081481
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp multilink
router rip
version 2
network 208.229.42.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 208.229.42.11
ip route 146.132.226.206 255.255.255.255 208.229.42.52
ip route 161.173.192.0 255.255.240.0 208.229.42.52
ip route 165.247.40.0 255.255.255.0 208.229.42.11
ip route 172.16.0.0 255.255.0.0 BRI0/0 220
ip route 172.17.0.0 255.255.0.0 208.229.42.2
ip route 172.19.0.0 255.255.0.0 FastEthernet0/0
ip route 199.88.143.0 255.255.255.0 208.229.42.11
ip http server
dialer-list 1 protocol ip permit
version 12.0
service timestamps log datetime
hostname WHSE-TO-MAIN
boot system flash:c2600-i-mz.120-7.T
enable secret 5 $1$q2LT$ajPf9bLmDVmMNXAvX385G0
username MAIN-TO-WHSE password 7 055B5F5C76404D1C0D
ip subnet-zero
no ip domain-lookup
description connected to Robbinsville
ip address 172.16.0.1 255.255.0.0
no keepalive
duplex auto
speed auto
interface Serial0/0
description connected to MAIN-TO-WHSE
ip unnumbered FastEthernet0/0
no ip mroute-cache
interface BRI0/0
no ip address
encapsulation ppp
shutdown
dialer-group 1
no cdp enable
ppp multilink
interface Dialer1
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map ip 208.229.42.251 name MAIN-TO-WHSE broadcast 15167941521
dialer-group 1
no cdp enable
ppp multilink
router rip
version 2
network 172.16.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 208.229.42.251 permanent
ip route 63.77.35.0 255.255.255.0 208.229.42.11
ip route 172.17.0.0 255.255.0.0 208.229.42.2 permanent
ip route 198.80.14.0 255.255.255.0 208.229.42.11
ip route 199.88.143.0 255.255.255.0 208.229.42.11 permanent
ip route 208.229.42.0 255.255.255.0 BRI0/0 220
ip http server
logging 172.16.1.17
any help would be greatly appreciated
thanks in advance
Silver
Re: ISDN Backup With Dialer Interface, and ip unnumbered
Please change the routing command to point to the dialer 1 interface on both end.
For eg: ip route 172.16.0.0 255.255.0.0 BRI0/0 220
change to : ip route 172.16.0.0 255.255.0.0 dialer1 220
Thanks, Mak
Just to add, the other way to achive the same is to point the floating static route to the next hop with higher matric. So in your case the config will be
ip route 172.16.0.0 255.255.0.0 172.16.0.1 220
That will work because you have a dialer map (ina away is a static route) configured.
Pl. visit following url for more
http://www.cisco.com/warp/public/793/access_dial/hdlc_12497.html
Let me ask you a question im using both ip unnumbed on the S0 interface, and the Dialer1 interface. Is this going to cause any problems, as you can see in the diagram im not done configuring it for backup, right now im just trying to get it to work. I have some debug's to paste in im not sure if it means anything but take a look at these two lines i think i have a problem with the isdn lines. one being data only, and the other being voice and data.
MAIN-TO-WHSE -----------------208.229.24.0
0x08017D05040288901801832C0B3136303932303831343831
4d03h: SETUP pd = 8 callref = 0x7D
4d03h: Bearer Capability i = 0x8890
4d03h: Channel ID i = 0x83
4d03h: Keypad Facility i = '16092081481'
4d03h: ISDN BR0/0: RX <- RRr sapi = 0 tei = 72 nr = 27
4d03h: ISDN BR0/0: RX <- INFOc sapi = 0 tei = 72 ns = 39 nr = 27 i = 0x0801FD02180189
4d03h: CALL_PROC pd = 8 callref = 0xFD
4d03h: Channel ID i = 0x89
4d03h: ISDN BR0/0: TX -> RRr sapi = 0 tei = 72 nr = 40
4d03h: ISDN BR0/0: received HOST_PROCEEDING call_id 0x842C
4d03h: ISDN BR0/0: RX <- INFOc sapi = 0 tei = 72 ns = 40 nr = 27 i = 0x0801FD45080282A2340103
4d03h: DISCONNECT pd = 8 callref = 0xFD
4d03h: Cause i = 0x82A2 - No channel available
4d03h: Signal i = 0x03 - Network congestion tone on
4d03h: ISDN BR0/0: TX -> RRr sapi = 0 tei = 72 nr = 41
4d03h: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x842C
4d03h: ISDN BR0/0: HOST_DISCONNECT_ACK: call type is DATA
WHSE-TO-MAIN ----------------------172.16.0.0
0x08017105040288901801832C0B3135313637393431353231
45w3d: SETUP pd = 8 callref = 0x71
45w3d: Bearer Capability i = 0x8890
45w3d: Channel ID i = 0x83
45w3d: Keypad Facility i = '15167941521'
45w3d: ISDN BR0/0: RX <- RRr sapi = 0 tei = 69 nr = 3
45w3d: ISDN BR0/0: RX <- INFOc sapi = 0 tei = 69 ns = 6 nr = 3 i = 0x08007B3201C3
45w3d: INFORMATION pd = 8 callref = (null)
Info Request i = 0xC3
45w3d: ISDN BR0/0: TX -> RRr sapi = 0 tei = 69 nr = 7
45w3d: ISDN BR0/0: Incoming call id = 0x7D5, dsl 0
45w3d: ISDN BR0/0: received HOST_INFORMATION call_id 0x0
45w3d: ISDN BR0/0: RX <- INFOc sapi = 0 tei = 69 ns = 7 nr = 3 i = 0x0801F15A08028283952A2D809E143531362D3739342D3135323120202020202020209E14436865636B206E756D6265722C2072656469616C
45w3d: RELEASE_COMP pd = 8 callref = 0xF1
45w3d: Cause i = 0x8283 - No route to destination
45w3d: Locking Shift to Codeset 5
45w3d: Codeset 5 IE 0x2A i = 0x809E14, '516-794-1521', 0x20202020202020209E14, 'Check', 0x20, 'number,', 0x20, 'redial'
45w3d: ISDN BR0/0: TX -> RRr sapi = 0 tei = 69 nr = 8
45w3d: ISDN BR0/0: received HOST_DISCONNECT_ACK call_id 0x94C5
45w3d: ISDN BR0/0: Error: Unfound B-channel on Disconnect_Ack - callid 0x94C5
45w3d: ISDN BR0/0: HOST_DISC_ACK Voice cid 0x9
I do not have all of the details, nor am i an expert on isdn line types but from the bottom two erros it appears that the both of the routers are talking but the isdn line type's are diffrent.
161
