ISDN between two 801 Router
Hello guys,
i have ISDN working between two 801 Routers. the connection ist OK but the only proble is : Every Morning i most reboot one Router (hostname Raunheim)to get the connection up. ist here a sowftware probg or ??? see config
Raunheim#show tech-support
------------------ show version ------------------
IOS (tm) C800 Software (C800-SY6-MW), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 16-May-00 15:02 by ccai
Image text-base: 0x000EA000, data-base: 0x00731000
ROM: TinyROM version 1.2(2)
Raunheim uptime is 3 hours, 30 minutes
System image file is "flash:c800-sy6-mw_121-2_T.bin"
Cisco C803 (MPC860) processor (revision 1) with 43964K bytes of virtual memory.
Processor board ID JAD044702B2
CPU part number 33
X.25 software, Version 3.0.0.
Bridging software.
Basic Rate ISDN software, Version 1.1.
2 POTS Ports
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
4M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
------------------ show running-config ------------------
Building configuration...
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Raunheim
enable password 7 <removed>
ip subnet-zero
ip dhcp excluded-address 192.168.129.1
ip dhcp excluded-address 192.168.129.100
ip dhcp excluded-address 192.168.129.200
ip dhcp pool dhcp1
network 192.168.129.0 255.255.255.0
default-router 192.168.129.1
no ip domain-lookup
isdn switch-type basic-net3
isdn leased-line BRI0
interface Ethernet0
ip address 192.168.129.1 255.255.255.0
interface BRI0
no ip address
encapsulation ppp
interface BRI0:1
ip address 192.168.128.2 255.255.255.252
encapsulation ppp
ip mroute-cache
interface BRI0:2
no ip address
shutdown
router eigrp 1
network 192.168.128.0
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.128.1
line con 0
login
transport input none
stopbits 1
line vty 0 4
login
no rcapi server
end
Nussloch#show tech-support
Nussloch uptime is 2 days, 18 hours, 40 minutes
Processor board ID JAD044702LS
CPU part number 33
Bridging software.
2 POTS Ports
version 12.1
hostname Nussloch
ip subnet-zero
no ip domain-lookup
interface Ethernet0
ip address 209.28.98.223 255.255.255.0
interface BRI0
no ip address
encapsulation ppp
interface BRI0:1
ip address 192.168.128.1 255.255.255.252
encapsulation ppp
interface BRI0:2
no ip address
shutdown
router eigrp 1
network 209.28.98.0
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 209.28.98.1
line con 0
login
stopbits 1
line vty 0 4
login
no rcapi server
end
1 REPLY
Re: ISDN between two 801 Router
Need to know what is the status of bri interface before you reboot the router next morning. so pl issue following commands on Raunheim before reboot and post it here.
sh interface bri0
sh interface bri0:1
sh ip route
Now what is the bandwidth of that bri leased line ? 64K or 128K?
You can use the config at following url for more on that
http://www.cisco.com/univercd/cc/td/doc/product/software/ios112/isdn128k.htm
114
