ISDN BRI 2nd B channel won't stay up
I have a 3620 router with an 8 port isdn BRI module in it. The purpose of this router is to have ISDN modem users dial-in so it isn't a Cisco to Cisco connection (3com, U.S. Robotics, etc.). The U.S. Robotics isdn modem doesn't work at all but thats another problem that I'll have to look into. The 3com and EICON Diva ISDN modem both connect with one channel.
Right now, I'm more concerned with getting the 2nd B channel to stay connected. I dial the first number in the list and it connects no problem. When I pass the threshold (which is now set to 1) the 2nd B channel tries to connect but gets rejected (call rejected). I believe that I have the correct commands in the config but it never stays up. After running debug, it shows a rejected call to the B channel when the load goes above the threshold. The call was initiated on an NT 4.0 workstation with a 3com isdn modem. As you can see in the debug, BRI1/6:2 is trying to be brought up and this was due to a traffic increase (dialer load-threshold 1 either). The call is rejected and BRI1/6:2 goes back to a down state. The SPID1 in BRI1/6 (BRI1/6:1) is the number that is initially dialed.
All I want is for a second B channel to come up when it reaches the dialer threshold.
Any ideas? Do I have this setup incorrectly? I have the same thing working on a Cisco 804 router but it is a router to router connection.
Config and debug are below.
RUNNING-CONFIG
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ISDNROUTER
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default group radius
aaa authentication ppp default group radius
aaa accounting network default start-stop group radius
ip subnet-zero
no ip finger
ip name-server xxx.xxx.xxx.xxx
isdn switch-type basic-ni
interface Ethernet0/0
description connected to EthernetLAN
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip helper-address xxx.xxx.xxx.xxx
no keepalive
full-duplex
interface BRI1/0
description connected to Dial-inPCs(ISDN)
no ip address
encapsulation ppp
dialer rotary-group 1
isdn spid1 #############1
isdn spid2 #############2
no cdp enable
interface BRI1/1
no ip address
encapsulation ppp
isdn spid1 #############3
isdn spid2 #############4
no cdp enable
interface BRI1/2
no ip address
encapsulation ppp
isdn spid1 #############5
isdn spid2 #############6
no cdp enable
interface BRI1/3
no ip address
encapsulation ppp
isdn spid1 #############7
isdn spid2 #############8
no cdp enable
interface BRI1/4
no ip address
encapsulation ppp
isdn spid1 #############9
isdn spid2 ############10
no cdp enable
interface BRI1/5
no ip address
encapsulation ppp
isdn spid1 #############11
isdn spid2 #############12
no cdp enable
interface BRI1/6
no ip address
encapsulation ppp
isdn spid1 ############13
isdn spid2 ############14
no cdp enable
interface BRI1/7
no ip address
encapsulation ppp
isdn spid1 ############15
isdn spid2 ############16
no cdp enable
interface Dialer1
ip unnumbered Ethernet0/0
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 3600 either
dialer-group 1
peer default ip address pool DPOOL
no cdp enable
ppp authentication pap chap
ppp multilink
ip local pool DPOOL xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
ip default-gateway xxx.xxx.xxx.xxx
ip classless
no ip http server
dialer-list 1 protocol ip permit
radius-server host xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646
radius-server retransmit 3
radius-server key 7 1234567890
end
DEBUG
1w2d: ISDN BR1/6: Event: Accepting the call id 0x109
1w2d: %LINK-3-UPDOWN: Interface BRI1/6:2, changed state to up
FRSISDN02#
1w2d: ISDN BR1/6: TX -> INFOc sapi = 0 tei = 80 ns = 65 nr = 9 i = 0x080199
0218018A
1w2d: CALL_PROC pd = 8 callref = 0x99
1w2d: Channel ID i = 0x8A
1w2d: ISDN BR1/6: RX <- RRr sapi = 0 tei = 80 nr = 66
1w2d: ISDN BR1/6: RX <- INFOc sapi = 0 tei = 80 ns = 9 nr = 66 i = 0x080119
5A08028295
1w2d: RELEASE_COMP pd = 8 callref = 0x19
1w2d: Cause i = 0x8295 - Call rejected
1w2d: ISDN BR1/6: TX -> RRr sapi = 0 tei = 80 nr = 10
FRSISDN02#
1w2d: %LINK-3-UPDOWN: Interface BRI1/6:2, changed state to down
FRSISDN02#
1w2d: ISDN BR1/6: TX -> RRp sapi = 0 tei = 89 nr = 72
1w2d: ISDN BR1/6: RX <- RRf sapi = 0 tei = 89 nr = 1
FRSISDN02#
1w2d: ISDN BR1/6: RX <- UI sapi = 0 tei = 127 i = 0x08011A050402889018018A3401
407008C136373230353934952A1A808001038C0E466F727761726465642D6275737980010380013C
1 REPLY
Bronze
Re: ISDN BRI 2nd B channel won't stay up
The call is being cleared by the caller, not the cisco:
1w2d: ISDN BR1/6: TX -> INFOc sapi = 0 tei = 80 ns = 65 nr = 9 i = 0x0801990218018A
1w2d: ISDN BR1/6: RX <- INFOc sapi = 0 tei = 80 ns = 9 nr = 66 i = 0x0801195A08028295
Not sure why the carrier or remote is rejecting the call.
I would suggest you increase the load-threshold to 3 (not related to your current problem, but it may prevent future toggling) and that you enable MSEC timestamps for debugging purposes:
serv time log da ms
serv time deb da ms
I would stick with "debug isdn q931" when troubleshooting this, too. In general, to troubleshoot problems with the second channel connecting I would pay attention to:
show ppp mult ! confirm existing bundles
debug isdn q931 ! have a look at what ISDN is doing
debug ppp neg ! If the ISDN call is being accepted, see what PPP is doing
214
