isdn bri doesn't call
Hello, I am a beginner in the networking and have to configure a router 2503 to do a call to a windows 2000 RRAS. The windows calls but does not authenticates chap, but now isn't a problem. On the other hand the router does not even begin the call. Below I attach you the configuration. Can someone help me?
Thank you.
Current configuration:
version 11.2
service timestamps debug uptime
service timestamps log uptime
no service udp-small-servers
no service tcp-small-servers
hostname Barcelona
boot system flash
enable secret XXXXX
username xxxxx password xxxxx
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Ethernet0
shutdown
interface Serial0
shutdown
interface BRI0
description Connect to Windows 2000
ip address 10.0.2.1 255.255.255.0
encapsulation ppp
dialer idle-timeout 7200
dialer map ip 10.0.2.2 name cisco 999000999
dialer load-threshold 1 either
dialer-group 1
ppp authentication chap
ip route 10.0.2.2 255.255.255.255 BRI0
dialer-list 1 protocol ip permit
line con 0
transport input none
line aux 0
line vty 0 4
login
end
Silver
Re: isdn bri doesn't call
How are you trying to initiate a call? What does "sh isdn status" indicate?
The following debugs will be useful when trying to ping 10.0.2.2. (If you are tying to initiate a call to any other ip address across, need to add appropriate routing command. "ip route x.x.x.x z.z.z.z 10.0.2.2)
deb dialer / deb isdn q931/ deb ppp nego.
http://www.cisco.com/warp/public/701/23.html
Thanks, Mak.
Hello, thank you very much, now already calls but does not establishes the authentication chap. The communication establishes between a router 2503 and windows 2000 RRAS. The W2K pc is called rrasw2k and rras has name cisco and password cisco. The router is called bcn. Down below there is the configuration. The debug show this:
BR0:1 PPP: Phase is AUTHENTICATING, by both
BR0:1 CHAP: O CHALLENGE id 9 len 24 from "bcn"
BR0:1 CHAP: I CHALLENGE id 0 len 34 from "rrasw2k"
BR0:1 CHAP: Username rrasw2k not found
BR0:1 CHAP: Unable to authenticate for peer
BR0:1 PPP: Phase is TERMINATING
BR0:1 LCP: O TERMREQ [Open] id 21 len 4
BR0:1 LCP: I TERMACK [TERMsent] id 21 len 4
BR0:1 LCP: State is Closed
BR0:1 PPP: Phase is DOWN
BR0:1 PPP: Phase is ESTABLISHING, Passive Open
BR0:1 LCP: State is Listen
version 11.2
hostname bcn
enable secret 5 XXXXXXXX
interface Ethernet0
no ip address
shutdown
interface BRI0
ip address 10.0.2.2 255.255.255.0
encapsulation ppp
dialer map ip 10.0.2.2 939999999
dialer-group 1
no ip classless
end
Can anyone help me?
Thank you.
Marti.
Bronze
Marti,
You need to add the remote host rrasw2k in your router's configuration, along with the proper password. This host does not have the name "cisco" because the CHAP challenge in your debugging comes from the device named rrasw2k. Your config needs to have this username/password.
Good Luck!
Mark
85
