ISDN BRI Error: Cause i=0x82EF - Protocol error; unspecified
I'm receiving the following error message on two Cisco 1760 routers that are attempting to communicate with each other over an ISDN BRI link: "Cause i = 0x82EF - Protocol error; unspecified."
I have appended configuration files and a debug session using pings below w/ more information.
I have talked with the phone company:
* all circuit tests pass.
* the technician could establish sessions w/ each of my routers over their ISDN BRI channels.
The "sh isdn status" command gives the following:
Global ISDN Switchtype = basic-ni
ISDN BRI0/0 interface
dsl 0, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 97, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI = 98, Ces = 2, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 97, ces = 1, state = 8(established)
spid1 configured, spid1 sent, spid1 valid
Endpoint ID Info: epsf = 0, usid = 70, tid = 0
TEI 98, ces = 2, state = 8(established)
spid2 configured, spid2 sent, spid2 valid
Endpoint ID Info: epsf = 0, usid = 71, tid = 0
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 6, L2 Session ID = 41
Any ideas?
*** BEGIN CONFIG AND DEBUG INFORMATION ***
Side 1:
Cisco 1760 router
ISDN BRI U interface
IOS 12.2(11)T8
SPID1: 101123000000
SPID2: 101123111100
Side 2:
Cisco 1760 router
IOS 12.2(11)T8
SPID1: 10112322220101
SPID2: 10112333330101
Side 1 router startup-config:
version 12.2
service password-encryption
hostname ...
ip subnet-zero
ip name-server ...
isdn switch-type basic-ni
interface Loopback0
no ip address
interface FastEthernet0/0
ip address 10.0.0.8 255.255.255.0
speed 100
full-duplex
fair-queue
interface BRI0/0
description ISDN Circuit
ip address 10.68.0.1 255.255.0.0
encapsulation ppp
dialer string 1232222 ; Note: I've also used a dialer map command w/ the same result.
dialer load-threshold 127 either
dialer-group 1
isdn spid1 101123000000 1230000
isdn spid2 101123111100 1231111
compress predictor
ppp multilink
router rip
version 2
redistribute static
passive-interface BRI0/0
network 10.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.254
ip route 10.69.0.0 255.255.0.0 10.68.0.2
ip http server
access-list 121 permit ip any any
access-list 121 permit icmp any any
access-list 121 permit tcp any any
access-list 121 permit udp any any
dialer-list 1 protocol ip list 121
Side 2 router startup-config:
version 12.2
ip subnet-zero
interface Loopback0
no ip address
description Uplink to ...
ip address 10.69.0.1 255.255.0.0
speed 10
full-duplex
fair-queue
interface BRI0/0
ip address 10.68.0.2 255.255.0.0
encapsulation ppp
dialer string 1230000
dialer-group 1
isdn spid1 10112322220101 1232222
isdn spid2 10112333330101 1233333
compress predictor
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 10.68.0.1
ip http server
Debug session: Side 1 router calling Side 2 router:
clear dialer
...#sh dialer
BRI0/0 - dialer type = ISDN
Dial String Successes Failures Last DNIS Last status
1232222 0 0 never - Default
0 incoming call(s) have been screened.
0 incoming call(s) rejected for callback.
BRI0/0:1 - dialer type = ISDN
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is idle
BRI0/0:2 - dialer type = ISDN
...#sh debug
Dial on demand:
Dial on demand events debugging is on
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON.
Oct 7 16:09:16.874: BR0/0 DDR: place call
Oct 7 16:09:16.874: BR0/0 DDR: Dialing cause ip (s=10.0.0.1, d=10.69.88.77)
Oct 7 16:09:16.874: BR0/0 DDR: Attempting to dial 1232222
Oct 7 16:09:16.878: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x29
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Keypad Facility i = '1232222'
Oct 7 16:09:17.086: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xA9
Channel ID i = 0x89
Locking Shift to Codeset 5
Codeset 5 IE 0x2A i = 0x808807, '1232222', 0x80010D800114800114800114
Oct 7 16:09:17.118: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xA9
Oct 7 16:09:17.122: BRI0/0: wait for isdn carrier timeout, call id=0x8029
Oct 7 16:09:17.126: ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x29
Oct 7 16:09:17.218: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA9
Oct 7 16:09:18.204: BR0/0 DDR: place call
Oct 7 16:09:18.204: BR0/0 DDR: Dialing cause ip (s=10.0.0.1, d=10.69.88.77)
Oct 7 16:09:18.204: BR0/0 DDR: Attempting to dial 1232222
Oct 7 16:09:18.208: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x2A
Standard = CCITT
Channel ID i = 0x83
Oct 7 16:09:18.388: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xAA
Channel ID i = 0x89
Oct 7 16:09:18.420: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xAA
Oct 7 16:09:18.424: BRI0/0: wait for isdn carrier timeout, call id=0x802A
Oct 7 16:09:18.424: ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x2A
Oct 7 16:09:18.516: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xAA
Oct 7 16:09:19.454: BR0/0 DDR: place call
Oct 7 16:09:19.454: BR0/0 DDR: Dialing cause ip (s=10.0.0.1, d=10.69.88.77)
Oct 7 16:09:19.454: BR0/0 DDR: Attempting to dial 1232222
Oct 7 16:09:19.458: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x2B
Standard = CCITT
Channel ID i = 0x83
Oct 7 16:09:19.634: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xAB
Channel ID i = 0x89
Oct 7 16:09:19.670: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xAB
Oct 7 16:09:19.674: BRI0/0: wait for isdn carrier timeout, call id=0x802B
Oct 7 16:09:19.678: ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x2B
Oct 7 16:09:19.770: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xAB
Oct 7 16:09:20.560: BR0/0 DDR: place call
Oct 7 16:09:20.560: BR0/0 DDR: Dialing cause ip (s=10.0.0.1, d=10.69.88.77)
Oct 7 16:09:20.560: BR0/0 DDR: Attempting to dial 1232222
Oct 7 16:09:20.564: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x2C
Standard = CCITT
Channel ID i = 0x83
Oct 7 16:09:20.736: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xAC
Channel ID i = 0x89
Oct 7 16:09:20.772: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xAC
Oct 7 16:09:20.776: BRI0/0: wait for isdn carrier timeout, call id=0x802C
Oct 7 16:09:20.780: ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x2C
Oct 7 16:09:20.872: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xAC
Oct 7 16:09:21.617: BR0/0 DDR: place call
Oct 7 16:09:21.617: BR0/0 DDR: Dialing cause ip (s=10.0.0.1, d=10.69.88.77)
Oct 7 16:09:21.617: BR0/0 DDR: Attempting to dial 1232222
Oct 7 16:09:21.621: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x2D
Standard = CCITT
Channel ID i = 0x83
Oct 7 16:09:21.786: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xAD
Channel ID i = 0x89
Oct 7 16:09:21.818: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xAD
Oct 7 16:09:21.822: BRI0/0: wait for isdn carrier timeout, call id=0x802D
Oct 7 16:09:21.826: ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x2D
Oct 7 16:09:21.922: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xAD
Bronze
Re: ISDN BRI Error: Cause i=0x82EF - Protocol error; unspecified
Hi Larry,
don't know if it is of much help, but this url has an explanation of disconnect cause codes:
http://www.cisco.com/en/US/customer/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
The 82 in 0x82EF seems to indicate that the local telco is sending the disconnect because of an "unspecified" protocol error.
Do you have debug info for the sessions that the telco was able to establish? You could then compare your setup parameters with theirs. E.g. do they support 64k or should you set your speed to 56k etc.
hth
Herbert
Hello:
Yes, everytime you receive a 82 in the cause ID that means a Telco isuue, talk to them & explain them that something is wrong in their side.
Gentlemen: Thank you for your responses. I did have many telephone chats with various SBC technicians; but to no avail. I was told that if I use an 11-digit dialer number a la 12121230000 I would get a 64K connection instead of a 56K connection, which eventually proved to be correct. However, instead of a proper connection, the error message changed: "Cause i = 0x82C1 - Bearer capability not implemented." This caused more frustration for me and head scratching from SBC; even to the point of them trying to trace the call and see where the problem started. As you both mentioned, the 82 in the cause code indicated the local ISDN router.
To make a long story short, after going through my routers' settings with a fine tooth comb and finding nothing apparently wrong, I decided to prepend the dialer string with a "9" to see what would happen. It worked! Apparently my ISDN lines do not connect directly to an ISDN switch but through a PBX and then to an ISDN switch. The SBC technicians apparently did not know or realize this fundamental fact.
1228
