Webcast-Catalyst9k
ISDN BRI module not working in 3640
Dear Experts..
We just purchase 3640 router with 4-port ISDN BRI module, when i PLug in my ISDN line in bri port its layer onee and two not activated and shows me a deactivated status, as follow..
ISDN BRI2/0 interface
dsl 16, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVATING
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 16 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 16
We also have a 2522 router with a bri port and the same ISDN line working fine on that router ,,,
when i on my q921 and q931 debug and give this command
isdn call int bri2/0 5436782
it ginves me the messages as follows
*Mar 24 18:07:29.098: ISDN BR2/0: Could not bring up interface
Plzz tell me what i am missing ,,,,, or is there any p[ossibility of IOS bug ( we are using 12.2-7b ) or the faulty BRI module..
Thanks in advance
Muhamed Asif Shaikh
Re: ISDN BRI module not working in 3640
try this doc
http://www.cisco.com/warp/public/129/isdn_20602.html#problems2
also try using Cisco Output Interpreter for eg; "show isdn status" command and others, very useful tool;
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
R/Yusuf
Somehow the Layer 1 on the BRI in 3640 fail to make it to "Active" state...Try to use " shut/no shut under the interface and also "clear interface bri x/x" to see the results..Also try to move the same bri line to other bri port as well..
Here is the place which talks about that too.
http://www.cisco.com/warp/public/129/bri-layer1.html
And also Layer 2
http://www.cisco.com/warp/public/129/bri-layer2.html
If its not comaing up at all then may be the card went bad...Tejal
127
