ISDN BRI problem
I' ve a problem unpredictable on my interface bri0/0/0 (HWIC 1B-U card) on cisco 2901 : layer 1 U interface is DEACTIVATED - CO RUNNING LOOPBACK TESTS...
And with this  message it's impossible to run the line. I don't understand why this error message come from.
Thank you for your help.
router#show controllers  bri0/0/0
BRI unit 0:BRI unit 0 with U interface:
Layer 1 internal state is PENDING ACTIVATION
FPGA version = V6
FPGA create  = 09/02/18 24
Layer 1 U interface is DEACTIVATED - CO RUNNING LOOPBACK TESTS
** TELEPHONE COMPANY CENTRAL OFFICE RUNNING TESTS ON LINE **
    External S/T is DEACTIVATED - Requesting Timing
ISDN Line Information:
    Last C/I from ISDN transceiver:
        DR:Deactivation Request
    Last C/I to ISDN transceiver:
B1 Channel Information:
Interface BRI0/0/0:1
Hardware is HDLC32. this B channel is not initialized yet!
Slot 0, Wic_slot 0, Port 0
  0 missed datagrams, 0 overruns
  0 bad datagram encapsulations, 0 memory errors
  0 transmitter underruns  0 d channel collisions
B2 Channel Information:
Interface BRI0/0/0:2
router#show int bri0/0/0
BRI0/0/0 is up, line protocol is up (spoofing)
  Hardware is HWIC BRI with U interface (82912)
  Interface is unnumbered. Using address of Loopback1 (172.30.122.1)
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
     reliability 240/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  Last input 00:48:37, output never, output hang never
  Last clearing of "show interface" counters 00:49:14
  Input queue: 0/75/7/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     4 packets input, 32 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     7 input errors, 7 CRC, 0 frame, 0 overrun, 0 ignored, 5 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     6 carrier transitions
interface BRI0/0/0
ip unnumbered Loopback1
encapsulation ppp
dialer idle-timeout 300
dialer map ip 172.30.122.2 name nim1c1 broadcast 0141335690
dialer hold-queue 4
dialer-group 1
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice data
isdn sending-complete
trunk-group ALL_BRI 1
ppp authentication chap
Everyone's tags (2)
VIP Purple
Re: ISDN BRI problem
Can you please paste the output of the command:
sh isdn status
sh isdn active
If layer 1 is deactivated:please check cable connection and then follow these steps:
Perform the steps in this section and, after each step, issue the show isdn status command to check if Layer 1 is up (ACTIVE).
1. Issue the shutdown then the no shutdown command on the BRI interface .
2. This ensures that the BRI interface is not administratively down. You can also issue the clear interface bri number command to reset the interface.
regards
Please rate if it helps.
In fact the channel D is busy, Led NT1 is green. I've reboot the router, same thing, but the line should up only if some icmp packets are send to the other router.
VIP Purple
can u please paste the output ..then we will see :
sh isn status
ISDN BRI problem
here :
router#show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000003
    Total Allocated ISDN CCBs = 0
VIP Purple
Hi Remi,
If the show isdn status command output indicates that Layer1 is DEACTIVATED, then there is a problem with the physical connectivity.
if the problem still exits then :
It most probably TELCO problem only. I have also faced same problem once. I did all possibilities. But still it was showing deactivated. Telco also  done lots of testing.They even came to my location and tested the circuit and told there is no problem at all in their part. But after a long investigation they found some problem in their switching department.
It could be a port issue also. try to swap the connection with another port or module.
Hall of Fame Super Gold
sandeepchoudhary21 wrote:
Hi Remi,
If the show isdn status command output indicates that Layer1 is DEACTIVATED, then there is a problem with the physical connectivity of the T1 line.
That is incorrect. First of all, a BRI circuit is not a " T1 line".
Secondly, anywhere in the world excpet the US, it is normal that telco removes power to the BRI circuit after a timeout. The circuit power is then re-applied as soon a call is attempted in either deictions.
VIP Purple
Hi Paolo,
Thanks for correction about T1 line, that was my mistake.
I  did not get this point????
and what do you think ,what is the problem with this interface??
Thanks again.
You can search for more posts regarding BRI to understand what that means.
Regarding OP problem, he first update IOS, then post more information
Silver
remi Houssoulliez wrote:
here :
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
Remi.
Out of curiosity, what country are you in?
There are several different ISDN switch types which are used, depending on what country you are in. Yours is set to basic-net3, which is only valid on NET3-ISDN switches (Some parts of Europe, norway, New Zealand). If you're in a country which uses a different switch type, you may need to change this to match. Your Telco should be able to telly ou which ISDN switch type you should use.
See the folowing document
http://www.cisco.com/en/US/docs/ios/11_3/feature/guide/natisdn.html
for information on available switch types. For example, as an Aussie, I use basic-ts013 for BRI and primary-net5 for PRI circuits. Mis-match of switch type can cause the interface to not come up.
Also, what type of TA is installed for your ISDN circuit? This can also cause a mis-match. Sorry if this is vague - I'm dredging up stuff I haven't used in literally 10 years from memory.
Cheers.
basic-ts013 is obsolete for Australia. I have installation there and all do work fine with basic-net3.
(config)#isdn switch-type ?
basic-1tr6    1TR6 switch type for Germany
  basic-5ess    Lucent 5ESS switch type for the U.S.
  basic-dms100  Northern Telecom DMS-100 switch type for the U.S.
  basic-net3    NET3 switch type for UK, Europe, Asia and Australia
  basic-ni      National ISDN switch type for the U.S.
  basic-qsig    QSIG switch type
  basic-ts013   TS013 switch type for Australia (obsolete)
  ntt           NTT switch type for Japan
  vn3           VN3 and VN4 switch types for France
In fact, also "basic-1tr6" is now obsolete, as well the vestigial "ntt" and "vn3" types.
Silver
Like I said, Paolo, I was dredging information from about 10 years ago :-). I haven't used a BRI in ages. I was more concerned that the original poster might be in the US, where basic-net3 won't work.
Cheers.
Hi Darren, I was being too zealant, appreciate your contribution here.
2337
