ISDN BRI to PRI WAN
I am trying to determine what hardware/software is needed at the Head-end (PRI side) of an ISDN WAN. I am trying to network 10 small locations dialing out on BRI's into a PRI at the Head-end. I need to know what is going to be required on the head-end in order to handle this WAN.
Thanks-
Colin Clifford
Re: ISDN BRI to PRI WAN
Following Hardware is required:
Router with E1/T1/PRI interface.
example:
1.CISCO3640 Cisco 3600 4-slot Modular Router-AC with IP Software
2.NM-1FE-TX 1-Port Fast Ethernet Network Module (TX Only)
3.NM-1CE1U 1-Port Channelized E1/ISDN-PRI Unbalanced Network Module
or NM-1CE1B 1-Port Channelized E1/ISDN-PRI balanced Network Module
4.If you use non-ISDN telephone to dialin,Digital modem module is required
Gongxinping,
Thanks for the advice and quick response. Much appreciated.
201
