isdn call interface command not working correctly ??!!!
danny_ng
Due to some reason, my PRI router need to be configured multiple dialer profiles with multiple dialer pool-member #. The "isdn call interface" command does not succesfully carry out and failed when display by using the show isdn history command. This command previously was working fine when only single dialer profile is used with dialer rotary-group feature (multiple dialer-map commands).
Any expert has this experience before ?? is it limited and can not use "isdn call interface" when using multiple dialer profiles in single physical interface ??? Please advise and thanks in advance.
Danny
cymurai
It would help if you could post your configs.
These links might help!
http://www.cisco.com/warp/public/129/23.html
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b21.shtml
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a00800c7d61.shtml
Although they are for BRI they should work for PRI interfaces also.
Hope this helps!
