02-10-2004 04:08 PM - edited 03-02-2019 01:30 PM
2 channel is not comming up.
-can get the first one up no problem but the 2nd will just not come up.
head router is a 2651 IOS is IP PLUS
c2600-is-mz.122-19.bin
Remote router is a 1720 IOS is IP PLUS
c1700-sy-mz.122-11.T8.bin
My question has anyone had any issues with either of
these IOS's in an ISDN install???
any suggestions welcome
02-10-2004 04:27 PM
make sure you have
encap ppp
ppp multilink
dialer load-threshold x
configured on the dialer on each end.
the dialer load threshold by default is 127 or the link must be 50 % saturated to come up , if you wish to have the other b channel come up immedialtely then configure dialer load-threshold 1 either .
02-10-2004 10:35 PM
02-11-2004 02:55 AM
can you paste in sh isdn status
02-12-2004 11:41 AM
Notice the B channels available
is only 1
I'm presently talking to the telco right now.
Dial String Successes Failures Last DNIS Last status
2120713 106 6 00:00:25 successful Default
0 incoming call(s) have been screened.
0 incoming call(s) rejected for callback.
BRI0:1 - dialer type = ISDN
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is multilink member
Dial reason: ip (s=10.180.41.13, d=199.194.27.65)
Current call connected 00:01:28
Connected to 2120713 (r1.calgary-INF.hyatt)
BRI0:2 - dialer type = ISDN
Dialer state is idle
r1.calgary-SAT.crowfoot#sho isdn stat det
*14:48:21.643 pST Tue Mar 23 1993
Global ISDN Switchtype = basic-ni
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 78, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI = 79, Ces = 2, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 78, ces = 1, state = 5(init)
spid1 configured, spid1 sent, spid1 valid
Endpoint ID Info: epsf = 0, usid = 70, tid = 1
TEI 79, ces = 2, state = 5(init)
spid2 configured, spid2 sent, spid2 valid
Endpoint ID Info: epsf = 0, usid = 71, tid = 1
Layer 3 Status:
NLCB:callid=0x0, callref=0x0, state=37, ces=0 event=0x0
NLCB:callid=0x806E, callref=0x68, state=10, ces=1 event=0x7
NLCB:callid=0x0, callref=0x0, state=0, ces=2 event=0x0
NLCB:callid=0x0, callref=0x0, state=0, ces=1 event=0x0
1 Active Layer 3 Call(s)
CCB:callid=0x806E, callref=0x68, state=0x4, sapi=0x0, ces=0x1, B-chan=1, calltype=DATA, hdlctype=HDLC-TRUNK
Active dsl 0 CCBs = 1
Number of active calls = 1
Number of available B-channels = 1
The Free Channel Mask: 0x80000002
Total Allocated ISDN CCBs = 1
02-13-2004 10:35 AM
I had this problem in a test lab, and it took me a while to get it right. Try here:
http://www.cisco.com/warp/customer/471/ppp_multilink_ts.html
I had to add this command:
"isdn fast-rollover-delay 5" - Set the rollover delay at 5 seconds.
This delay is provided to allow the old call to be torn down completely before the new call is attempted. This command is necessary on some ISDN switches because the new call may be attempted before the old call is completely torn down. This causes the second call to fail.
Good luck,
Joe
