You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
ISDN Connectivity problem - addendum.
Sorry I posted the incorrect config previously. Here is the proper post.
I have a 2611 in a hub site, and another at a spoke site. The hub site router is acting as a simple access router with an E1 card transferring requests to a Radius server. This part works fine locally however when dialling up remotely, the hub router hangs the line up after a few seconds without even attempting to authenticate. Hub config is below, the spoke sited were dialling successfully to a Tigris router. Any help appreciated.
Dean
sh run
Building configuration...
Current configuration : 2183 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname mel04
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default group radius
aaa authentication login NO_RADIUS local
aaa authentication ppp default group radius
aaa authorization exec default group radius
aaa authorization exec NO_RADIUS local
aaa authorization network default local group radius
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
enable password 7 045E1B570C345E4B
--More-- !
username root password 7 151C0E07102B39
ip subnet-zero
no ip finger
no ip domain-lookup
ip name-server 202.81.96.82
isdn switch-type primary-ts014
controller E1 1/0
pri-group timeslots 1-31
interface Ethernet0/0
description Connected to HP Switch on mel04 VLAN
ip address 202.81.105.66 255.255.255.252
full-duplex
interface Ethernet0/1
no ip address
--More-- shutdown
half-duplex
interface Serial1/0:15
no ip address
no cdp enable
interface Dialer0
no ip address
no cdp enable
interface Dialer1
description connected to dial in PCs(ISDN)
no ip address
encapsulation ppp
no ip split-horizon
dialer in-band
dialer-group 1
peer default ip address pool mel04-Group-1
ppp authentication chap pap callin
ppp multilink
--More-- ip local pool me104-Group-1 203.81.106.1 203.81.106.30
ip classless
ip default-network 202.81.105.0
ip route 0.0.0.0 0.0.0.0 202.81.105.65
ip http server
snmp-server community public RO
snmp-server location Richmond
radius-server host 202.81.96.93 auth-port 1645 acct-port 1646 key 7 050C051B285F5E
radius-server host 202.81.96.94 auth-port 1645 acct-port 1646 key 7 10490A0D0C0402
radius-server host 202.81.96.99 auth-port 1645 acct-port 1646 key 7 07082258471A09
radius-server retransmit 3
line con 0
exec-timeout 0 0
password 7 11071C0E031319
transport input none
line aux 0
line vty 0 4
password 7 06080A2A584F1B
--More-- authorization exec NO_RADIUS
login authentication NO_RADIUS
no scheduler allocate
end
mel04#
  • Other Network Infrastructure Subjects
Re: ISDN Connectivity problem - addendum.
The D channel of the E1/PRI line "interface Serial1/0:15" is not likned with the interface dialer 1. So i can expect the PPP call not to work. So to fix that you need to have the config like following. "dialer rotary-group 1" will link that interface with "interface dialer 1"
no ip address
dialer-group 1
ppp multilink
Also not sure why the dialer interface is not configured with the ip address. You need to add the command "ip unnumbered ethernet 0/0" under "interface dialer 1". with that calls should work fine(asumming the radius is configured fine). If not, we need to see the debug for following
debug isdn q931
debug ppp nego
debug ppp auth
debug aaa authentication
debug aaa authorization
Dean
Just a quick comment...I noticed that in the statement
"ip local pool me104-Group-1 203.81.106.1 203.81.106.30"
you refer to ME104-Group-1 rather than MEL04-Group-1
would stop an IP address being allocated.
Peter
Peter, thanks very much for that, what a trap for young players! I'm not sure if this is the existing config as I have posted an old capture but I'll certainly be checking that.
Dean
84
