ISDN D-channel Layer 2 Problem !!
hi ,
I have a router with E1 module (see sh version below) , I'm trying to connect this router to a PBX .
the problem is , ISDN serial 0:15 interface is giving TEI_ASSIGNMENT in the layer 2 (this is from sh isdn status), and it shows Serial1/0:15 is up, line protocol is up (spoofing) (in show interface s1/0:15)
I know that the problem is in the D-channel ,
I'm trying to set the encapsulation to PPP on the interface s1/0:15 but it gives me this error :
"%Hardware does not support ISDN data calls; encapsulation not set."
anyone can tell me what is that , I'm sure that the problem is from the encaspulation !!!
please help.
this is what I got when trying to set the encapsulation to PPP
MICDGWV(config-if)#int s1/0:15
MICDGWV(config-if)#encapsulation ?
atm-dxi ATM-DXI encapsulation
bstun Block Serial tunneling (BSTUN)
cpp Combinet proprietary protocol
hdlc Serial HDLC synchronous
lapb LAPB (X.25 Level 2)
ppp Point-to-Point protocol
sdlc SDLC
sdlc-primary SDLC (primary)
sdlc-secondary SDLC (secondary)
smds Switched Megabit Data Service (SMDS)
stun Serial tunneling (STUN)
x25 X.25
MICDGWV(config-if)#encapsulation ppp
--------------------------------------- sh version --------------------------------------------------
IOS (tm) C2600 Software (C2600-JS-M), Version 12.2(7b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 05-Mar-02 04:40 by pwade
Image text-base: 0x80008088, data-base: 0x813C20E0
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
MICDGWV uptime is 59 minutes
System image file is "flash:c2600-js-mz.122-7b.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 60416K/5120K bytes of memory.
Processor board ID JAD05060EFH (3259457801)
M860 processor: part number 0, mask 49
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
7 Serial network interface(s)
2 Serial(sync/async) network interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
------------------------------------------------ interface seial1/0:15 ----------------------
MICDGWV#sh int s1/0:15
Hardware is DSX1
Description: VOIP||ISDN|Y||||||| See E1 Controller for details
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input never, output 00:58:48, output hang never
Last clearing of "show interface" counters 00:10:13
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
----------------------sh ru ----------------------
MICDGWV#sh run
Building configuration...
Current configuration : 1953 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname MICDGWV
boot system flash c2600-js-mz.122-7b.bin
boot system rom
logging buffered 4096 notifications
enable password xxxx
voice-card 1
ip subnet-zero
isdn switch-type primary-qsig
call rsvp-sync
cns event-service server
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711alaw
voice class h323 1
h225 timeout tcp establish 3
dial-control-mib retain-timer 1000
dial-control-mib max-size 1200
controller E1 1/0
pri-group timeslots 1-6,16
interface Loopback0
ip address xxxxxxxxxxx 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr xxxxxxxxx
interface Ethernet0/0
ip address xxxx.xxx.xxxx.xxx 255.255.255.252
keepalive 4
half-duplex
interface Serial0/0
description NOT IN USE |||||||
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Serial1/0:15
description VOIP||ISDN|Y||||||| See E1 Controller for details
no ip address
no logging event link-status
no snmp trap link-status
isdn incoming-voice voice
isdn T309-enable
fair-queue 64 256 0
no cdp enable
router eigrp 4278
network 143.26.0.0
no auto-summary
eigrp log-neighbor-changes
ip classless
no ip http server
ip pim bidir-enable
voice-port 1/0:15
echo-cancel coverage 32
dial-peer cor custom
dial-peer voice 9999 pots
destination-pattern 9663812....
direct-inward-dial
forward-digits all
dial-peer voice 6666 pots
dial-peer voice 575 pots
destination-pattern 575....
direct-inward-dial
port 1/0:15
line con 0
exec-timeout 0 0
password xxxxxx
line aux 0
exec-timeout 0 0
password xxxxxx
line vty 0 4
exec-timeout 0 0
password xxxxxx
login
end
  • Other Network Infrastructure Subjects
Silver
Re: ISDN D-channel Layer 2 Problem !!
Have you considered that your channel 15 is not defined in your time slots in the E1 controllers config ?
Does the ISDN card on the PBX, supports data calls to be placed. Most probably, the switch (PBX) is configured only for voice calls. Check the PBX setting.
May be you should try
conf t
int s1/0/:15
isdn protocol-emulate network
regards
Farid
245
