ISDN DIALIN and MSCHAP client
giuliano
HI all.
I use an ISDN cisco for dialing in ms win98 remote access client with chap
as authenticate.
All works correctly, i assign dinamically the ip to all clients that connect,
but the clients does not take the correct default route to my isdn router.
Why this? I have to specify a parameter on the router?
Thanks.
thisisshanky
Level 11
Level 11
Are the IP addresses correctly being acquired by the PCs? What does an "ipconfig" command (in dos) reveal the default gateway to be on the PCs once the dialing is complete ? You can additionally use a "route print" to see the default route in the local routing table of the PC.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
tepatel
No special config required on the router. If the ip address is negotiated correctly, both router and client will install host route for eachother. So on client. the ip address and default gateway allocated will be the same ip for PPP connection.
On the router, "sh ip route" should show host route with 32 bit mask for the dialin cleint. Pl. Verify that.
