ISDN Dialout on 3662 (Not DDR) using PRI
I have a 3662 with 2 pri's currently running aaa authentication to a TACACS+ server for vpn, async dialin and async dialout. all are currently working fine. The async dialout is using the Tactical Software Dialout/EZ with 48 port license.
I still have 1 ISDN dialout user that I need to move over to this cisco. This remote site is one our vendors, not a connection I want to be net to net. I do not want to use Dial on Demand Routing (Interesting Traffic) for this.
Is the Tactical Software Dialout/EZ only for async calls or can it be used for ISDN dialout calls too.?
Thanks in advance!
Greg Floyd
1 REPLY
Re: ISDN Dialout on 3662 (Not DDR) using PRI
No...dialout/EZ is for Async dialout calls only.. You can't use it for isdn calls..If you need to use the dialout on that isdn line, you need to use the DDR..Tejal
224
