ISDN dialup through PRI and BRI
The scenario is as follows.
HO(head office) will have 1 isdn PRI no. and 1 isdn BRI no (spare in case of ISDN Pri
down). The PRI is attached to Cisco 7206 whereas the ISDN bri will reside on a Cisco2600 router in HO LAN. There are actually two routers at HO.
Stores will have 1 isdn BRI no.
Can Stores call HO using these two ISDN numbers. Stores will call the Pri
no. as the main line and Bri as the backup line in case the Pri does not
respond.
Can i add the the additional command? Will it work? How is the precedence
set?
Store ISDN config is as follows
interface Dialer1
bandwidth 64
ip address 172.16.1.2 255.255.255.252
encapsulation ppp
ip tcp header-compression iphc-format
no ip mroute-cache
dialer pool 1
dialer remote-name HQ
dialer string 77184094 (Pri no)
dialer string xxxxxxx (Bri no)
dialer-group 1
ppp authentication chap
ppp multilink
ppp multilink fragment-delay 10
ppp multilink interleave
ip rtp header-compression iphc-format
ip rtp priority 16384 16383 48
Ip route 0.0.0.0 0.0.0.0 dialer 1 180
Thanks.
Delon
1 REPLY
Silver
Re: ISDN dialup through PRI and BRI
Based on the availability of the PRI or ISDN the config will function, And it will not be a true backup for PRI line. Supose when the Stores ISDN line dials and the one of the PRI line which it dials was busy, it will try the next string in the interface dilaer configurattion and gets established if the ISDN line in the CO is free. Hence it will not be a true backup for the PRI for the purpose of breakdown.
93
