10-02-2003 06:21 AM - edited 03-02-2019 10:44 AM
Config
Current configuration : 3528 bytes
version 12.2
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
hostname ************
logging buffered 4096 debugging
logging monitor notifications
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication login no_tacacs enable
aaa authentication ppp default local
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
enable secret 5 ************
username 02 password 7 ************
username ************ password 7 ************
clock timezone PST -8
clock summer-time EST recurring
ip subnet-zero
no ip domain-lookup
ip ssh time-out 120
ip ssh authentication-retries 3
crypto mib ipsec flowmib history tunnel size 200
crypto mib ipsec flowmib history failure size 200
isdn switch-type basic-ni
interface Loopback0
ip address 172.18.40.1 255.255.255.192
interface Ethernet0/0
ip address 172.18.40.65 255.255.255.192
half-duplex
interface Serial0/0
no ip address
no fair-queue
interface BRI0/0
ip address 192.168.252.254 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer map ip 192.168.252.253 name 02 19998887776
dialer map ip 192.168.252.253 name 02 19998887777
dialer load-threshold 5 either
dialer-group 1
isdn spid1 1
isdn spid2 2
no fair-queue
no cdp enable
ppp multilink
interface Serial0/1
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/1.1 point-to-point
bandwidth 128
ip address 192.168.50.182 255.255.255.252
no ip route-cache
no ip mroute-cache
frame-relay class cir64/port128
frame-relay interface-dlci 110
router eigrp 228
network 172.18.0.0
network 192.168.50.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.50.181
ip route 0.0.0.0 0.0.0.0 192.168.252.253 220
no ip http server
no ip pim bidir-enable
map-class frame-relay cir64/port128
frame-relay cir 128000
frame-relay bc 16000
frame-relay mincir 64000
frame-relay adaptive-shaping becn
logging 172.18.16.49
access-list 100 deny eigrp any any
access-list 100 permit ip any any
access-list 101 permit ip any any
access-list 101 permit eigrp any any
dialer-list 1 protocol ip list 100
snmp-server community *********
snmp-server manager
tacacs-server host 172.18.16.49 key *********
tacacs-server host 172.18.16.25 key *********
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
login authentication no_tacacs
line aux 0
modem Dialin
transport input all
line vty 0 4
session-timeout 60
exec-timeout 60 0
line vty 5
no scheduler allocate
ntp clock-period 17208447
ntp server 172.18.16.1
end
ISDN Status:
Global ISDN Switchtype = basic-ni
ISDN BRI0/0 interface
dsl 0, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 107, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 107, ces = 1, state = 5(init)
spid1 configured, no LDN, spid1 sent, spid1 valid
Endpoint ID Info: epsf = 0, usid = 70, tid = 1
TEI Not Assigned, ces = 2, state = 3(await establishment)
spid2 configured, no LDN, spid2 NOT sent, spid2 NOT valid
Layer 3 Status:
1 Active Layer 3 Call(s)
CCB:callid=0, sapi=0, ces=2, B-chan=0, calltype=INTERNAL
CCB:callid=C, sapi=0, ces=1, B-chan=1, calltype=DATA
Active dsl 0 CCBs = 2
The Free Channel Mask: 0x80000002
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 2
ISDN History:
ISDN CALL HISTORY
Call History contains all active calls, and a maximum of 100 inactive calls.
Inactive call data will be retained for a maximum of 15 minutes.
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
In (spid 1 ac) (spid1) +.7b62.c62e 100
In (spid 1 ac) (spid1) +.7b62.c62e 96
So, it keeps dialing over and over again.
I don't understand though.. I've marked eigrp as uninteresting, and yet it keeps dialing, when there's not supposed to be any traffic. ALl traffic should be routing through the serial link, and when it goes down, it should use the backup ISDN.
Any idea? It should just establish layer 2, but not try to establish layer 3 until a call is made.
Solved! Go to Solution.
10-02-2003 10:45 AM
If you do not wish to RX calls on this line , and if it is backup there is really no need to recerive calls , you can configure the command under the BRI
isdn reject data
isdn reject voice
10-02-2003 06:31 AM
Try adding passive-interface bri0 under the router eigrp process.
Also, I could be wrong but the output of your show isdn call shows the calls as "in". Could you the other router be calling up this router?
10-02-2003 06:41 AM
I tried making bri0 passive already.
the number showing up on the show isdn history is the number of spid 1, and the first part is the area code, preceeded by the number (1).
I find that strange too.
But, the router on the other side has an entirely different spid.
So in other words, it's as if the router is dialing it's own spid...
10-02-2003 06:31 AM
ok to fix the problem with the router keeps dialing
your acl 100 needs to be fine tuned
access-list 100 deny eigrp any any (this is good)good
After your permit place the 'log' keyword
access-list 100 permit ip any any log
This will give you Source & dest ip addresses as well as port #'s , once you get this info you can determine what is placing calls.
You also have a problem with Spid 2 the switch is not recognizing the spids the router is advertising you can teel this by
you are not getting TEI from the switch , Open a ticket with the provider .
the valid state for spids are init and established all other states are not valid you will not be able to place a call
10-02-2003 06:44 AM
The spids, prior, said state 5=(init), but the router still kept dialing... I interpret this as "initializing". ISDN calls were still successful, but I wanted to ensure that we weren't incuring any additional charges, as this was a problem in the past.
So, I removed the spids, re-inserted them and reloaded. Now it says SPID Not valid.. but I'm going to try and put the second one in again.
10-02-2003 06:47 AM
place the log statement at the end of the permit in acl 100 this will tell you who is dialing
10-02-2003 06:57 AM
I put the new ACL and Passive-interface on bri0/0,
but all I'm seeing is this...
Oct 2 07:53:39: %LINK-3-UPDOWN: Interface BRI0/0:1, changed state to up
Oct 2 07:53:40: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Oct 2 07:53:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0:1, chang
ed state to up
Oct 2 07:53:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1
Oct 2 07:53:45: %ISDN-6-CONNECT: Interface BRI0/0:1 is now connected to 1775 00
c0.7b62.c62e
Oct 2 07:55:21: %ISDN-6-DISCONNECT: Interface BRI0/0:1 disconnected from 1775
00c0.7b62.c62e, call lasted 102 seconds
Oct 2 07:55:21: %LINK-3-UPDOWN: Interface BRI0/0:1, changed state to down
Oct 2 07:55:21: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to dow
n
Oct 2 07:55:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0:1, chang
ed state to down
Oct 2 07:55:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1
10-02-2003 07:10 AM
I think the box on the remote side is calling you can you do the same thing there and see what you see
10-02-2003 07:18 AM
SHow isdn history on the remote side reveals that no calls have been made...
in the show ISDN status, did you notice this??
Layer 3 Status:
CALLtype=INTERNAL ???
that's odd, don't you think?
10-02-2003 07:21 AM
It only keeps the info for 15 minutes configure the log statment and wait for the next call
10-02-2003 07:35 AM
Ok, this is strange.. here's the config of the int on the other side..
interface BRI1/0
ip address 192.168.252.253 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer-group 1
isdn spid1 19330042000101
isdn spid2 19340042000101
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
it's not configured to dial!
but, here's what the log says: (I did a clear log before I did a show log, what's up with the time/date stamp?)
17w1d: ISDN BR1/0: TX -> RRp sapi = 0 tei = 64 nr = 5
17w1d: ISDN BR1/0: RX <- RRp sapi = 0 tei = 64 nr = 5
17w1d: ISDN BR1/0: TX -> RRf sapi = 0 tei = 64 nr = 5
17w1d: ISDN BR1/0: RX <- RRf sapi = 0 tei = 64 nr = 5
17w1d: ISDN BR1/0: RX <- RRp sapi = 0 tei = 65 nr = 1
17w1d: ISDN BR1/0: TX -> RRf sapi = 0 tei = 65 nr = 1
17w1d: ISDN BR1/0: TX -> RRp sapi = 0 tei = 65 nr = 1
17w1d: ISDN BR1/0: RX <- RRf sapi = 0 tei = 65 nr = 1
17w1d: %SEC-6-IPACCESSLOGDP: list 100 permitted icmp 172.18.89.188 -> 172.18.40.
128 (0/0), 1 packet
229 (0/0), 1 packet
10-02-2003 07:42 AM
Is there on openview box or some kind on network managements server 172.18.89.188 ?
10-02-2003 07:57 AM
No, I think that's actually a welchia-infected machine. I blocked ICMP.. same deal.
Here's the config on the other side
Current configuration : 3734 bytes
version 12.2
no parser cache
service config
no service single-slot-reload-enable
service timestamps log uptime
no service dhcp
boot system slot0:c3640-i-mz.122-2.t.bin
logging buffered 10000 debugging
logging rate-limit console 10 except errors
clock timezone EST -5
ip subnet-zero
no ip dhcp-client network-discovery
interface BRI1/0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer-group 1
isdn spid1 1 1
isdn spid2 1 2
no fair-queue
no cdp enable
ppp multilink
router eigrp 228
timers active-time 6
passive-interface BRI1/1
network 148.189.0.0
network 172.18.0.0
no auto-summary
10-03-2003 07:23 AM
Your passive interface statement is pointing at the wrong interface:
interface BRI1/0
router eigrp 228
10-02-2003 07:56 AM
add
to your config to change the date/time stamps from router uptime to local date/time.
Also do a debug dialer events on both routers. This will tell dialing causes.
