ISDN Error: Illegal Interface BR0:1
spremkumar
Level 9
Level 9
hi
can someone tellme y i m getting this error while trying to connect to my ISP ?
its a working config and started behavin like this since ydy.
2d19h: %DIALER-6-BIND: Interface BRI0:1 bound to profile BRI0
2d19h: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 24325585
2d19h: BR0:1 PPP: Treating connection as a callout
2d19h: BR0:1 PPP: Phase is ESTABLISHING, Active Open
2d19h: BR0:1 LCP: O CONFREQ [Closed] id 231 len 26
2d19h: BR0:1 LCP: MagicNumber 0x1A6DB94B (0x05061A6DB94B)
2d19h: BR0:1 LCP: MRRU 1524 (0x110405F4)
2d19h: BR0:1 LCP: EndpointDisc 1 Local (0x130C016164696461736D756D)
2d19h: ISDN BR0: Event: Connected to 24325585 on B1 at 64 Kb/s
2d19h: ISDN Error: Illegal Interface BR0:1
2d19h: BR0:1 LCP: TIMEout: State REQsent
thx in adv
prem
Hello Prem,
your trace shows only outbound LCP CONFREQ messages and no inbound messages. This could be caused by an ISDN speed mismatch. Possibly your local or remote circuit does not support the 64K default speed.
Try to configure a map class (for dialer profiles), or adjust your dialer map statement (for legacy DDR) on both sides of the circuit.
Here is an example from CCO on how to configure this:
For Dialer Profiles:
maui-soho-01(config)#interface Dialer1
maui-soho-01(config-if)#dialer string 81560 class 56k! -- Dial 81560 and use the map-class named "56k" (defined below)
maui-soho-01(config-if)#exit
maui-soho-01(config)#map-class dialer 56k! -- map-class named "56k" that was used with the dialer string in int Dialer1maui-soho-01(config-map-clas)#dialer isdn speed 56! -- Set the speed of the call to be 56k (default is 64k)
For Legacy DDR (dialer maps):
maui-soho-01(config)#interface bri 0
maui-soho-01(config-if)#dialer map ip 10.1.1.1 name maui-nas-08 speed 56 81560
!-- The keyword speed 56 sets the outgoing call rate at 56k
Also, check if all interfaces (physical and dialer) are configured for ppp encapsulation.
Georg Pauwen
hi
to hve clear picture i hve attached the config here.
one channel is used for internet and the second channel is being used for vpn.
interface Tunnel0
ip address 10.1.1.6 255.255.255.252
no ip directed-broadcast
tunnel source x.x.x.x
tunnel destination y.y.y.y
interface Ethernet0
ip accounting output-packets
ip nat inside
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
ppp multilink
interface Dialer0
ip address negotiated
ip access-group 177 in
ip access-group 178 out
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 900
dialer wait-for-carrier-time 10000
dialer string 12345678
dialer-group 1
ppp authentication pap callin
ppp pap sent-username yyyyyy password yyyyyyyy
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username ddddddd password ddddddd
ip nat inside source list 1 interface Dialer0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.3.0 255.255.255.0 Tunnel0
ip route 192.168.4.0 255.255.255.0 Tunnel0
ip route 10.2.1.0 255.255.255.0 Dialer1
access-list 1 permit 192.168.1.0 0.0.0.255
prem
Hello Prem,
take the ppp multilink out of the physical BRI configuration, or leave it in and add it to your dialers as well.
Georg
