ISDN Fire Up 2nd Channel
fkseow
I have a 2610 router which has a BRI port as a bakup link that physically connected a S/T port of the NT1 box (There is a free S/T port & BRI - 2B Channel (64K) and 1 B Channel). - Each channel gives 64k bps.
Anyone know how do I configure my router 2610 in order to fire up the second channel (i.e. total Bandwidth -128Kbps) whenever the bandwidth requirement is more 64 Kbps ?
Any configuration sample ? Please guide.
tepatel
Here is the place which discuss that for you..You need to use the command "dialer load-threshold xxx" command for that to define the load on first b channel before it can bring up the second b channel..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios11/arbook/arddr.htm#xtocid2225318
