06-27-2002 06:50 PM - edited 03-01-2019 11:07 PM
----Head Office COnfig--------
hostname 010_RO_01
enable secret 5 <removed>
enable password 7 <removed>
username 011_RO_01 password 7 <removed>
username 012_RO_01 password 7 <removed>
username 013_RO_01 password 7 <removed>
username 040_RO_01 password 7 <removed>
username 030_RO_01 password 7 <removed>
username 050_RO_01 password 7 <removed>
username 010_RO_02 password 7 <removed>
no ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
isdn voice-call-failure 0
interface FastEthernet0/0
ip address 192.168.10.254 255.255.255.0
no ip directed-broadcast
duplex auto
speed auto
bridge-group 1
interface Serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
bridge-group 1
interface Serial0/0.1 multipoint
ip address 192.168.253.1 255.255.255.0
frame-relay map bridge 80 broadcast
frame-relay map bridge 70 broadcast
frame-relay map bridge 60 broadcast
frame-relay map bridge 50 broadcast
frame-relay map bridge 30 broadcast
frame-relay map bridge 20 broadcast
frame-relay map bridge 40 broadcast
frame-relay map ip 192.168.253.2 60 broadcast
frame-relay map ip 192.168.253.4 50 broadcast
frame-relay map ip 192.168.253.5 40 broadcast
frame-relay map ip 192.168.253.6 20 broadcast
frame-relay map ip 192.168.253.7 30 broadcast
frame-relay map ip 192.168.253.8 70 broadcast
frame-relay map ip 192.168.253.9 80 broadcast
bridge-group 1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface BRI1/0
description Connected from Cikarang Branch using ISDN
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer rotary-group 1
no cdp enable
interface BRI1/1
description Connected from Thamrin Branch using ISDN
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer rotary-group 2
no cdp enable
interface BRI1/2
description Connected from Kota Branch using ISDN
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer rotary-group 3
no cdp enable
interface BRI1/3
description Connected to Bandung using ISDN
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer rotary-group 4
no cdp enable
interface BRI1/4
description Connected to Surabaya Branch usingISDN
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer rotary-group 5
no cdp enable
interface BRI1/5
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface BRI1/6
no ip address
shutdown
interface BRI1/7
no ip address
shutdown
interface Dialer1
ip address 192.168.252.5 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name 013_RO_01 broadcast
dialer map ip 192.168.252.6 name 013_RO_01 broadcast 28600056
dialer hold-queue 10
dialer load-threshold 10 outbound
dialer-group 1
snapshot server 15 dialer
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer2
ip address 192.168.252.25 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name 012_RO_01 broadcast
dialer map ip 192.168.252.26 name 012_RO_01 broadcast 23550106
dialer-group 1
no cdp enable
ppp multilink
interface Dialer3
ip address 192.168.252.9 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name 011_RO_01 broadcast
dialer map ip 192.168.252.10 name 011_RO_01 broadcast 26500071
dialer-group 1
no cdp enable
ppp multilink
interface Dialer4
description Connected from Bandung Branch using ISDN
ip address 192.168.252.13 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name 040_RO_01 broadcast
dialer map ip 192.168.252.14 name 040_RO_01 broadcast 0224250099
dialer-group 1
no cdp enable
ppp multilink
interface Dialer5
description Connected from Surabaya Branch using ISDN
ip address 192.168.252.17 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name 030_RO_01 broadcast
dialer map ip 192.168.252.18 name 030_RO_01 broadcast 0315600119
dialer-group 1
no cdp enable
ppp multilink
router igrp 1
network 192.168.10.0
network 192.168.252.0
network 192.168.253.0
ip classless
ip route 192.168.11.0 255.255.255.0 192.168.252.10 150
ip route 192.168.12.0 255.255.255.0 192.168.252.26 150
ip route 192.168.13.0 255.255.255.0 192.168.252.6 150
ip route 192.168.30.0 255.255.255.0 192.168.252.18 150
ip route 192.168.40.0 255.255.255.0 192.168.252.14 150
ip route 192.168.50.0 255.255.255.0 192.168.252.22 150
no ip http server
access-list 101 deny igrp any any
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
bridge 1 protocol ieee
------RemoteSide COnfig------------
hostname 040_RO_01
boot system flash:c2600-i-mz.120-7.T
username 010_RO_01 password 7 <removed>
ip subnet-zero
no ip domain-lookup
chat-script default ABORT ERROR ABORT BUSY ABORT "NO ANSWER" "" "ATDT\T" TIMEOUT
60 CONNECT \c
ip address 192.168.40.254 255.255.255.0
no ip mroute-cache
speed auto
half-duplex
bridge-group 1
interface Serial0/0
backup delay 1 120
backup interface Dialer1
ip address 192.168.253.5 255.255.255.0
no ip mroute-cache
no fair-queue
frame-relay map ip 192.168.253.1 40 broadcast
bridge-group 1
interface BRI0/0
description Connected to HQ using ISDN
no ip address
encapsulation ppp
no ip mroute-cache
no cdp enable
interface Serial0/1
physical-layer async
description connected to 010_RO_02
no ip address
encapsulation ppp
dialer in-band
async mode dedicated
fair-queue 64 16 0
no cdp enable
interface Dialer1
ip address 192.168.252.14 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map snapshot 1 name 010_RO_01 broadcast 02125530221
dialer map ip 192.168.252.13 name 010_RO_01 broadcast 02125530221
dialer-group 1
snapshot client 15 360 suppress-statechange-update dialer
no cdp enable
ppp multilink
interface Dialer2
ip address 192.168.251.14 255.255.255.252
encapsulation ppp
dialer in-band
dialer-group 1
pulse-time 3
no cdp enable
router igrp 1
network 192.168.40.0
ip classless
ip route 192.168.10.0 255.255.255.0 192.168.252.13 150
ip route 192.168.10.0 255.255.255.0 192.168.251.13 200
no ip http server
Please anyone here help with this configuration. The ISDN won't up although the serial 0/0 at the Head Office "down".
Do I need to configure:
- dialer map snapshot 1 name 010_RO_01 broadcast 02125530221
- snapshot client 15 360 suppress-statechange-update dialer
At the RemoteSide?
Please help :(
Thank You
HATO
06-28-2002 01:01 AM
As we don't know where it fails collect these debugs :
debug dialer
debug isdn q931
debug ppp nego
debug ppp authe
If it is not clear from the debugs, post them here
06-28-2002 01:35 AM
Below is the Debug output:
10:45:16: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.153), 40 bytes, outgoing interesting (list 101)
10:45:16: BRI1/4 DDR: rotor dialout [priority]
10:45:16: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.153)
10:45:16: BRI1/4 DDR: Attempting to dial 0315600119
10:45:16: DDR: Packet queued
10:45:68719476736: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x17
10:45:70886188668: Bearer Capability i = 0x8890
10:45:68719476736: Channel ID i = 0x83
10:45:68719476736: Called Party Number i = 0x80, '0315600119'
10:45:16: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0x97
10:45:16: Channel ID i = 0x89
10:45:24: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0x97
10:45:29: Dialer5 DDR: ip (s=192.168.10.10, d=192.168.30.12), 78 bytes, outgoing interesting (list 101)
10:45:29: DDR: Packet queued
10:45:30: Dialer5 DDR: ip (s=192.168.10.10, d=192.168.30.12), 78 bytes, outgoing interesting (list 101)
10:45:30: DDR: Packet queued
10:45:31: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0x97
10:45:31: Cause i = 0x8090 - Normal call clearing
10:45:133143986176: BRI1/4: wait for isdn carrier timeout, call id=0x8018
10:45:135310713644: DDR: Dialing failed, 4 packets unqueued and discarded
10:45:133143986176: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x17
10:45:135310698108: Cause i = 0x8090 - Normal call clearing
10:45:31: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0x97
10:45:32: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.153), 40 bytes, outgoing interesting (list 101)
10:45:32: BRI1/4 DDR: rotor dialout [priority]
10:45:32: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.153)
10:45:32: BRI1/4 DDR: Attempting to dial 0315600119
10:45:32: DDR: Packet queued
10:45:137438953472: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x18
10:45:139605665404: Bearer Capability i = 0x8890
10:45:137438953472: Channel ID i = 0x83
10:45:137438953472: Called Party Number i = 0x80, '0315600119'
10:45:32: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0x98
10:45:32: Channel ID i = 0x89
10:45:40: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0x98
10:45:44: BRI1/5 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:45:44: BRI1/5 DDR: sending broadcast to default destination -- failed, not connected
10:45:44: BRI1/6 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:45:44: BRI1/6 DDR: sending broadcast to default destination -- failed, not connected
10:45:47: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0x98
10:45:47: Cause i = 0x8090 - Normal call clearing
10:45:201863462912: BRI1/4: wait for isdn carrier timeout, call id=0x8019
10:45:204030190380: DDR: Dialing failed, 1 packets unqueued and discarded
10:45:201863462912: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x18
10:45:204030174844: Cause i = 0x8090 - Normal call clearing
10:45:47: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0x98
10:45:51: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:45:51: BRI1/3 DDR: rotor dialout [priority]
10:45:51: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:45:51: BRI1/3 DDR: Attempting to dial 0224250099
10:45:51: DDR: Packet queued
10:45:219043332096: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/3, TEI 80 changed to up
10:45:219043332096: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x19
10:45:221210044028: Bearer Capability i = 0x8890
10:45:219043332096: Channel ID i = 0x83
10:45:219043332096: Called Party Number i = 0x80, '0224250099'
10:45:51: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0x99
10:45:51: Channel ID i = 0x89
10:45:54: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:45:54: DDR: Packet queued
10:45:244813135872: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/4, TEI 64 changed to down
10:45:59: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0x99
10:46:00: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:46:00: DDR: Packet queued
10:46:04: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.153), 40 bytes, outgoing interesting (list 101)
10:46:04: BRI1/4 DDR: rotor dialout [priority]
10:46:04: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.153)
10:46:04: BRI1/4 DDR: Attempting to dial 0315600119
10:46:04: DDR: Packet queued
10:46:17179869184: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/4, TEI 64 changed to up
10:46:17179869184: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x1A
10:46:19346581116: Bearer Capability i = 0x8890
10:46:17179869184: Channel ID i = 0x83
10:46:17179869184: Called Party Number i = 0x80, '0315600119'
10:46:04: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0x9A
10:46:04: Channel ID i = 0x89
10:46:06: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0x99
10:46:06: Cause i = 0x8090 - Normal call clearing
10:46:25769803776: BRI1/3: wait for isdn carrier timeout, call id=0x801A
10:46:27936531244: DDR: Dialing failed, 3 packets unqueued and discarded
10:46:25769803776: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x19
10:46:27936515708: Cause i = 0x8090 - Normal call clearing
10:46:06: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0x99
10:46:12: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:46:12: BRI1/3 DDR: rotor dialout [priority]
10:46:12: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:46:12: BRI1/3 DDR: Attempting to dial 0224250099
10:46:12: DDR: Packet queued
10:46:51539607552: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x1B
10:46:53706319484: Bearer Capability i = 0x8890
10:46:51539607552: Channel ID i = 0x83
10:46:51539607552: Called Party Number i = 0x80, '0224250099'
10:46:12: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0x9B
10:46:12: Channel ID i = 0x89
10:46:12: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0x9A
10:46:19: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0x9A
10:46:19: Cause i = 0x8090 - Normal call clearing
10:46:81604378624: BRI1/4: wait for isdn carrier timeout, call id=0x801B
10:46:83771106092: DDR: Dialing failed, 1 packets unqueued and discarded
10:46:81604378624: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x1A
10:46:83771090556: Cause i = 0x8090 - Normal call clearing
10:46:19: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0x9A
10:46:20: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0x9B
10:46:27: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0x9B
10:46:27: Cause i = 0x8090 - Normal call clearing
10:46:115964116992: BRI1/3: wait for isdn carrier timeout, call id=0x801C
10:46:118130844460: DDR: Dialing failed, 1 packets unqueued and discarded
10:46:115964116992: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x1B
10:46:118130828924: Cause i = 0x8090 - Normal call clearing
10:46:27: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0x9B
10:46:124554051584: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/4, TEI 64 changed to down
10:46:158913789952: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/3, TEI 80 changed to down
10:46:44: BRI1/5 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:46:44: BRI1/5 DDR: sending broadcast to default destination -- failed, not connected
10:46:44: BRI1/6 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:46:44: BRI1/6 DDR: sending broadcast to default destination -- failed, not connected
10:47:01: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 41 bytes, outgoing interesting (list 101)
10:47:01: BRI1/4 DDR: rotor dialout [priority]
10:47:01: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.151)
10:47:01: BRI1/4 DDR: Attempting to dial 0315600119
10:47:01: DDR: Packet queued
10:47:4294967296: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/4, TEI 64 changed to up
10:47:4294967296: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x1C
10:47:6461679228: Bearer Capability i = 0x8890
10:47:4294967296: Channel ID i = 0x83
10:47:4294967296: Called Party Number i = 0x80, '0315600119'
10:47:01: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0x9C
10:47:01: Channel ID i = 0x89
10:47:02: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 41 bytes, outgoing interesting (list 101)
10:47:02: DDR: Packet queued
10:47:03: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 41 bytes, outgoing interesting (list 101)
10:47:03: DDR: Packet queued
10:47:04: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 41 bytes, outgoing interesting (list 101)
10:47:04: DDR: Packet queued
10:47:05: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 41 bytes, outgoing interesting (list 101)
10:47:05: DDR: Packet queued
10:47:06: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 41 bytes, outgoing interesting (list 101)
10:47:06: DDR: Packet queued
10:47:06: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:07: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:08: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.153), 40 bytes, outgoing interesting (list 101)
10:47:08: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:09: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0x9C
10:47:11: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:16: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:16: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0x9C
10:47:16: Cause i = 0x8090 - Normal call clearing
10:47:68719476736: BRI1/4: wait for isdn carrier timeout, call id=0x801D
10:47:70886204204: DDR: Dialing failed, 10 packets unqueued and discarded
10:47:68719476736: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x1C
10:47:70886188668: Cause i = 0x8090 - Normal call clearing
10:47:16: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0x9C
10:47:21: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:47:21: BRI1/4 DDR: rotor dialout [priority]
10:47:21: BRI1/4 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.30.12)
10:47:21: BRI1/4 DDR: Attempting to dial 0315600119
10:47:21: DDR: Packet queued
10:47:90194313216: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x1D
10:47:92361025148: Bearer Capability i = 0x8890
10:47:90194313216: Channel ID i = 0x83
10:47:90194313216: Called Party Number i = 0x80, '0315600119'
10:47:21: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0x9D
10:47:21: Channel ID i = 0x89
10:47:24: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:47:24: DDR: Packet queued
10:47:27: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:27: DDR: Packet queued
10:47:29: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0x9D
10:47:30: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:47:30: DDR: Packet queued
10:47:34: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:47:34: BRI1/3 DDR: rotor dialout [priority]
10:47:34: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:47:34: BRI1/3 DDR: Attempting to dial 0224250099
10:47:34: DDR: Packet queued
10:47:146028888064: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/3, TEI 80 changed to up
10:47:146028888064: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x1E
10:47:148195599996: Bearer Capability i = 0x8890
10:47:146028888064: Channel ID i = 0x83
10:47:146028888064: Called Party Number i = 0x80, '0224250099'
10:47:34: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0x9E
10:47:34: Channel ID i = 0x89
10:47:36: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0x9D
10:47:36: Cause i = 0x8090 - Normal call clearing
10:47:154618822656: BRI1/4: wait for isdn carrier timeout, call id=0x801E
10:47:156785550124: DDR: Dialing failed, 4 packets unqueued and discarded
10:47:154618822656: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x1D
10:47:156785534588: Cause i = 0x8090 - Normal call clearing
10:47:36: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0x9D
10:47:36: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:47:36: DDR: Packet queued
10:47:37: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:47:37: DDR: Packet queued
10:47:37: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:47:39: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:47:39: DDR: Packet queued
10:47:41: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:47:41: DDR: Packet queued
10:47:42: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:47:42: BRI1/4 DDR: rotor dialout [priority]
10:47:42: BRI1/4 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.30.12)
10:47:42: BRI1/4 DDR: Attempting to dial 0315600119
10:47:42: DDR: Packet queued
10:47:180388626432: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x1F
10:47:182555338364: Bearer Capability i = 0x8890
10:47:180388626432: Channel ID i = 0x83
10:47:180388626432: Called Party Number i = 0x80, '0315600119'
10:47:42: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0x9F
10:47:42: Channel ID i = 0x89
10:47:42: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0x9E
10:47:43: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:47:43: DDR: Packet queued
10:47:44: BRI1/5 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:47:44: BRI1/5 DDR: sending broadcast to default destination -- failed, not connected
10:47:44: BRI1/6 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:47:44: BRI1/6 DDR: sending broadcast to default destination -- failed, not connected
10:47:46: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:47:46: DDR: Packet queued
10:47:48: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:47:48: DDR: Packet queued
10:47:50: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0x9F
10:47:54: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0x9E
10:47:54: Cause i = 0x8090 - Normal call clearing
10:47:231928233984: BRI1/3: wait for isdn carrier timeout, call id=0x801F
10:47:234094961452: DDR: Dialing failed, 9 packets unqueued and discarded
10:47:231928233984: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x1E
10:47:234094945916: Cause i = 0x8090 - Normal call clearing
10:47:54: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0x9E
10:47:55: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:47:55: BRI1/3 DDR: rotor dialout [priority]
10:47:55: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:47:55: BRI1/3 DDR: Attempting to dial 0224250099
10:47:55: DDR: Packet queued
10:47:236223201280: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x20
10:47:238389913212: Bearer Capability i = 0x8890
10:47:236223201280: Channel ID i = 0x83
10:47:236223201280: Called Party Number i = 0x80, '0224250099'
10:47:55: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xA0
10:47:55: Channel ID i = 0x89
10:47:57: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:47:57: DDR: Packet queued
10:47:57: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0x9F
10:47:57: Cause i = 0x8090 - Normal call clearing
10:47:244813135872: BRI1/4: wait for isdn carrier timeout, call id=0x8020
10:47:246979863340: DDR: Dialing failed, 2 packets unqueued and discarded
10:47:244813135872: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x1F
10:47:246979847804: Cause i = 0x8090 - Normal call clearing
10:47:57: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0x9F
10:48:03: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xA0
10:48:30064771072: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/4, TEI 64 changed to down
10:48:10: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xA0
10:48:10: Cause i = 0x8090 - Normal call clearing
10:48:42949672960: BRI1/3: wait for isdn carrier timeout, call id=0x8021
10:48:45116400428: DDR: Dialing failed, 2 packets unqueued and discarded
10:48:42949672960: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x20
10:48:45116384892: Cause i = 0x8090 - Normal call clearing
10:48:10: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xA0
10:48:12: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:12: BRI1/4 DDR: rotor dialout [priority]
10:48:12: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.12)
10:48:12: BRI1/4 DDR: Attempting to dial 0315600119
10:48:12: DDR: Packet queued
10:48:51539607552: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/4, TEI 64 changed to up
10:48:51539607552: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x21
10:48:53706319484: Bearer Capability i = 0x8890
10:48:51539607552: Channel ID i = 0x83
10:48:51539607552: Called Party Number i = 0x80, '0315600119'
10:48:12: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xA1
10:48:12: Channel ID i = 0x89
10:48:13: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:13: DDR: Packet queued
10:48:14: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:14: DDR: Packet queued
10:48:17: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:17: DDR: Packet queued
10:48:18: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:48:18: BRI1/3 DDR: rotor dialout [priority]
10:48:18: BRI1/3 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.40.12)
10:48:18: BRI1/3 DDR: Attempting to dial 0224250099
10:48:18: DDR: Packet queued
10:48:77309411328: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x22
10:48:79476123260: Bearer Capability i = 0x8890
10:48:77309411328: Channel ID i = 0x83
10:48:77309411328: Called Party Number i = 0x80, '0224250099'
10:48:18: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xA2
10:48:18: Channel ID i = 0x89
10:48:20: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xA1
10:48:22: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:22: DDR: Packet queued
10:48:26: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xA2
10:48:27: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xA1
10:48:27: Cause i = 0x8090 - Normal call clearing
10:48:115964116992: BRI1/4: wait for isdn carrier timeout, call id=0x8022
10:48:118130844460: DDR: Dialing failed, 6 packets unqueued and discarded
10:48:115964116992: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x21
10:48:118130828924: Cause i = 0x8090 - Normal call clearing
10:48:27: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xA1
10:48:30: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:48:30: BRI1/4 DDR: rotor dialout [priority]
10:48:30: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.151)
10:48:30: BRI1/4 DDR: Attempting to dial 0315600119
10:48:30: DDR: Packet queued
10:48:128849018880: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x23
10:48:131015730812: Bearer Capability i = 0x8890
10:48:128849018880: Channel ID i = 0x83
10:48:128849018880: Called Party Number i = 0x80, '0315600119'
10:48:30: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xA3
10:48:30: Channel ID i = 0x89
10:48:32: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:32: DDR: Packet queued
10:48:34: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:48:34: DDR: Packet queued
10:48:37: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:48:37: DDR: Packet queued
10:48:37: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xA2
10:48:37: Cause i = 0x8090 - Normal call clearing
10:48:158913789952: BRI1/3: wait for isdn carrier timeout, call id=0x8023
10:48:161080517420: DDR: Dialing failed, 3 packets unqueued and discarded
10:48:158913789952: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x22
10:48:161080501884: Cause i = 0x8090 - Normal call clearing
10:48:37: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xA2
10:48:38: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xA3
010_RO_01#
010_RO_01#
10:48:43: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:48:43: BRI1/3 DDR: rotor dialout [priority]
10:48:43: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:48:43: BRI1/3 DDR: Attempting to dial 0224250099
10:48:43: DDR: Packet queued
10:48:184683593728: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x24
10:48:186850305660: Bearer Capability i = 0x8890
10:48:184683593728: Channel ID i = 0x83
10:48:184683593728: Called Party Number i = 0x80, '0224250099'
10:48:43: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xA4
10:48:43: Channel ID i = 0x89
010_RO_01#
010_RO_01#sh i
10:48:44: BRI1/5 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:48:44: BRI1/5 DDR: sending broadcast to default destination -- failed, not connected
10:48:44: BRI1/6 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:48:44: BRI1/6 DDR: sending broadcast to default destination -- failed, not connected
10:48:45: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xA3
10:48:45: Cause i = 0x8090 - Normal call clearing
10:48:193273528320: BRI1/4: wait for isdn carrier timeout, call id=0x8024
10:48:195440255788: DDR: Dialing failed, 2 packets unqueued and discarded
10:48:193273528320: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x23
10:48:195440240252: Cause i = 0x8090 - Normal call clearing
10:48:45: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xA3
% Ambiguous command: "sh i"
010_RO_01#
010_RO_01#
010_RO_01#
010_RO_01#
010_RO_01#
010_RO_01#
010_RO_01#
010_RO_01#
010_RO_01#sh
10:48:51: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xA4isdn sts
10:48:53: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:48:53: BRI1/4 DDR: rotor dialout [priority]
10:48:53: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.12)
10:48:53: BRI1/4 DDR: Attempting to dial 0315600119
10:48:53: DDR: Packet queued
10:48:227633266688: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x25
10:48:229799978620: Bearer Capability i = 0x8890
10:48:227633266688: Channel ID i = 0x83
10:48:227633266688: Called Party Number i = 0x80, '0315600119'
10:48:53: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xA5
10:48:53: Channel ID i = 0x89
10:48:55: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:48:55: DDR: Packet queuedatud
10:48:58: Dialer4 DDR: ip (s=192.168.10.10, d=192.168.40.12), 362 bytes, outgoing interesting (list 101)
10:48:58: DDR: Packet queued
10:48:58: Dialer5 DDR: ip (s=192.168.10.10, d=192.168.30.12), 362 bytes, outgoing interesting (list 101)
10:48:58: DDR: Packet queued s
Global ISDN Switchtype = basic-net3
ISDN BRI1/0 interface
dsl 8, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 96, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Activated dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
--More--
10:49:00: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:49:00: DDR: Packet queued
10:49:01: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xA5
10:49:02: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xA4
10:49:02: Cause i = 0x8090 - Normal call clearing
10:49:8589934592: BRI1/3: wait for isdn carrier timeout, call id=0x8025
10:49:10756662060: DDR: Dialing failed, 4 packets unqueued and discarded
10:49:8589934592: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x24
10:49:10756646524: Cause i = 0x8090 - Normal call clearing
10:49:02: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xA4
10:49:04: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:49:04: DDR: Packet queued
10:49:07: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:49:07: DDR: Packet queued ISDN BRI1/1 interface
dsl 9, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 80, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Activated dsl 9 CCBs = 0
--More--
10:49:08: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.153), 40 bytes, outgoing interesting (list 101)
10:49:08: DDR: Packet queued
10:49:09: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xA5
10:49:09: Cause i = 0x8090 - Normal call clearing
10:49:38654705664: BRI1/4: wait for isdn carrier timeout, call id=0x8026
10:49:40821433132: DDR: Dialing failed, 5 packets unqueued and discarded
10:49:38654705664: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x25
10:49:40821417596: Cause i = 0x8090 - Normal call clearing
10:49:09: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xA5
10:49:09: Cause i = 0x8090 - Normal call clearing ISDN BRI1/2 interface
dsl 10, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Activated dsl 10 CCBs = 0
--More-- ISDN BRI1/3 interface
dsl 11, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 80, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
Activated dsl 11 CCBs = 1
CCB:callid=8025, sapi=0, ces=1, B-chan=1, calltype=DATA
The Free Channel Mask: 0x80000002
--More--
10:49:55834574848: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/3, TEI 80 changed to down
10:49:13: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:49:13: BRI1/4 DDR: rotor dialout [priority]
10:49:13: BRI1/4 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.30.12)
10:49:13: BRI1/4 DDR: Attempting to dial 0315600119
10:49:13: DDR: Packet queued
10:49:55834574848: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x26
10:49:58001286780: Bearer Capability i = 0x8890
10:49:55834574848: Channel ID i = 0x83
10:49:55834574848: Called Party Number i = 0x80, '0315600119'
10:49:13: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xA6
10:49:13: Channel ID i = 0x89 ISDN BRI1/4 interface
dsl 12, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
Activated dsl 12 CCBs = 1
CCB:callid=8026, sapi=0, ces=1, B-chan=1, calltype=DATA
--More--
10:49:21: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xA6 ISDN BRI1/5 interface
dsl 13, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
Activated dsl 13 CCBs = 0
--More--
10:49:25: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:49:25: DDR: Packet queued
10:49:28: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xA6
10:49:28: Cause i = 0x8090 - Normal call clearing
10:49:120259084288: BRI1/4: wait for isdn carrier timeout, call id=0x8027
10:49:122425811756: DDR: Dialing failed, 2 packets unqueued and discarded
10:49:120259084288: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x26
10:49:122425796220: Cause i = 0x8090 - Normal call clearing
10:49:28: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xA6
10:49:28: Cause i = 0x8090 - Normal call clearing ISDN BRI1/6 interface
dsl 14, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Activated dsl 14 CCBs = 0
--More--
010_RO_01#c
10:49:34: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:49:34: BRI1/3 DDR: rotor dialout [priority]
10:49:34: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:49:34: BRI1/3 DDR: Attempting to dial 0224250099
10:49:34: DDR: Packet queued
10:49:146028888064: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/3, TEI 80 changed to upping
10:49:146028888064: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x27
10:49:148195599996: Bearer Capability i = 0x8890
10:49:146028888064: Channel ID i = 0x83
10:49:146028888064: Called Party Number i = 0x80, '0224250099'
10:49:34: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xA7
10:49:34: Channel ID i = 0x89
10:49:35: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.12), 55 bytes, outgoing interesting (list 101)
10:49:35: BRI1/4 DDR: rotor dialout [priority]
10:49:35: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.12)
10:49:35: BRI1/4 DDR: Attempting to dial 0315600119
10:49:35: DDR: Packet queued
10:49:150323855360: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x28
10:49:152490567292: Bearer Capability i = 0x8890
10:49:150323855360: Channel ID i = 0x83
10:49:150323855360: Called Party Number i = 0x80, '0315600119'
10:49:35: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xA8
10:49:35: Channel ID i = 0x89
10:49:37: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:49:37: DDR: Packet queued192.168.40.
10:49:42: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xA7
10:49:43: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:49:43: DDR: Packet queued
10:49:43: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xA8254
Sending 5, 100-byte ICMP Echos to 192.168.40.254, timeout is 2 seconds:
10:49:44: BRI1/5 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:49:44: BRI1/5 DDR: sending broadcast to default destination -- failed, not connected
10:49:44: BRI1/6 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:49:44: BRI1/6 DDR: sending broadcast to default destination -- failed, not connected
10:49:45: Dialer4 DDR: ip (s=192.168.252.13, d=192.168.40.254), 100 bytes, outgoing interesting (list 101)
10:49:45: DDR: Packet queued.
10:49:47: Dialer4 DDR: ip (s=192.168.252.13, d=192.168.40.254), 100 bytes, outgoing interesting (list 101)
10:49:47: DDR: Packet queued.
10:49:49: Dialer4 DDR: ip (s=192.168.252.13, d=192.168.40.254), 100 bytes, outgoing interesting (list 101)
10:49:49: DDR: Packet queued.
10:49:51: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xA8
10:49:51: Cause i = 0x8090 - Normal call clearing
10:49:219043332096: BRI1/4: wait for isdn carrier timeout, call id=0x8029
10:49:221210059564: DDR: Dialing failed, 1 packets unqueued and discarded
10:49:219043332096: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x28
10:49:221210044028: Cause i = 0x8090 - Normal call clearing
10:49:51: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xA8
10:49:51: Dialer4 DDR: ip (s=192.168.252.13, d=192.168.40.254), 100 bytes, outgoing interesting (list 101)
10:49:51: DDR: Packet queued.
10:49:53: Dialer4 DDR: ip (s=192.168.252.13, d=192.168.40.254), 100 bytes, outgoing interesting (list 101)
10:49:53: DDR: Packet queued
10:49:53: Dialer5 DDR: ip (s=192.168.10.1, d=192.168.30.151), 40 bytes, outgoing interesting (list 101)
10:49:53: BRI1/4 DDR: rotor dialout [priority]
10:49:53: BRI1/4 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.30.151)
10:49:53: BRI1/4 DDR: Attempting to dial 0315600119
10:49:227633266688: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x29
10:49:229799978620: Bearer Capability i = 0x8890
10:49:227633266688: Channel ID i = 0x83
10:49:227633266688: Called Party Number i = 0x80, '0315600119'
10:49:53: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xA9
10:49:53: Channel ID i = 0x89
10:49:54: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xA7
10:49:54: Cause i = 0x8090 - Normal call clearing
10:49:231928233984: BRI1/3: wait for isdn carrier timeout, call id=0x8028
10:49:234094961452: DDR: Dialing failed, 8 packets unqueued and discarded
10:49:231928233984: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x27
10:49:234094945916: Cause i = 0x8090 - Normal call clearing
10:49:54: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xA7
10:49:54: Cause i = 0x8090 - Normal call clearing .
Success rate is 0 percent (0/5)
010_RO_01#
10:49:55: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:49:55: BRI1/3 DDR: rotor dialout [priority]
10:49:55: BRI1/3 DDR: Dialing cause ip (s=192.168.10.109, d=192.168.40.12)
10:49:55: BRI1/3 DDR: Attempting to dial 0224250099
10:49:55: DDR: Packet queued
10:49:236223201280: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x2A
10:49:238389913212: Bearer Capability i = 0x8890
10:49:236223201280: Channel ID i = 0x83
10:49:236223201280: Called Party Number i = 0x80, '0224250099'
10:49:55: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xAA
10:49:55: Channel ID i = 0x89
10:50:02: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xA9
10:50:03: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xAA
10:50:04: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:50:04: DDR: Packet queued
10:50:07: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:50:07: DDR: Packet queued
10:50:09: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xA9
10:50:09: Cause i = 0x8090 - Normal call clearing
10:50:38654705664: BRI1/4: wait for isdn carrier timeout, call id=0x802A
10:50:40821433132: DDR: Dialing failed, 3 packets unqueued and discarded
10:50:38654705664: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x29
10:50:40821417596: Cause i = 0x8090 - Normal call clearing
10:50:09: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xA9
010_RO_01#
10:50:10: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xAA
10:50:10: Cause i = 0x8090 - Normal call clearing
10:50:42949672960: BRI1/3: wait for isdn carrier timeout, call id=0x802B
10:50:45116400428: DDR: Dialing failed, 1 packets unqueued and discarded
10:50:42949672960: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x2A
10:50:45116384892: Cause i = 0x8090 - Normal call clearing
10:50:10: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xAA
10:50:11: Dialer5 DDR: ip (s=192.168.10.193, d=192.168.30.12), 263 bytes, outgoing interesting (list 101)
10:50:11: BRI1/4 DDR: rotor dialout [priority]
10:50:11: BRI1/4 DDR: Dialing cause ip (s=192.168.10.193, d=192.168.30.12)
10:50:11: BRI1/4 DDR: Attempting to dial 0315600119
10:50:11: DDR: Packet queued
10:50:11: Dialer4 DDR: ip (s=192.168.10.193, d=192.168.40.12), 263 bytes, outgoing interesting (list 101)
10:50:11: BRI1/3 DDR: rotor dialout [priority]
10:50:11: BRI1/3 DDR: Dialing cause ip (s=192.168.10.193, d=192.168.40.12)
10:50:11: BRI1/3 DDR: Attempting to dial 0224250099
10:50:47244640256: ISDN BR1/4: TX -> SETUP pd = 8 callref = 0x2B
10:50:49411352188: Bearer Capability i = 0x8890
10:50:47244640256: Channel ID i = 0x83
10:50:47244640256: Called Party Number i = 0x80, '0315600119'
10:50:47244640256: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x2C
10:50:47244640256: Called Party Number i = 0x80, '0224250099'
10:50:11: ISDN BR1/4: RX <- SETUP_ACK pd = 8 callref = 0xAB
10:50:11: Channel ID i = 0x89
10:50:11: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xAC
10:50:13: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:50:13: DDR: Packet queued
10:50:19: ISDN BR1/4: RX <- CALL_PROC pd = 8 callref = 0xAB
10:50:19: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xAC
10:50:23: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.12), 55 bytes, outgoing interesting (list 101)
10:50:23: DDR: Packet queued
10:50:25: Dialer5 DDR: ip (s=192.168.10.109, d=192.168.30.12), 44 bytes, outgoing interesting (list 101)
10:50:25: DDR: Packet queued
10:50:26: ISDN BR1/4: RX <- DISCONNECT pd = 8 callref = 0xAB
10:50:26: Cause i = 0x8090 - Normal call clearing
10:50:111669149696: BRI1/4: wait for isdn carrier timeout, call id=0x802C
10:50:113835877164: DDR: Dialing failed, 3 packets unqueued and discarded
10:50:111669149696: ISDN BR1/4: TX -> RELEASE pd = 8 callref = 0x2B
10:50:113835861628: Cause i = 0x8090 - Normal call clearing
10:50:26: ISDN BR1/4: RX <- RELEASE_COMP pd = 8 callref = 0xAB
10:50:27: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xAC
10:50:27: Cause i = 0x8090 - Normal call clearing
10:50:115964116992: BRI1/3: wait for isdn carrier timeout, call id=0x802D
10:50:118130844460: DDR: Dialing failed, 2 packets unqueued and discarded
10:50:115964116992: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x2C
10:50:118130828924: Cause i = 0x8090 - Normal call clearing
10:50:27: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xAC
10:50:31: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 41 bytes, outgoing interesting (list 101)
10:50:31: BRI1/3 DDR: rotor dialout [priority]
10:50:31: BRI1/3 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.40.150)
10:50:31: BRI1/3 DDR: Attempting to dial 0224250099
10:50:31: DDR: Packet queued
10:50:133143986176: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x2D
10:50:135310698108: Bearer Capability i = 0x8890
10:50:133143986176: Channel ID i = 0x83
10:50:133143986176: Called Party Number i = 0x80, '0224250099'
10:50:31: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xAD
10:50:31: Channel ID i = 0x89
10:50:32: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 41 bytes, outgoing interesting (list 101)
10:50:32: DDR: Packet queued
10:50:33: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 41 bytes, outgoing interesting (list 101)
10:50:33: DDR: Packet queued
10:50:34: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:50:34: DDR: Packet queued
10:50:34: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 41 bytes, outgoing interesting (list 101)
10:50:35: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 41 bytes, outgoing interesting (list 101)
10:50:35: DDR: Packet queued
10:50:36: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 41 bytes, outgoing interesting (list 101)
10:50:36: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 40 bytes, outgoing interesting (list 101)
10:50:158913789952: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/4, TEI 64 changed to down
10:50:37: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 40 bytes, outgoing interesting (list 101)
10:50:37: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:50:37: Dialer4 DDR: ip (s=192.168.10.10, d=192.168.40.12), 40 bytes, outgoing interesting (list 101)
10:50:39: ISDN BR1/3: RX <- CALL_PROC pd = 8 callref = 0xAD
10:50:39: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 40 bytes, outgoing interesting (list 101)
10:50:42: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 40 bytes, outgoing interesting (list 101)
10:50:43: Dialer4 DDR: ip (s=192.168.10.109, d=192.168.40.12), 44 bytes, outgoing interesting (list 101)
10:50:44: BRI1/5 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:50:44: BRI1/5 DDR: sending broadcast to default destination -- failed, not connected
10:50:44: BRI1/6 DDR: cdp, 283 bytes, outgoing uninteresting (no dialer-group defined)
10:50:44: BRI1/6 DDR: sending broadcast to default destination -- failed, not connected
10:50:46: ISDN BR1/3: RX <- DISCONNECT pd = 8 callref = 0xAD
10:50:46: Cause i = 0x8090 - Normal call clearing
10:50:197568495616: BRI1/3: wait for isdn carrier timeout, call id=0x802E
10:50:199735223084: DDR: Dialing failed, 10 packets unqueued and discarded
10:50:197568495616: ISDN BR1/3: TX -> RELEASE pd = 8 callref = 0x2D
10:50:199735207548: Cause i = 0x8090 - Normal call clearing
10:50:46: ISDN BR1/3: RX <- RELEASE_COMP pd = 8 callref = 0xAD
10:50:48: Dialer4 DDR: ip (s=192.168.10.1, d=192.168.40.150), 40 bytes, outgoing interesting (list 101)
10:50:48: BRI1/3 DDR: rotor dialout [priority]
10:50:48: BRI1/3 DDR: Dialing cause ip (s=192.168.10.1, d=192.168.40.150)
10:50:48: BRI1/3 DDR: Attempting to dial 0224250099
10:50:48: DDR: Packet queued
10:50:206158430208: ISDN BR1/3: TX -> SETUP pd = 8 callref = 0x2E
10:50:208325142140: Bearer Capability i = 0x8890
10:50:206158430208: Channel ID i = 0x83
10:50:206158430208: Called Party Number i = 0x80, '0224250099'
10:50:48: ISDN BR1/3: RX <- SETUP_ACK pd = 8 callref = 0xAE
10:50:48: Channel ID i = 0x89
01:03:240518168576: Found idle channel B1
01:03:240518168576: CC_CHAN_GetIdleChanbri: dsl 12
01:03:242684896268: ISDN BR1/0: received HOST_PROCEEDING call_id 0x806D
01:03:240518168576: ISDN BR1/2: received HOST_PROCEEDING call_id 0x806F
01:03:240518168576: ISDN BR1/3: received HOST_INFORMATION call_id 0x8070
01:03:240518168576: ISDN Event: dsl 11 call_id 0x8070 B channel assigned by switch 0
ISDN BR1/4: received HOST_INFORMATION call_id 0x8071
01:03:240518168576: ISDN Event: dsl 12 call_id 0x8071 B channel assigned by switch 0
ISDN BR1/0: received HOST_DISCONNECT call_id 0x806D
01:03:240518168576: ISDN BR1/0: Event: Call to 28600056 was hung up.
01:03:242684896140: ISDN BR1/0: process_disc_ack(): call id 0x806D, ces 1, call type DATA
01:03:242684896520: ISDN BR1/0: received HOST_DISCONNECT_ACK call_id 0x806D
01:03:240518168576: ISDN BR1/0: HOST_DISCONNECT_ACK: call type is DATA
01:03:246979863564: ISDN BR1/2: received HOST_DISCONNECT call_id 0x806F
01:03:244813135872: ISDN BR1/2: Event: Call to 26500071 was hung up.
01:03:246979863436: ISDN BR1/2: process_disc_ack(): call id 0x806F, ces 1, call type DATA
01:03:246979863816: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x806F
01:03:244813135872: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
01:03:244813135872: ISDN BR1/1: Activating
01:03:59: ISDN BR1/0: Outgoing call id = 0x8072, dsl 8
01:03:59: ISDN BR1/2: Outgoing call id = 0x8073, dsl 10
01:03:253403070464: ISDN BR1/1: Could not bring up interface
01:03:255569782516: ISDN BR1/1: Shutting down ISDN Layer 3
01:03:59: ISDN BR1/0: Event: Call to 28600056 at 64 Kb/s
01:03:59: ISDN BR1/0: process_bri_call(): call id 0x8072, called_number 28600056, speed 64, call type DATA
01:03:59: ISDN BR1/2: Event: Call to 26500071 at 64 Kb/s
01:03:59: ISDN BR1/2: process_bri_call(): call id 0x8073, called_number 26500071, speed 64, call type DATA
01:03:253403070464: CC_CHAN_GetIdleChanbri: dsl 8
01:03:253403070464: Found idle channel B1
01:03:253403070464: CC_CHAN_GetIdleChanbri: dsl 10
01:03:255569798156: ISDN BR1/0: received HOST_PROCEEDING call_id 0x8072
01:03:253403070464: ISDN BR1/2: received HOST_PROCEEDING call_id 0x8073
01:03:253403070464: ISDN BR1/0: received HOST_DISCONNECT call_id 0x8072
01:03:253403070464: ISDN BR1/0: Event: Call to 28600056 was hung up.
01:03:255569798028: ISDN BR1/0: process_disc_ack(): call id 0x8072, ces 1, call type DATA
01:03:255569798408: ISDN BR1/0: received HOST_DISCONNECT_ACK call_id 0x8072
01:03:253403070464: ISDN BR1/0: HOST_DISCONNECT_ACK: call type is DATA
01:03:255569798156: ISDN BR1/2: received HOST_DISCONNECT call_id 0x8073
01:03:253403070464: ISDN BR1/2: Event: Call to 26500071 was hung up.
01:03:255569798028: ISDN BR1/2: process_disc_ack(): call id 0x8073, ces 1, call type DATA
01:04:2166727944: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x8073
01:04:00: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
01:04:01: ISDN BR1/1: L1 persistent Deactivated
01:04:02: ISDN BR1/0: Outgoing call id = 0x8074, dsl 8
01:04:02: ISDN BR1/1: Outgoing call id = 0x8075, dsl 9
01:04:02: ISDN BR1/2: Outgoing call id = 0x8076, dsl 10
01:04:02: ISDN BR1/0: Event: Call to 28600056 at 64 Kb/s
01:04:02: ISDN BR1/0: process_bri_call(): call id 0x8074, called_number 28600056, speed 64, call type DATA
01:04:02: ISDN BR1/1: Event: Call to 23550106 at 64 Kb/s
01:04:02: ISDN BR1/1: process_bri_call(): call id 0x8075, called_number 23550106, speed 64, call type DATA
01:04:02: ISDN BR1/2: Event: Call to 26500071 at 64 Kb/s
01:04:02: ISDN BR1/2: process_bri_call(): call id 0x8076, called_number 26500071, speed 64, call type DATA
01:04:8589934592: CC_CHAN_GetIdleChanbri: dsl 8
01:04:8589934592: Found idle channel B1
01:04:8589934592: CC_CHAN_GetIdleChanbri: dsl 9
01:04:8589934592: CC_CHAN_GetIdleChanbri: dsl 10
01:04:8589934592: ISDN BR1/1: Activating
01:04:8589934592: ISDN BR1/1: Could not bring up interface
01:04:10756646644: ISDN BR1/1: Shutting down ISDN Layer 3
01:04:10756662284: ISDN BR1/0: received HOST_PROCEEDING call_id 0x8074
01:04:8589934592: ISDN BR1/2: received HOST_PROCEEDING call_id 0x8076
01:04:8589934592: ISDN BR1/0: received HOST_DISCONNECT call_id 0x8074
01:04:8589934592: ISDN BR1/0: Event: Call to 28600056 was hung up.
01:04:10756662156: ISDN BR1/0: process_disc_ack(): call id 0x8074, ces 1, call type DATA
01:04:10756662536: ISDN BR1/0: received HOST_DISCONNECT_ACK call_id 0x8074
01:04:8589934592: ISDN BR1/0: HOST_DISCONNECT_ACK: call type is DATA
01:04:15051629580: ISDN BR1/2: received HOST_DISCONNECT call_id 0x8076
01:04:12884901888: ISDN BR1/2: Event: Call to 26500071 was hung up.
01:04:15051629452: ISDN BR1/2: process_disc_ack(): call id 0x8076, ces 1, call type DATA
01:04:15051629832: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x8076
01:04:12884901888: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
01:04:17179869184: ISDN BR1/1: Activating
01:04:17179869184: ISDN BR1/1: Could not bring up interface
01:04:19346581236: ISDN BR1/1: Shutting down ISDN Layer 3
01:04:19346596876: ISDN BR1/3: received HOST_PROCEEDING call_id 0x8070
01:04:17179869184: B-channel assigned in previous message call id = 0x8070
01:04:19346596876: ISDN BR1/4: received HOST_PROCEEDING call_id 0x8071
01:04:17179869184: B-channel assigned in previous message call id = 0x8071
01:04:05: ISDN BR1/0: Outgoing call id = 0x8077, dsl 8
01:04:05: ISDN BR1/1: Outgoing call id = 0x8078, dsl 9
01:04:05: ISDN BR1/2: Outgoing call id = 0x8079, dsl 10
01:04:05: ISDN BR1/0: Event: Call to 28600056 at 64 Kb/s
01:04:05: ISDN BR1/0: process_bri_call(): call id 0x8077, called_number 28600056, speed 64, call type DATA
01:04:05: ISDN BR1/1: Event: Call to 23550106 at 64 Kb/s
01:04:05: ISDN BR1/1: process_bri_call(): call id 0x8078, called_number 23550106, speed 64, call type DATA
01:04:05: ISDN BR1/2: Event: Call to 26500071 at 64 Kb/s
01:04:05: ISDN BR1/2: process_bri_call(): call id 0x8079, called_number 26500071, speed 64, call type DATA
01:04:21474836480: CC_CHAN_GetIdleChanbri: dsl 8
01:04:21474836480: Found idle channel B1
01:04:21474836480: CC_CHAN_GetIdleChanbri: dsl 9
01:04:21474836480: CC_CHAN_GetIdleChanbri: dsl 10
01:04:23641564172: ISDN BR1/0: received HOST_PROCEEDING call_id 0x8077
01:04:21474836480: ISDN BR1/2: received HOST_PROCEEDING call_id 0x8079
01:04:21474836480: ISDN BR1/0: received HOST_DISCONNECT call_id 0x8077
01:04:21474836480: ISDN BR1/0: Event: Call to 28600056 was hung up.
01:04:23641564044: ISDN BR1/0: process_disc_ack(): call id 0x8077, ces 1, call type DATA
01:04:23641564424: ISDN BR1/0: received HOST_DISCONNECT_ACK call_id 0x8077
01:04:21474836480: ISDN BR1/0: HOST_DISCONNECT_ACK: call type is DATA
01:04:27936531468: ISDN BR1/2: received HOST_DISCONNECT call_id 0x8079
01:04:25769803776: ISDN BR1/2: Event: Call to 26500071 was hung up.
01:04:27936531340: ISDN BR1/2: process_disc_ack(): call id 0x8079, ces 1, call type DATA
01:04:25769803776: ISDN BR1/1: Activating
01:04:25769803776: ISDN BR1/1: Could not bring up interface
01:04:27936515828: ISDN BR1/1: Shutting down ISDN Layer 3
01:04:27936531720: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x8079
01:04:25769803776: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
01:04:08: ISDN BR1/0: Outgoing call id = 0x807A, dsl 8
01:04:08: ISDN BR1/1: Outgoing call id = 0x807B, dsl 9
01:04:08: ISDN BR1/2: Outgoing call id = 0x807C, dsl 10
01:04:08: ISDN BR1/0: Event: Call to 28600056 at 64 Kb/s
01:04:08: ISDN BR1/0: process_bri_call(): call id 0x807A, called_number 28600056, speed 64, call type DATA
01:04:08: ISDN BR1/1: Event: Call to 23550106 at 64 Kb/s
01:04:08: ISDN BR1/1: process_bri_call(): call id 0x807B, called_number 23550106, speed 64, call type DATA
01:04:08: ISDN BR1/2: Event: Call to 26500071 at 64 Kb/s
01:04:08: ISDN BR1/2: process_bri_call(): call id 0x807C, called_number 26500071, speed 64, call type DATA
01:04:34359738368: CC_CHAN_GetIdleChanbri: dsl 8
01:04:34359738368: Found idle channel B1
01:04:34359738368: CC_CHAN_GetIdleChanbri: dsl 9
01:04:34359738368: CC_CHAN_GetIdleChanbri: dsl 10
01:04:34359738368: ISDN BR1/1: Activating
01:04:34359738368: ISDN BR1/1: Could not bring up interface
01:04:36526450420: ISDN BR1/1: Shutting down ISDN Layer 3
01:04:36526466060: ISDN BR1/0: received HOST_PROCEEDING call_id 0x807A
01:04:34359738368: ISDN BR1/2: received HOST_PROCEEDING call_id 0x807C
01:04:34359738368: ISDN BR1/0: received HOST_DISCONNECT call_id 0x807A
01:04:34359738368: ISDN BR1/0: Event: Call to 28600056 was hung up.
01:04:36526465932: ISDN BR1/0: process_disc_ack(): call id 0x807A, ces 1, call type DATA
01:04:36526466312: ISDN BR1/0: received HOST_DISCONNECT_ACK call_id 0x807A
01:04:34359738368: ISDN BR1/0: HOST_DISCONNECT_ACK: call type is DATA
01:04:40821433356: ISDN BR1/2: received HOST_DISCONNECT call_id 0x807C
01:04:38654705664: ISDN BR1/2: Event: Call to 26500071 was hung up.
01:04:40821433228: ISDN BR1/2: process_disc_ack(): call id 0x807C, ces 1, call type DATA
01:04:40821433608: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x807C
01:04:38654705664: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
01:04:42949672960: ISDN BR1/1: Activating
01:04:47244640255: ISDN BR1/1: Physical layer is IF_DOWN
01:04:43016808092: ISDN BR1/1: Could not bring up interface
01:04:45116385012: ISDN BR1/1: Shutting down ISDN Layer 3
01:04:42949672960: ISDN BR1/1: Shutting down ME
01:04:42949672960: ISDN BR1/1: Shutting down ISDN Layer 3
01:04:49411367948: ISDN BR1/4: received HOST_DISCONNECT call_id 0x8071
01:04:47244640256: ISDN BR1/4: Event: Call to 0315600119 was hung up.
01:04:49411367820: ISDN BR1/4: process_disc_ack(): call id 0x8071, ces 1, call type DATA
01:04:49411368200: ISDN BR1/4: received HOST_DISCONNECT_ACK call_id 0x8071
01:04:47244640256: ISDN BR1/4: HOST_DISCONNECT_ACK: call type is DATA
01:04:49411367948: ISDN BR1/3: received HOST_DISCONNECT call_id 0x8070
01:04:47244640256: ISDN BR1/3: Event: Call to 0224250099 was hung up.
01:04:49411367820: ISDN BR1/3: process_disc_ack(): call id 0x8070, ces 1, call type DATA
01:04:49411368200: ISDN BR1/3: received HOST_DISCONNECT_ACK call_id 0x8070
01:04:47244640256: ISDN BR1/3: HOST_DISCONNECT_ACK: call type is DATA
01:04:83771081876: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 96 changed to down
01:04:81604378624: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/2, TEI 96 changed to down
01:04:90194313216: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/4, TEI 96 changed to down
01:04:90194313216: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/3, TEI 96 changed to down
01:04:40: ISDN BR1/0: Physical layer is IF_DOWN
01:04:171798691840: ISDN BR1/0: Shutting down ME
01:04:171798691840: ISDN BR1/0: Shutting down ISDN Layer 3
01:04:40: ISDN BR1/2: Physical layer is IF_DOWN
01:04:171798691840: ISDN BR1/2: Shutting down ME
01:04:171798691840: ISDN BR1/2: Shutting down ISDN Layer 3
01:04:42: ISDN BR1/4: Physical layer is IF_DOWN
01:04:180388626432: ISDN BR1/4: Shutting down ME
01:04:180388626432: ISDN BR1/4: Shutting down ISDN Layer 3
01:04:42: ISDN BR1/3: Physical layer is IF_DOWN
01:04:180388626432: ISDN BR1/3: Shutting down ME
01:04:180388626432: ISDN BR1/3: Shutting down ISDN Layer 3
Thank You
HATO
