Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ISDN Help Needed!
I have 2 router connected with Frame Relay, both of the router using ISDN as backup. Central Site configured as snapshot server, and the remote site configured as client. When the Frame Relay "Down" the ISDN "Up". I already using debug and has check all the ISDN phase. It's connected normally succesed. But when I try to ping the remote site router (from the remote site--->ping it self interface ip address) and I cannot ping to the Central Site. I've got this messages:
012_RO_01#ping 192.168.252.26
Sending 5, 100-byte ICMP Echos to 192.168.252.26, timeout is 2 seconds:
4d05h: Dialer1 DDR: ip (s=192.168.252.26, d=192.168.252.26), 100 bytes, outgoing interesting (list 101).
Success rate is 0 percent (0/5)
Quest:
1. Why I cannot ping my own interface.
2. When the Central Site ping the Remote Site then the connection becomes OK (well establish--> the remote router becomes can ping to the central)
Thank You.
Best Regards,
HATO
1 REPLY
Silver
Re: ISDN Help Needed!
Get your configs ready and open a case with tac. Without looking through those and running debugs, it's difficult to see where the problem is.
80
