11-06-2002 12:53 AM - edited 03-02-2019 02:40 AM
I have three sites; Sites A, B & C. Sites B and C both have the a Cisco 1720 with a BRI port (one 128K ISDN link attached) will respectively dial to Site A which has a 2620 router with two BRI ports as required.
Site A:
Loopback0 - 10.10.68.1
E0/0 - 10.10.69.1
Bri0/0 - no ip address
Bri0/1 - no ip address
L1--> RouterA(config)#username RouterB password 0 ciscoisdn
L2--> RouterA(config)#username RouterC password 0 ciscoisdn
L3--> RouterA(config)#int bri0/0
L4--> RouterA(config-if)#dialer pool-member 1
L5--> RouterA(config-if)#int dialer1
L6--> RouterA(config-if)#dialer pool 1
L7--> RouterA(config)#int bri0/1
L8--> RouterA(config-if)#dialer pool-member 2
L9--> RouterA(config-if)#int dialer2
L10--> RouterA(config-if)#dialer pool 2
L11--> RouterA(config)#ip route 10.10.18.1 255.255.255.255 dialer1
L12--> RouterA(config)#ip route 10.10.23.1 255.255.255.255 dialer2
Q1. Are L1 & L2 necessary for RouterB and RouterC to dial in (Using PPP authentication) ?
Q2. Are L11 & L12 routing correctly ?
Site B:
Loopback0 - 10.10.18.1
E0/0 - 10.10.19.1
L1--> RouterB(config)#username RouterA password 0 ciscoisdn
L2--> RouterB(config)#int bri0/0
L3--> RouterB(config-if)#dialer pool-member 1
L4--> RouterB(config-if)#int dialer1
L5--> RouterB(config-if)#dialer pool 1
L6--> RouterB(config)#ip route 10.10.68.1 255.255.255.255 dialer1
Q1. Is L6 routing correctly ?
Site C:
Loopback0 - 10.10.23.1
E0/0 - 10.10.24.1
L2--> RouterC(config)#int bri0/0
L3--> RouterC(config-if)#dialer pool-member 1
L4--> RouterC(config-if)#int dialer1
L5--> RouterC(config-if)#dialer pool 1
L6--> RouterC(config)#ip route 10.10.68.1 255.255.255.255 dialer1
Q1.Is L6 routing correctly ?
Please help out.
11-06-2002 08:07 AM
I assume, your bri interfaces, are using ip unnumbered command, utilising the ip address of the loopback interface on the BRI interface.
On all routers, there should be a default route, pointing to the BRI interface or the dialer interface.
For example on Site C
ip route 0.0.0.0 0.0.0.0 dialer 1
ip route 10.10.68.1 255.255.255.255 dialer 1
This should help!
11-06-2002 08:50 AM
First of all, you likely don't need to use Dialer Profiles at the remotes; it's more complex than is necessary. So a remote config like this would be fine:
int Loopback0
ip address 10.10.23.1 255.255.255.0
int Bri0/0
ip unn loop 0
encap ppp
dialer map ip 10.10.68.1 name RouterA 1234
dialer-group 1
ppp multlink
ppp authen chap callin
dialer load threshold X
dialer-list 1 .........
ip route 0.0.0.0 0.0.0.0 bri 0/0 10.10.68.1
As for RouterA, same thing; you don't need Dialer Profiles really. You could have a config like this:
int Loopback0
ip addr 10.10.68.1 255.255.255.0
int Bri0/0
no ip address
dialer rotary 1
int Bri0/1
no ip address
dialer rotary 1
int dialer1
ip unn loop 0
encap ppp
ppp multilink
dialer-group 1
dialer-list 1 .....
ip route 10.10.24.0 255.255.255.0 10.10.23.1
ip route 10.10.19.0 255.255.255.0 10.10.18.1
See if that helps simplify things.
11-06-2002 05:03 PM
Hi, for your "dialer rotary 1" in the RouterA config, what does it mean ?
Under what circumstances that I need to have "dialer profile" and what circumstances I don't need it ?
Please help out.
Thank out.
11-07-2002 09:16 AM
Dialer profile is user specific..means every user have a specific dialer interface where you can use the different settings like, pap/chap, idle-timeout, authentication methods etc..
While Rotary-groups are more lagacy DDR..where all the users share the same config under one interface..
Pl. visit following urls for more
11-07-2002 04:23 PM
Thank you very much on your guide.
Thank you.
11-08-2002 01:58 PM
When you have multiple interfaces that will be receiving or placing the same calls, then it's easiest (from the configuration perspective) to configure a rotary group, and assign each of the physical interfaces to the rotary-group - thus they will inherit the config of the rotary-group interface. This is what "dialer rotary 1" does, it associates the physical interface with "Dialer 1".
Dialer Profiles are really only needed when you have per-user requirements; ie, the users which are dialing in or to which you are dialing out to have unique interface configuration parameters. That does not look to be the case for you.
11-26-2002 01:59 AM
Hi Sir, I had tried on the config you suggested above with "ISDN switch-type basic-net3", but from my RouterB and RouterC, when I ping to RouterA loopback address, they called to RouterA but failed.
Over RouterB and RouterC, I used commands;
sh isdn act - show nothing
sh isdn status - Layer 2 - Active
sh isdn his - out 7188223 Failed
Please help out.
11-26-2002 09:20 AM
we need to see the following debug for a callout
debug isdn q931
debug ppp negotiation
debug ppp authentication
11-26-2002 09:46 AM
You need to have a look at the following to figure out what is wrong:
debug isdn q931
debug dialer
debug ppp neg
11-06-2002 09:44 AM
The config looks good at this point..always it needs a whole config to verify the connectivity..All the questions answers to "YES"..Pl. visit following url for more config and troubleshooting tips
http://www.cisco.com/warp/public/793/access_dial/ddr_dialer_profile.html
