ISDN IP Routing !!!
I have three sites; Sites A, B & C. Sites B and C both have the a Cisco 1720 with a BRI port (one 128K ISDN link attached) will respectively dial to Site A which has a 2620 router with two BRI ports as required.
Site A:
Loopback0 - 10.10.68.1
E0/0 - 10.10.69.1
Bri0/0 - no ip address
Bri0/1 - no ip address
L1--> RouterA(config)#username RouterB password 0 ciscoisdn
L2--> RouterA(config)#username RouterC password 0 ciscoisdn
L3--> RouterA(config)#int bri0/0
L4--> RouterA(config-if)#dialer pool-member 1
L5--> RouterA(config-if)#int dialer1
L6--> RouterA(config-if)#dialer pool 1
L7--> RouterA(config)#int bri0/1
L8--> RouterA(config-if)#dialer pool-member 2
L9--> RouterA(config-if)#int dialer2
L10--> RouterA(config-if)#dialer pool 2
L11--> RouterA(config)#ip route 10.10.18.1 255.255.255.255 dialer1
L12--> RouterA(config)#ip route 10.10.23.1 255.255.255.255 dialer2
Q1. Are L1 & L2 necessary for RouterB and RouterC to dial in (Using PPP authentication) ?
Q2. Are L11 & L12 routing correctly ?
Site B:
Loopback0 - 10.10.18.1
E0/0 - 10.10.19.1
L1--> RouterB(config)#username RouterA password 0 ciscoisdn
L2--> RouterB(config)#int bri0/0
L3--> RouterB(config-if)#dialer pool-member 1
L4--> RouterB(config-if)#int dialer1
L5--> RouterB(config-if)#dialer pool 1
L6--> RouterB(config)#ip route 10.10.68.1 255.255.255.255 dialer1
Q1. Is L6 routing correctly ?
Site C:
Loopback0 - 10.10.23.1
E0/0 - 10.10.24.1
L2--> RouterC(config)#int bri0/0
L3--> RouterC(config-if)#dialer pool-member 1
L4--> RouterC(config-if)#int dialer1
L5--> RouterC(config-if)#dialer pool 1
L6--> RouterC(config)#ip route 10.10.68.1 255.255.255.255 dialer1
Q1.Is L6 routing correctly ?
Please help out.
1 REPLY
Re: ISDN IP Routing !!!
You don't need to use dialer profile for that config at site B &C..It can get complicated..Config looks fine though..
Here is the url which discuss similar kind of scenerio..
http://www.cisco.com/warp/public/793/access_dial/ddr_dialer_profile.html
Also you can use dialer maps too.
http://www.cisco.com/warp/public/129/config-bri-map.html
78
