Community Member
ISDN Issue
who can help me to solve the isdn issue that the router cannot construct the isdn call well? the related debug infor is follow:
4w0d: ISDN Se2/0:15: event CALL_PROGRESS dsl 0
4w0d: ISDN Se2/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x3196, bchan 9, dsl0
4w0d: ISDN Se2/0:15: RX <- DISCONNECT pd = 8 callref = 0x0011
4w0d: Cause i = 0x8090 - Normal call clearing
4w0d: Progress Ind i = 0x8088 - In-band info or appropriate now availab
4w0d: ISDN Se2/0:15: LIF_EVENT: ces/callid 1/0x3194 CALL_DISC
4w0d: ISDN Se2/0:15: TX -> RELEASE pd = 8 callref = 0x8011
4w0d: ISDN Se2/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x0011
4w0d: ISDN Se2/0:15: CCPRI_ReleaseCall(): bchan 8, call id 0x3194, call type VOE
4w0d: CCPRI_ReleaseChan released b_dsl 0 B_Chan 8
4w0d: ISDN Se2/0:15: LIF_EVENT: ces/callid 1/0x3194 CALL_CLEARED
4w0d: ISDN Se2/0:15: received CALL_CLEARED call_id 0x3194
4w0d: ISDN Se2/0:15: Outgoing call id = 0x83CF, dsl 0
4w0d: ISDN Se2/0:15: process_pri_call(): call id 0x83CF, number 01066114433, spE
4w0d: building outgoing channel id for call nfas_int is 0 len is 0
4w0d: ISDN Se2/0:15: TX -> SETUP pd = 8 callref = 0x03CF
4w0d: Bearer Capability i = 0x8090A3
4w0d: Channel ID i = 0xA9839F
4w0d: Calling Party Number i = 0x80, '02895519', Plan:Unknown, Type:Unkn
4w0d: Called Party Number i = 0x80, '01066114433', Plan:Unknown, Type:Un
4w0d: ISDN Se2/0:15: RX <- CALL_PROC pd = 8 callref = 0x83CF
4w0d: Progress Ind i = 0x8288 - In-band info or appropriate now availab
4w0d: ISDN Se2/0:15: LIF_EVENT: ces/callid 1/0x83CF CALL_PROCEEDING
4w0d: ISDN Se2/0:15: PRI Event: 6, bchan = 30, call type = VOICE
4w0d: (Se2/0:15) TX call proc to appl thru CDAPI,call_id (0x83CF)
4w0d: ISDN Se2/0:15: RX <- DISCONNECT pd = 8 callref = 0x83CF
4w0d: Cause i = 0x8295 - Call rejected
4w0d: ISDN Se2/0:15: LIF_EVENT: ces/callid 1/0x83CF CALL_DISC
4w0d: ISDN Se2/0:15: TX -> RELEASE pd = 8 callref = 0x03CF
4w0d: ISDN Se2/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x83CF
4w0d: ISDN Se2/0:15: CCPRI_ReleaseCall(): bchan 31, call id 0x83CF, call type VE
4w0d: CCPRI_ReleaseChan released b_dsl 0 B_Chan 31
4w0d: ISDN Se2/0:15: LIF_EVENT: ces/callid 1/0x83CF CALL_CLEARED
4w0d: ISDN Se2/0:15: received CALL_CLEARED call_id 0x83CF
4w0d: ISDN Se2/0:15: process_disconnect(): call id 0x3195, call type is VOICE, )
4w0d: ISDN Se2/0:15: TX -> DISCONNECT pd = 8 callref = 0x800E
4w0d: ISDN Se2/0:15: RX <- RELEASE pd = 8 callref = 0x000E
4w0d: ISDN Se2/0:15: CCPRI_ReleaseCall(): bchan 9, call id 0x3195, call type VOE
4w0d: CCPRI_ReleaseChan released b_dsl 0 B_Chan 9
4w0d: ISDN Se2/0:15: LIF_EVENT: ces/callid 1/0x3195 CALL_CLEARED
4w0d: ISDN Se2/0:15: received CALL_CLEARED call_id 0x3195
4w0d: ISDN Se2/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x800E
callcenter_CD#
4w0d: ISDN Se2/0:15: RX <- SETUP pd = 8 callref = 0x0007
who can help me to explain the debug infor and give me a right advice to solve the problem? Thanks
Sincerely
1 REPLY
Silver
Re: ISDN Issue
Is this a data or voice call ? It looks like the switch is only provisioned for one of these settings , call the carrier and have them check the switch to ensure it is configured for the type of call you are palcing , either voice or data or both .
113
