07-05-2002 01:56 AM - edited 03-04-2019 02:47 AM
Hi There,
Is it possible to connect and configure isdn bri leased line on serial interface. The router is cisco 2600 with wic-2t? Do I have to have isdn bri card in cisco 2600?
Suneel jain
07-06-2002 08:17 PM
You cannot connect an ISDN line directly to a serial interface but it can be used to connect to an ISDN terminal adapter which terminates the ISDN line but is is far more common to use a BRI interface in the router.
07-09-2002 10:03 PM
Thanks Rona, I am convinced that I need to buy isdn wic card. But due to curiosity I have another question.
Using TA can I still use this line as ISDN leased line?
Suneel jain
07-16-2002 01:03 AM
Suneel,
Using an ISDN port I am sure you can get this working. But saying that I have a problem at the moment. Using the isdn leased-line BRI 0 128, I get an error message. I have done a search on the CCO web site for the error and it says after a reboot 64K line works properly. I was of the opinion that both channels are used (128K)
Isaac
09-02-2002 11:57 PM
Have you ever tried the "dialer load-threshold"-command ??
09-03-2002 03:37 AM
Sorry, wrong section !!
09-02-2002 01:56 AM
Suneel,
It is not possible to connect a BRI to a serial interface (Different Interfaces). You definitely need a BRI card. I got this working with a Cisco 800 funny enough as I never could get it working with a 2600 even with an IOS 12.2(8) and above.
Isaac
