ISDN link continuosly up/down when being used for Frame Relay Backup
Why does router continuosly bring up/down the ISDN Circuits for BRI3/0 and BRI3/1?
PLYMQR03#show run
Building configuration...
Current configuration : 15254 bytes
! Last configuration change at 10:21:14 cdt Mon Feb 3 2003
version 12.1
service config
no service single-slot-reload-enable
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname PLYMQR03
logging buffered 64000 debugging
logging console critical
no logging monitor
enable secret 5 $1$9ehQ$UDaoASBC7LxaAZfKfFaiA/
enable password 7 09585C0C1C
username STNMQR02 password 7 046B273F1C3542671A3D0B
username AUBMQR01 password 7 052A132D2C7D71103810261126
username PLYMQSJT password 7 097F643D
username OWAMQR02 password 7 013C11254F585F5A2A49591A
username OWAMQR01 password 7 096359280D564E4700091339
username LOUAAFR2 password 7 0820420F584956383D18
clock timezone cdt 0
ip subnet-zero
no ip source-route
ip name-server 206.28.162.24
ip name-server 206.28.162.1
appletalk routing
ipx routing 00e0.1e88.bd61
isdn switch-type basic-ni
isdn voice-call-failure 0
controller T1 2/1
framing esf
clock source line primary
linecode b8zs
channel-group 0 timeslots 1-14 speed 64
tdm-group 1 timeslots 15-24
controller T1 2/2
framing esf
linecode b8zs
tdm-group 2 timeslots 15-24
buffers small permanent 300
buffers small max-free 1000
buffers middle permanent 180
buffers big permanent 275
buffers big max-free 750
buffers large permanent 60
buffers large max-free 50
buffers large min-free 10
stun peer-name 205.239.5.8
stun protocol-group 10 sdlc
stun protocol-group 11 sdlc
stun protocol-group 12 sdlc
interface Ethernet0/0
description * PLY LAN
ip address 205.239.7.10 255.255.255.0 secondary
ip address 205.239.5.8 255.255.255.0 secondary
ip address 172.16.1.10 255.255.0.0
ip helper-address 205.239.7.100
ip helper-address 172.16.1.58
ip directed-broadcast
full-duplex
ntp broadcast client
appletalk cable-range 668-668 668.53
appletalk discovery
ipx network D0000677 encapsulation SAP
ipx output-gns-filter 1000
no cdp enable
no mop enabled
hold-queue 500 in
interface Serial0/0
description * P2P T1 to Faribault
ip address 205.239.4.209 255.255.255.252
encapsulation ppp
ipx network D9999992
no cdp enable
interface Serial0/1
description * Faribault Telex 1174-15R
mtu 4400
no ip address
encapsulation stun
shutdown
clockrate 72000
stun group 12
stun sdlc-role secondary
sdlc address 40
stun route address 40 tcp 172.20.1.1 local-ack
hold-queue 150 in
interface Ethernet1/0
ip address 63.77.163.185 255.255.255.248
shutdown
ipx network B0000002 encapsulation SAP
no cdp enable
interface Serial1/0
description * Motorola FT100M - MCI frame-relay T1
no ip address
encapsulation frame-relay IETF
ntp broadcast
frame-relay lmi-type ansi
hold-queue 120 in
interface Serial1/0.3 point-to-point
description * Scottsboro, AL - Primary PVC 192K CIR
bandwidth 1536
ip address 205.239.4.205 255.255.255.252
delay 1500
shutdown
ntp broadcast
ipx network D8999997
no cdp enable
frame-relay interface-dlci 67
interface Serial1/0.4 point-to-point
description * Louisville, KY PVC 384K CIR new
ip address 172.26.6.41 255.255.255.252
ipx network A8999999
no cdp enable
frame-relay interface-dlci 97
interface Serial1/0.5 point-to-point
description * Louisville, KY PVC 32K CIR
ip address 205.239.4.49 255.255.255.252
shutdown
no cdp enable
frame-relay interface-dlci 70
interface Serial1/0.6 point-to-point
description * Staunton, VA backup PVC 0 CIR
bandwidth 384
ip address 205.239.4.201 255.255.255.252
ipx network D8999995
ipx type-20-propagation
no cdp enable
frame-relay interface-dlci 66
interface Serial1/0.8 point-to-point
description * UUNET Internet Connection for MOL
ip unnumbered Ethernet1/0
ip access-group 105 in
shutdown
no cdp enable
frame-relay interface-dlci 17 IETF
interface Serial1/0.10 point-to-point
description * Auburn, NY - Primary PVC 384K CIR
bandwidth 1536
ip address 192.168.253.21 255.255.255.252
delay 100
appletalk cable-range 670-670 670.5
appletalk zone Plymouth-Auburn
ipx delay 10
ipx network D8999989
no ipx sap-incremental eigrp 2
no cdp enable
frame-relay interface-dlci 102
interface Serial1/1
mtu 4400
no ip address
encapsulation stun
shutdown
interface Ethernet2/0
no ip address
ip access-group 102 in
ip access-group 103 out
shutdown
no cdp enable
interface Serial2/0
description * Auburn, NY Telex 1174-15R
mtu 4400
no ip address
encapsulation stun
shutdown
clockrate 148000
stun group 10
sdlc address 40
stun route address 40 tcp 172.17.1.1 local-ack
hold-queue 150 in
interface Serial2/1:0
description * Owatonna P2P Circuit
ip address 192.168.253.33 255.255.255.252
encapsulation ppp
ipx network D9999993
no cdp enable
interface BRI3/0
description * Auburn ISDN Backup
ip address 192.168.253.17 255.255.255.252
encapsulation ppp
no ip mroute-cache
dialer map ip 192.168.253.18 name AUBMQR01 13152533955
dialer map ip 192.168.253.18 name AUBMQR01 13152535334
dialer hold-queue 100
dialer load-threshold 1 outbound
dialer-group 2
appletalk cable-range 672-672 672.52
appletalk zone Plymouth-Auburn-ISDN
ipx network DB999999
isdn spid1 61251988341111
isdn spid2 61251988351111
no fair-queue
compress predictor
no cdp enable
ppp authentication chap
ppp multilink
interface BRI3/1
description * Staunton, VA ISDN Backup
ip address 205.239.4.213 255.255.255.252
encapsulation ppp
no ip mroute-cache
dialer map ip 205.239.4.214 name STNMQR02 15408851590
dialer map ip 205.239.4.214 name STNMQR02 15408851591
dialer-group 2
ipx network DB999995
isdn spid1 61251986271111
isdn spid2 61251986261111
no fair-queue
compress predictor
no cdp enable
ppp multilink
interface BRI3/2
description * Stewart Thompson's Home Office
ip address 192.168.253.29 255.255.255.252
encapsulation ppp
no ip mroute-cache
keepalive 32767
dialer idle-timeout 3600
dialer map ip 192.168.253.30 name PLYMQSJT broadcast
dialer-group 1
ipx network DB888888
isdn spid1 76369490281111 6949028
isdn spid2 76369492221111 6949222
no fair-queue
compress stac
no cdp enable
ppp authentication chap callin
ppp multilink
interface BRI3/3
description * Louisville ISDN Backup
ip address 172.26.6.53 255.255.255.252
encapsulation ppp
no ip mroute-cache
dialer map ip 172.26.6.54 name LOUAAFR2 15023269598
dialer map ip 172.26.6.54 name LOUAAFR2 15023940561
dialer-group 2
isdn spid1 76355704651111 5570465
isdn spid2 76355704661111 5570466
no fair-queue
compress predictor
no cdp enable
ppp multilink
interface BRI3/4
no ip address
shutdown
no cdp enable
interface BRI3/5
no ip address
shutdown
no cdp enable
interface BRI3/6
no ip address
shutdown
no cdp enable
interface BRI3/7
no ip address
shutdown
no cdp enable
router eigrp 1
redistribute static
passive-interface BRI3/0
passive-interface BRI3/1
network 63.0.0.0
network 166.49.0.0
network 172.16.0.0
network 172.26.0.0
network 192.168.253.0
network 192.168.254.0
network 205.239.4.0
network 205.239.5.0
network 205.239.7.0
network 208.168.42.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
ip forward-protocol udp 799
ip forward-protocol udp 800
ip forward-protocol udp 801
ip forward-protocol udp 8002
ip route 0.0.0.0 0.0.0.0 205.239.5.1
ip route 10.1.1.0 255.255.255.0 172.16.1.12
ip route 172.17.0.0 255.255.0.0 192.168.253.18 180
ip route 172.18.0.0 255.255.0.0 205.239.4.214 160
ip route 172.20.0.0 255.255.0.0 205.239.4.206 200
ip route 172.21.0.0 255.255.0.0 192.168.253.34 80
ip route 172.21.0.0 255.255.0.0 205.239.4.210 200
ip route 172.25.0.0 255.255.0.0 172.26.6.54 100
ip route 172.25.6.54 255.255.255.255 BRI3/3
ip route 192.168.29.0 255.255.255.0 192.168.253.34
ip route 192.168.51.0 255.255.255.0 172.26.6.42
ip route 192.168.252.32 255.255.255.240 192.168.253.30
ip route 192.168.252.48 255.255.255.240 192.168.253.30
ip route 192.168.253.18 255.255.255.255 BRI3/0
ip route 192.168.253.30 255.255.255.255 192.168.253.30
ip route 198.85.41.96 255.255.255.240 205.239.4.214 160
ip route 205.239.4.148 255.255.255.252 205.239.4.214 160
ip route 205.239.4.214 255.255.255.255 BRI3/1
ip route 205.239.8.0 255.255.255.0 192.168.253.18 180
ip route 205.239.9.0 255.255.255.0 205.239.4.214 160
ip route 207.169.178.0 255.255.255.0 205.239.4.214 160
no ip http server
logging trap debugging
logging source-interface Ethernet0/0
logging 172.16.1.58
logging 172.16.2.245
access-list 2 permit 205.239.7.6
access-list 2 permit 205.239.7.8
access-list 2 permit 205.239.7.27
access-list 6 deny 205.239.7.102
access-list 6 deny 205.239.7.105
access-list 6 permit any
access-list 99 permit 172.25.0.4
access-list 99 permit 10.10.10.254
access-list 99 permit 205.239.5.0 0.0.0.255
access-list 99 permit 205.239.7.0 0.0.0.255
access-list 99 permit 205.239.8.0 0.0.0.255
access-list 99 permit 172.16.0.0 0.0.255.255
access-list 99 permit 205.239.6.192 0.0.0.31
access-list 99 permit 192.168.27.0 0.0.0.255
access-list 100 deny ip any host 255.255.255.255
access-list 100 deny eigrp any host 255.255.255.255
access-list 100 deny icmp host 205.239.7.6 any
access-list 100 deny icmp host 205.239.7.27 any
access-list 100 deny ip 207.37.131.0 0.0.0.255 any
access-list 100 deny ip 207.169.177.0 0.0.0.255 any
access-list 100 deny ip any 207.37.131.0 0.0.0.255
access-list 100 deny ip any 207.169.177.0 0.0.0.255
access-list 100 permit ip any any log
access-list 100 permit eigrp any any log
access-list 100 permit icmp any host 205.239.4.214
access-list 101 deny udp any any eq snmp
access-list 101 permit tcp any host 208.168.42.2 eq telnet
access-list 101 permit tcp any host 208.168.42.2 eq domain
access-list 101 permit udp any host 208.168.42.2 eq domain
access-list 101 permit udp host 205.239.7.106 host 208.168.42.2 eq netbios-ns
access-list 101 permit icmp any host 208.168.42.2 echo
access-list 101 permit udp any host 208.168.42.2 eq 1428
access-list 101 permit udp any host 208.168.42.2 gt 1023
access-list 101 permit tcp any host 208.168.42.2 eq smtp
access-list 101 permit ip host 161.44.20.64 any
access-list 101 permit tcp any host 205.239.7.106 eq smtp
access-list 102 deny ip any host 255.255.255.255
access-list 102 deny eigrp any host 255.255.255.255
access-list 102 deny icmp host 205.239.7.6 any
access-list 102 deny icmp host 205.239.7.27 any
access-list 102 deny icmp host 205.239.5.66 any
access-list 102 deny ip 207.37.131.0 0.0.0.255 any
access-list 102 deny ip 207.169.177.0 0.0.0.255 any
access-list 102 deny ip any 207.37.131.0 0.0.0.255
access-list 102 deny ip any 207.169.177.0 0.0.0.255
access-list 102 deny ip any 224.0.0.0 0.0.0.255
access-list 102 permit ip any any log
access-list 102 permit eigrp any any log
access-list 102 permit icmp any host 192.168.253.18
access-list 104 permit tcp any any established
access-list 104 permit tcp any any eq smtp
access-list 104 permit udp any any eq domain
access-list 104 permit tcp any any eq domain
access-list 104 permit tcp any any eq telnet
access-list 104 permit icmp any any
access-list 104 permit udp host 205.239.7.106 host 208.168.42.2 eq netbios-ns
access-list 104 permit udp any any eq netbios-ns
access-list 104 permit udp any any eq 1428
access-list 104 permit udp any any gt 1023
access-list 105 permit ip host 161.44.20.93 any
access-list 105 deny udp any any eq snmp
access-list 105 permit ip any host 63.77.163.186
access-list 105 permit ip host 172.25.0.4 host 63.77.163.185
access-list 105 permit icmp any any echo
access-list 105 permit icmp any any echo-reply
access-list 160 permit ip any host 205.239.4.214
access-list 160 permit ip host 205.239.4.214 any
access-list 900 deny any any all any sap
access-list 900 deny any any all any rip
access-list 900 deny any any all any 457
access-list 900 permit any
access-list 1000 deny ABF0269C.00a0.2451.a137
access-list 1000 deny ABF0269C.00a0.241a.631c
access-list 1000 deny ABF0269C.0080.c82d.6a32
access-list 1000 deny ABF0269C.0800.09a6.4afb
access-list 1000 deny ABF0269C.0060.08a9.4fed
access-list 1000 deny ABF0269C.0000.e818.49d8
access-list 1000 deny ABF0269C.00a0.24e4.ef2c
access-list 1000 deny ABF0269C.0060.08ae.c8f1
access-list 1000 deny ABF0269C.00c0.4f6f.10fd
access-list 1000 permit FFFFFFFF
queue-list 4 protocol stun 1
queue-list 4 protocol ip 2
queue-list 4 protocol ipx 3
queue-list 4 default 4
queue-list 4 queue 1 byte-count 8800
priority-list 1 protocol ip high tcp 1994
priority-list 1 protocol ip low tcp ftp
priority-list 1 protocol ip low tcp ftp-data
priority-list 5 protocol ip low tcp ftp-data
priority-list 5 protocol ip high tcp telnet
priority-list 5 protocol stun medium
priority-list 5 protocol ip medium udp snmp
priority-list 5 protocol ip high tcp login
priority-list 5 protocol ip high tcp 2000
priority-list 5 protocol ip high tcp 6000
priority-list 5 protocol ip high udp 6000
priority-list 5 protocol ip high udp 2000
priority-list 5 protocol ip high tcp 8510
priority-list 5 protocol ip high tcp 8000
priority-list 5 protocol ip high tcp 8025
priority-list 5 protocol ip high tcp 8075
priority-list 5 protocol ip high tcp 8080
priority-list 5 protocol ip high tcp 8085
priority-list 5 protocol ip high tcp 8500
priority-list 5 protocol ip high tcp 8525
priority-list 5 protocol ip high tcp 8575
priority-list 5 protocol ip high tcp 8590
priority-list 5 protocol ip high tcp 9026
priority-list 5 protocol ip high tcp 9001
priority-list 5 protocol ip high tcp 9010
priority-list 5 protocol ip high tcp 9041
priority-list 5 protocol ip high tcp 9033
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip list 102
connect tdm1 T1 2/1 1 T1 2/2 2
no cdp run
snmp-server engineID local 00000009020000E01E88BD61
snmp-server community PLYMQR03_snmp RW 2
snmp-server community mcq_ERP_PROD_get view v1default RO
snmp-server community public view v1default RO
snmp-server community mcq_ERP_DEV_get view v1default RO
snmp-server community aaf_snmp RO 99
snmp-server packetsize 8192
snmp-server host 205.239.7.8 mcq_ERP_DEV_get
snmp-server host 205.239.7.6 mcq_ERP_PROD_get
snmp-server host 205.239.7.27 public
ipx router eigrp 2
network D0000677
network D9999992
network D8999995
network D8999997
network B0000002
network DB999995
network D8999989
network DB888888
network D9999993
banner motd ^CCC
For Use By Authorized Personnel Only
Unauthorized Use Will Be Subject To Prosecution
^C
line con 0
exec-timeout 0 0
password 7 105A1B1C00
login
line aux 0
modem InOut
transport input all
speed 38400
flowcontrol hardware
line vty 0 4
session-timeout 60
access-class 99 in
exec-timeout 30 0
password 7 1403000E09
login
ntp clock-period 17179573
ntp server 205.239.5.1
end
Re: ISDN link continuosly up/down when being used for Frame Rela
Please post the output of the: debug dialer command
PLYMQR03#show log
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
Console logging: level critical, 0 messages logged
Monitor logging: disabled
Buffer logging: level debugging, 5156 messages logged
Trap logging: level debugging, 5160 message lines logged
Logging to 172.16.1.58, 5160 message lines logged
Logging to 172.16.2.245, 5160 message lines logged
Log Buffer (64000 bytes):
Feb 4 14:45:56: %LINK-3-UPDOWN: Interface BRI3/1:1, changed state to down
Feb 4 14:45:56: %LINK-3-UPDOWN: Interface BRI3/1:2, changed state to down
Feb 4 14:45:57: %LINK-3-UPDOWN: Interface BRI3/1, changed state to up
Feb 4 14:45:57: %ISDN-6-LAYER2UP: Layer 2 for Interface BR3/1, TEI 71 changed t
o up
Feb 4 14:45:58: %SYS-5-CONFIG_I: Configured from console by vty0 (172.25.0.4)
Feb 4 14:45:58: %ISDN-6-LAYER2UP: Layer 2 for Interface BR3/1, TEI 72 changed t
o up
Feb 4 14:45:59: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI3/1, TEI 72 change
d to down
Feb 4 14:45:59: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR3/1, TEI 72 changed
to down
Feb 4 14:46:03: %ISDN-6-LAYER2UP: Layer 2 for Interface BR3/1, TEI 72 changed t
o up
Feb 4 14:46:06: %LINK-3-UPDOWN: Interface BRI3/1:1, changed state to up
Feb 4 14:46:07: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
Feb 4 14:46:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/1:1, chang
ed state to up
Feb 4 14:46:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2
Feb 4 14:46:12: %ISDN-6-CONNECT: Interface BRI3/1:1 is now connected to 1540885
1590 STNMQR02
Feb 4 14:46:41: %LINK-3-UPDOWN: Interface BRI3/1:2, changed state to up
Feb 4 14:46:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/1:2, chang
ed state to up
Feb 4 14:46:47: %ISDN-6-CONNECT: Interface BRI3/1:2 is now connected to 1540885
1590 STNMQR02
Feb 4 14:47:11: %LINK-3-UPDOWN: Interface BRI3/1:1, changed state to down
Feb 4 14:47:11: %LINK-3-UPDOWN: Interface BRI3/1:2, changed state to down
Feb 4 14:47:11: %LINK-5-CHANGED: Interface BRI3/1, changed state to administrat
ively down
Feb 4 14:47:11: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to dow
n
Feb 4 14:47:11: %ISDN-6-DISCONNECT: Interface BRI3/1:1 disconnected from unkno
wn , call lasted 65 seconds
Feb 4 14:47:11: %ISDN-6-DISCONNECT: Interface BRI3/1:2 disconnected from unkno
wn , call lasted 29 seconds
Feb 4 14:47:11: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI3/1, TEI 71 change
d to down
Feb 4 14:47:11: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI3/1, TEI 72 change
d to down
Feb 4 14:47:11: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR3/1, TEI 71 changed
to down
Feb 4 14:47:11: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR3/1, TEI 72 changed
to down
Feb 4 14:47:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/1:1, chang
ed state to down
Feb 4 14:47:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/1:2, chang
ed state to down
Feb 4 14:47:12: %SYS-5-CONFIG_I: Configured from console by vty0 (172.25.0.4)
Feb 4 14:47:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2
Feb 4 16:09:05: %LINK-3-UPDOWN: Interface BRI3/2:1, changed state to up
Feb 4 16:09:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/2:1, chang
ed state to up
Feb 4 16:09:11: %ISDN-6-CONNECT: Interface BRI3/2:1 is now connected to 7634281
367 PLYMQSJT
Feb 4 16:24:34: %ISDN-6-DISCONNECT: Interface BRI3/2:1 disconnected from 76342
81367 PLYMQSJT, call lasted 928 seconds
Feb 4 16:24:34: %LINK-3-UPDOWN: Interface BRI3/2:1, changed state to down
Feb 4 16:24:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/2:1, chang
ed state to down
Feb 4 16:40:55: %LINK-3-UPDOWN: Interface BRI3/2:1, changed state to up
Feb 4 16:40:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/2:1, chang
ed state to up
Feb 4 16:41:01: %ISDN-6-CONNECT: Interface BRI3/2:1 is now connected to 7634281
367 PLYMQSJT
Feb 4 19:55:05: %ISDN-6-DISCONNECT: Interface BRI3/2:1 disconnected from 76342
81367 PLYMQSJT, call lasted 11650 seconds
Feb 4 19:55:05: %LINK-3-UPDOWN: Interface BRI3/2:1, changed state to down
Feb 4 19:55:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/2:1, chang
ed state to down
Feb 4 20:53:54: %LINK-3-UPDOWN: Interface BRI3/2:1, changed state to up
Feb 4 20:53:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI3/2:1, chang
ed state to up
Feb 4 20:54:00: %ISDN-6-CONNECT: Interface BRI3/2:1 is now connected to 7634281
367 PLYMQSJT
PLYMQR03# clear logging
Clear logging buffer [confirm]
PLYMQR03#show log
PLYMQR03#debug dialer
PLYMQR03#debug dialer ?
events Dial on demand events
map Dynamic dialer maps
packets Dial on demand traffic
PLYMQR03#debug dialer events
Dial on demand events debugging is on
PLYMQR03#debug dialer map
Dial on demand dynamic dialer maps debugging is on
PLYMQR03#debug dialer packets
Dial on demand packets debugging is on
PLYMQR03#config t
Enter configuration commands, one per line. End with CNTL/Z.
PLYMQR03(config)#int bri3/0
PLYMQR03(config-if)#no shut
PLYMQR03(config-if)#^Z
PLYMQR03#wri mem
[OK]
PLYMQR03#show debug
Dial on demand:
PLYMQR03#show log
Buffer logging: level debugging, 5315 messages logged
Trap logging: level debugging, 5319 message lines logged
Logging to 172.16.1.58, 5319 message lines logged
Logging to 172.16.2.245, 5319 message lines logged
Feb 5 07:35:18: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
outgoing interesting (ip PERMIT)
Feb 5 07:35:18: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:18: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
going uninteresting (list 102)
Feb 5 07:35:19: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 51 bytes,
Feb 5 07:35:19: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:19: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 51 bytes, out
Feb 5 07:35:19: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
.ffff), 432 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:19: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
.ffff), 256 bytes, outgoing uninteresting (no list matched)
.ffff), 96 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:20: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
.ffff), 70 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:20: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:20: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:20: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:20: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:22: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:22: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:22: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:23: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:23: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:23: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:25: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:25: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:25: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:25: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:25: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:26: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:26: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:26: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:27: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:27: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:27: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:28: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:28: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:29: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:29: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:29: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:30: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:30: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:31: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:31: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:31: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:31: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:35:31: BR3/0:1 DDR: disconnecting call
Feb 5 07:35:31: %LINK-3-UPDOWN: Interface BRI3/0:2, changed state to down
Feb 5 07:35:31: BR3/0:2 DDR: disconnecting call
Feb 5 07:35:31: %LINK-3-UPDOWN: Interface BRI3/0, changed state to up
Feb 5 07:35:31: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
.ffff), 40 bytes, outgoing uninteresting (no list matched)
.ffff), 88 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:31: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:31: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:31: %ISDN-6-LAYER2UP: Layer 2 for Interface BR3/0, TEI 68 changed t
o up
Feb 5 07:35:32: %SYS-5-CONFIG_I: Configured from console by vty0 (172.25.0.4)
Feb 5 07:35:32: %ISDN-4-INVALID_SPID: Interface BR3/0, Spid1 was rejected
Feb 5 07:35:34: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:34: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:34: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:35: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:35: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:35: BR3/0 DDR: ip (s=192.168.253.17, d=255.255.255.255), 49 bytes,
outgoing uninteresting (list 102)
Feb 5 07:35:35: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:35: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:38: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:39: BR3/0 DDR: ip (s=192.168.253.17, d=255.255.255.255), 49 bytes,
Feb 5 07:35:39: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:39: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:39: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:39: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:39: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:39: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:43: BR3/0 DDR: ip (s=192.168.253.17, d=255.255.255.255), 49 bytes,
Feb 5 07:35:43: BR3/2 DDR: ip (s=192.168.253.29, d=255.255.255.255), 49 bytes,
Feb 5 07:35:43: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:43: BR3/3 DDR: ip (s=172.26.6.53, d=255.255.255.255), 49 bytes, out
Feb 5 07:35:43: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:43: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:43: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:44: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:44: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:45: BR3/0 DDR: appletalk (s=672.52, d=0.255), 40 bytes, outgoing un
Feb 5 07:35:46: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
.ffff), 34 bytes, outgoing uninteresting (no list matched)
.ffff), 264 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:47: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:48: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:48: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:48: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
.ffff), 480 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:49: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:35:49: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:49: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:50: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:35:51: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
.ffff), 288 bytes, outgoing uninteresting (no list matched)
Feb 5 07:35:51: %ISDN-4-INVALID_SPID: Interface BR3/0, Spid1 was rejected
Feb 5 07:35:52: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:53: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:53: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:53: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:53: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:35:55: BR3/0 DDR: appletalk (s=672.52, d=0.255), 40 bytes, outgoing un
Feb 5 07:35:56: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:35:58: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:35:58: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:35:58: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:35:58: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:00: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:00: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:01: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:01: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:01: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:02: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:02: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:02: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:02: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:03: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:03: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:04: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:04: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:05: BR3/0 DDR: appletalk (s=672.52, d=0.255), 40 bytes, outgoing un
Feb 5 07:36:06: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:07: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:07: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:07: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:07: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:11: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:11: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:11: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:12: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:12: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:15: BR3/0 DDR: appletalk (s=672.52, d=0.255), 40 bytes, outgoing un
Feb 5 07:36:15: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:16: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:16: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:17: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:17: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:18: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:18: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:20: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:20: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:20: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:22: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:22: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:25: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:25: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:25: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:25: BR3/0 DDR: appletalk (s=672.52, d=0.255), 40 bytes, outgoing un
Feb 5 07:36:26: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:36:26: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:36:26: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:36:26: BR3/0:1 DDR: disconnecting call
Feb 5 07:36:26: %ISDN-6-LAYER2UP: Layer 2 for Interface BR3/0, TEI 69 changed t
o up
Feb 5 07:36:26: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:26: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:27: %ISDN-4-INVALID_SPID: Interface BR3/0, Spid2 was rejected
Feb 5 07:36:28: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:36:28: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:36:28: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:36:28: BR3/0:1 DDR: disconnecting call
Feb 5 07:36:29: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:29: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:29: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:31: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:31: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:32: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:36:32: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:32: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:34: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:34: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:34: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:34: BR3/0 DDR: ip (s=172.16.1.51, d=192.168.253.18), 112 bytes, out
going interesting (list 102)
Feb 5 07:36:34: BR3/0 DDR: Dialing cause ip (s=172.16.1.51, d=192.168.253.18)
Feb 5 07:36:34: BR3/0 DDR: Attempting to dial 13152533955
Feb 5 07:36:34: DDR: Packet queued
Feb 5 07:36:36: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:36: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:37: %AT-6-ONLYROUTER: BRI3/0: AppleTalk interface enabled; no neigh
bors found
Feb 5 07:36:38: BR3/0 DDR: appletalk (s=672.52, d=0.255), 69 bytes, outgoing un
Feb 5 07:36:38: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:38: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:39: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:39: BR3/0 DDR: appletalk (s=672.52, d=0.255), 69 bytes, outgoing un
Feb 5 07:36:40: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:40: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:40: BR3/0 DDR: appletalk (s=672.52, d=0.255), 69 bytes, outgoing un
Feb 5 07:36:41: BR3/0 DDR: appletalk (s=672.52, d=0.255), 69 bytes, outgoing un
Feb 5 07:36:42: BR3/0 DDR: appletalk (s=672.52, d=0.255), 69 bytes, outgoing un
Feb 5 07:36:43: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:36:43: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:43: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:44: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:45: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:45: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:46: %ISDN-4-INVALID_SPID: Interface BR3/0, Spid2 was rejected
Feb 5 07:36:46: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:36:48: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:48: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:48: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:36:49: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:36:49: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:50: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:36:50: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:50: BR3/2 DDR: sending broadcast to ip 192.168.253.30
3955
o up
3955
bors found
Feb 5 07:36:51: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:36:51: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:51: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:52: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:52: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:53: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:36:53: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:55: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:55: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:36:57: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:36:57: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:36:58: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:36:59: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:36:59: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:00: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:00: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:01: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:01: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:02: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:02: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:03: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:03: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:03: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:37:03: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
.ffff), 352 bytes, outgoing uninteresting (no list matched)
Feb 5 07:37:04: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:04: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:04: BRI3/0: wait for isdn carrier timeout, call id=0x8487
Feb 5 07:37:04: BR3/0 DDR: Attempting to dial 13152535334
Feb 5 07:37:06: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:06: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:07: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:08: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:08: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:11: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:11: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:12: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:13: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:37:13: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:13: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:15: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:15: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:17: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:18: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:18: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:18: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:18: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:20: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:20: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:21: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:22: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:22: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:22: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
.ffff), 160 bytes, outgoing uninteresting (no list matched)
Feb 5 07:37:22: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:22: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:23: %SEC-6-IPACCESSLOGDP: list 102 permitted icmp 172.16.1.51 -> 19
2.168.253.18 (0/0), 1 packet
Feb 5 07:37:23: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:37:25: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:25: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:26: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:26: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:37:26: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:37:26: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:37:26: BR3/0:1 DDR: disconnecting call
Feb 5 07:37:26: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:26: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:29: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:37:29: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:37:29: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:37:29: BR3/0:1 DDR: disconnecting call
Feb 5 07:37:29: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:29: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:30: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:31: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:31: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:33: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:37:34: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:34: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:34: BRI3/0: wait for isdn carrier timeout, call id=0x8488
Feb 5 07:37:34: DDR: Dialing failed, 1 packets unqueued and discarded
Feb 5 07:37:34: BR3/0 DDR: ip (s=172.16.1.51, d=192.168.253.18), 112 bytes, out
Feb 5 07:37:34: BR3/0 DDR: Dialing cause ip (s=172.16.1.51, d=192.168.253.18)
Feb 5 07:37:34: BR3/0 DDR: Attempting to dial 13152533955
Feb 5 07:37:34: DDR: Packet queued
Feb 5 07:37:35: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:36: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:36: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:39: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:39: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:40: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:40: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:40: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:43: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:37:43: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:43: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:44: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:45: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:45: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:46: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:37:46: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:46: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:48: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:37:48: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:48: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:49: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:37:49: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:50: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:37:50: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:50: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:51: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
.ffff), 416 bytes, outgoing uninteresting (no list matched)
Feb 5 07:37:53: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:53: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:53: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:37:54: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:54: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:54: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:37:57: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:37:57: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:37:58: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:37:59: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:37:59: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:00: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:00: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:01: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:01: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:02: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:02: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:03: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:03: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:03: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:03: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:38:03: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:03: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:04: BRI3/0: wait for isdn carrier timeout, call id=0x8489
Feb 5 07:38:04: BR3/0 DDR: Attempting to dial 13152535334
Feb 5 07:38:06: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:06: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:07: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:08: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:08: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:11: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:38:11: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:11: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:12: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:12: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:12: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:13: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:38:15: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:15: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:16: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:17: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:17: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:18: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:18: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:20: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:20: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:21: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:21: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:21: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:23: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:38:24: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:24: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:26: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:26: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:26: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:26: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:38:26: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:38:26: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:38:26: BR3/0:1 DDR: disconnecting call
Feb 5 07:38:29: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:38:29: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:38:29: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:38:29: BR3/0:1 DDR: disconnecting call
Feb 5 07:38:29: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:29: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:30: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:30: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:31: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:33: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:38:33: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:33: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:34: BRI3/0: wait for isdn carrier timeout, call id=0x848A
Feb 5 07:38:34: DDR: Dialing failed, 1 packets unqueued and discarded
Feb 5 07:38:35: BR3/0 DDR: ip (s=172.16.1.51, d=192.168.253.18), 112 bytes, out
Feb 5 07:38:35: BR3/0 DDR: Dialing cause ip (s=172.16.1.51, d=192.168.253.18)
Feb 5 07:38:35: BR3/0 DDR: Attempting to dial 13152533955
Feb 5 07:38:35: DDR: Packet queued
Feb 5 07:38:35: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:35: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:35: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:38: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:38: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:40: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:40: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:40: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:43: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:38:43: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:43: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:44: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:45: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:45: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:46: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:38:47: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:47: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:47: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:38:48: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:38:49: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:38:49: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:50: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:50: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:50: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:38:52: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:52: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:53: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:38:54: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:54: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:54: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:56: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:56: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:38:59: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:38:59: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:38:59: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:38:59: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:38:59: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:00: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:00: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:01: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:01: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:02: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:02: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:03: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:03: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:03: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:39:03: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:03: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:03: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:05: BRI3/0: wait for isdn carrier timeout, call id=0x848B
Feb 5 07:39:05: BR3/0 DDR: Attempting to dial 13152535334
Feb 5 07:39:05: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:05: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:07: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:08: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:08: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:10: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:10: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:12: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:12: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:12: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:13: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:39:15: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:15: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:17: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:17: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:17: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:17: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:17: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:19: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:19: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:21: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:21: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:22: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:23: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:39:24: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:24: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:26: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:26: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:26: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:27: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:39:27: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:39:27: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:39:27: BR3/0:1 DDR: disconnecting call
Feb 5 07:39:29: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:29: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:29: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to up
Feb 5 07:39:29: %ISDN-6-CONNECT: Interface BRI3/0:1 is now connected to 1315253
3955
Feb 5 07:39:29: %LINK-3-UPDOWN: Interface BRI3/0:1, changed state to down
Feb 5 07:39:29: BR3/0:1 DDR: disconnecting call
Feb 5 07:39:31: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:31: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:31: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:33: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:39:33: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:33: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:35: BRI3/0: wait for isdn carrier timeout, call id=0x848C
Feb 5 07:39:35: DDR: Dialing failed, 1 packets unqueued and discarded
Feb 5 07:39:35: BR3/0 DDR: ip (s=172.16.1.51, d=192.168.253.18), 112 bytes, out
Feb 5 07:39:35: BR3/0 DDR: Dialing cause ip (s=172.16.1.51, d=192.168.253.18)
Feb 5 07:39:35: BR3/0 DDR: Attempting to dial 13152533955
Feb 5 07:39:35: DDR: Packet queued
Feb 5 07:39:35: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:35: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:36: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:38: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:38: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:40: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:40: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:40: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:43: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:39:43: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:43: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:45: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:45: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:45: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:45: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:39:47: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:47: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:47: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:39:48: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:39:49: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:39:49: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:50: BR3/0 DDR: ipx (s=DB999999.00e0.1e88.bd61, d=DB999999.ffff.ffff
Feb 5 07:39:50: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:50: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:51: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:51: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:53: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:39:54: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:54: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:54: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:56: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:56: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:39:58: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
Feb 5 07:39:59: BR3/2 DDR: ip (s=192.168.253.29, d=224.0.0.10), 60 bytes, outgo
Feb 5 07:39:59: BR3/2 DDR: sending broadcast to ip 192.168.253.30
Feb 5 07:39:59: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:39:59: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:40:00: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:40:00: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:40:01: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:40:01: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:40:02: BR3/2 DDR: ipx (s=DB888888.00e0.1e88.bd61, d=DB888888.ffff.ffff
Feb 5 07:40:02: BR3/2 DDR: sending broadcast to ipx DB888888.0040.f917.40a4
Feb 5 07:40:03: BR3/0 DDR: appletalk (s=672.52, d=0.255), 35 bytes, outgoing un
Feb 5 07:40:03: BR3/3 DDR: ip (s=172.26.6.53, d=224.0.0.10), 60 bytes, outgoing
PLYMQR03# no debug all
All possible debugging has been turned off
PLYMQR03#config t
PLYMQR03(config-if)#shut
PLYMQR03#wri mem
Building configuration...
[OK]
It looks as if the problem is on the remote side. There are no outgoing calls on BRI3/0 or 3/1. Probably the remote routers are causing this. In other words: you are dialed into instead of dialling out.
We might have to check the remote configs as well, but with a debug dialer you can quickly trace which system is causing the calls.
Leo
Silver
Nothing obvious wrong with the configuration (but I did not look that closely). The trace requested will show whether or not "interesting traffic" is adequately defined.
In the meantime, I do have three other suggestions for you:
1 - Change your username / passwords NOW!!! you have just posted a list of ISDN numbers, login names, and passwords (type 7 scrambling is trivially reversed, do a google search on cisco password decryption to find several applets that anyone can use to decode the passwords you posted).
2 - Add the line "no ip route-cache" to the BRI interfaces. Many Cisco IOS releases have problems with fast switching of dial inks (this may or may not be the case with your IOS release).
3 - Consider using dialer profiles rather than assigning each user a specific interface. This will make life easier for you in the future when a line goes down and you need to support that usage before the line can be restored.
Good luck and have fun!
VIncent C Jones
www.networkingunlimited.com
Bronze
One of the messages in your log indicates that your SPIDs are invalid on BRI3/0. Verify your SPIDs.
Good Luck.
Mark
124
