ISDN max-link statement and Multilink ppp
I have recently added the below max-link statements and it appears that when an e1 pri dials the below PRIs that not more than 17 channels will connect. I also noticed that I only have Multilink ppp on the second interface. If I add Multilink PPP command on the first will it help? I also thought that, maybe the solution would be to remove the maxlink statements and add min-link statements on the other dialer pools that are common to both PRIs.
interface Serial3/0:23
description Sample Co. ISDN PRI (xxx)xxx-xx00
bandwidth 64
no ip address
encapsulation ppp
no ip route-cache
dialer pool-member 1 max-link 17
dialer pool-member 2 max-link 17
dialer pool-member 9 max-link 6
isdn switch-type primary-dms100
ppp authentication chap
interface Serial3/1:23
description Sample Co. ISDN PRI (xxx) xxx-x000
no ip address
encapsulation ppp
dialer pool-member 10
dialer pool-member 11
dialer pool-member 12
dialer pool-member 1 max-link 13
dialer pool-member 2 max-link 13
no fair-queue
ppp multilink
1 REPLY
Anonymous
N/A
Re: ISDN max-link statement and Multilink ppp
Yes you need to have multilink interface on the 1st T1 too.
If the call is incoming, the number dialed for your site would be xxxxxxxx00 and the
T1 would pick up the call with the right dialer interface using the right pool that has
been pre-configured.
The pool 1 for example is used and you'll not have more that 17 channel in the bundle.
Because the call is incoming from an E1 which requires a bunble of 30 channles, you side would
only be able to use the 17 in the max-link alone. If you need the other T1's pool 1 with
max-link 13 to be added to make 30 b-channels which can accomaodate the E1. You'll need the
remote E1 router configured to use two numbers i.e
dialer-string xxxxxxxx00
dialer string xxxxxxx000
This would cause the two local T1 to be used to accomdate the bandwidht demand of the
remote E1.
115
