ISDN Not coming up
mshamjee
Dear Friends.
I m enclosing the log files. The ISDN is not coming up.I have checked the ISDN the line is not having any probs. But if i reset the port the ISDN is coming up for 1 minute or so. kindly give me the suggestion for it
dialer map ip 10.253.150.213 name bclsurat broadcast 02613229873
dialer-group 2
isdn switch-type basic-net3
interface BRI1/3
demo#ping 10.253.150.213
Sending 5, 100-byte ICMP Echos to 10.253.150.213, timeout is 2 seconds:
Success rate is 0 percent (0/5)
demo#
demo#
demo#
demo#wr
Building configuration...
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![OK]
demo#sh run
Current configuration : 1990 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname demo
enable secret 5 $1$j58Y$0ZlK4OWwtBPJ/MtPp5ETt.
enable password airtel
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
interface Tunnel0
ip address 10.10.100.29 255.255.255.252
tunnel source BRI1/0
tunnel destination 202.56.253.182
interface Ethernet0/0
ip address 10.80.2.12 255.255.255.0
no ip mroute-cache
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
interface Ethernet0/1
no ip address
no ip mroute-cache
shutdown
interface Serial0/1
no ip address
no ip mroute-cache
shutdown
interface BRI1/0
no ip address
encapsulation ppp
dialer idle-timeout 658230
dialer string 6405352
dialer-group 2
ppp authentication chap
ppp pap sent-username testahm password 7 0835495D1D180D1A
interface BRI1/1
ip address negotiated
dialer-group 1
interface BRI1/2
ip address 10.253.150.214 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer idle-timeout 300
dialer-group 2
interface BRI1/3
no ip address
no ip mroute-cache
shutdown
interface BRI1/4
no ip address
no ip mroute-cache
interface BRI1/5
no ip address
no ip mroute-cache
shutdown
interface BRI1/6
no ip address
no ip mroute-cache
shutdown
interface BRI1/7
no ip address
no ip mroute-cache
shutdown
ip classless
ip route 10.201.24.0 255.255.255.0 Tunnel0
ip route 192.0.0.0 255.0.0.0 10.80.2.1
ip route 192.168.1.0 255.255.255.0 Tunnel0
no ip http server
demo#debug isdn eve
demo#debug isdn events
ISDN events debugging is on
00:21:32: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:21:34: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:21:36: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:21:38: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:21:40: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
demo#conf t
Enter configuration commands, one per line. End with CNTL/Z.
demo(config)#int bri1/2
demo(config-if)#shut
demo(config-if)#
00:22:29: ISDN BR1/2 EVENT: State = 6, Old State = 4
00:22:29: %LINK-5-CHANGED: Interface BRI1/2, changed state to administratively d
own
00:22:29: ISDN BR1/2 EVENT: State = 6, Old State = 4no
00:22:29: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to down
00:22:29: %LINK-3-UPDOWN: Interface BRI1/2:2, changed state to downshut
00:22:30: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/2, changed state
to down
demo(config-if)#
00:22:32: ISDN BR1/2 EVENT: State = 0, Old State = 6
00:22:32: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to down
00:22:32: %LINK-3-UPDOWN: Interface BRI1/2:2, changed state to down
00:22:32: ISDN BR1/2 EVENT: State = 4, Old State = 6
00:22:32: %LINK-3-UPDOWN: Interface BRI1/2, changed state to up
00:22:32: ISDN BR1/2: L1 is IF_ACTIVE
00:22:32: ISDN BR1/2 EVENT: State = 4, Old State = 4
00:22:32: ISDN BR1/2: Incoming call id = 0x0005, dsl 10
00:22:137438953472: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/2, TEI 96 change
d to up
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo(config-if)#^Z
00:22:40: %SYS-5-CONFIG_I: Configured fromsh run
version 12.1
hostname demo
ip subnet-zero
no ip domain-lookup
interface Tunnel0
--More--
00:22:180388626432: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/2, TEI 96 chan
ged to down
00:22:188978561023: ISDN BR1/2: Incoming call id = 0x0006, dsl 10
00:22:186840552325: ISDN BR1/2: received HOST_INCOMING_CALL call_id 0x6
00:22:184683593728: ISDN BR1/2: HOST_INCOMING_CALL: (non-POTS) DATA
00:22:184683593728: ISDN BR1/2: HOST_INCOMING_CALL: (1) call_type = DATA
00:22:184683593728: ISDN BR1/2: HOST_INCOMING_CALL: voice_answer_data = FALSE ca
ll type is DATA
00:22:184683594411: ISDN BR1/2: RM returned call_type 0 resource type 0 response
00:22:43: ISDN BR1/2: isdn_send_connect(): msg 4, call id 0x6, ces 1 bchan 0, ca
ll type DATA
00:22:43: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to up
00:22:188978561024: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/2, TEI 96 change
d to up
00:22:188978561024: ISDN BR1/2: received HOST_CONNECT call_id 0x6
00:22:188978561024: ISDN BR1/2: Event: Connected o
demo#wn> on B1 at 64 Kb/s
00:22:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/2:1, changed stat
e to up
00:22:208317550516: ISDN BR1/2: received HOST_DISCONNECT call_id 0x6
00:22:206158430208: ISDN BR1/2: Event: Call to <unknown> was hung up.
00:22:208317550388: ISDN BR1/2: process_disc_ack(): call id 0x6, ces 1, call typ
e DATA
00:22:207017750578: %ISDN-6-DISCONNECT: Interface BRI1/2:1 disconnected from un
known , call lasted 4 seconds
00:22:208315397932: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to down
00:22:208315388805: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x6
00:22:206158430208: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
00:22:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/2:1, changed stat
e to down
demo#
demo#
demo#
demo#conf t
00:22:231928233984: ISDN BR1/2: Incoming call id = 0x0007, dsl 10
00:22:234087354292: ISDN BR1/2: received HOST_INCOMING_CALL call_id 0x7
00:22:231928233984: ISDN BR1/2: HOST_INCOMING_CALL: (non-POTS) DATA
00:22:231928233984: ISDN BR1/2: HOST_INCOMING_CALL: (1) call_type = DATA
00:22:231928233984: ISDN BR1/2: HOST_INCOMING_CALL: voice_answer_data = FALSE ca
ll type is DATA
00:22:231928234667: ISDN BR1/2: RM returned call_type 0 resource type 0 response
00:22:54: ISDN BR1/2: isdn_send_connect(): msg 4, call id 0x7, ces 1 bchan 0, ca
ll type DATA
00:22:54: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to up
00:22:231928233984: ISDN BR1/2: received HOST_CONNECT call_id 0x7
00:22:231928233984: ISDN BR1/2: Event: Connected to <unknown> on B1 at 64 Kb/s
demo(config)#
demo(config)#
demo(config)#
demo(config)#
demo(config)#
00:22:251267223476: ISDN BR1/2: received HOST_DISCONNECT call_id 0x7
00:22:249108103168: ISDN BR1/2: Event: Call to <unknown> was hung up.
00:22:251267223348: ISDN BR1/2: process_disc_ack(): call id 0x7, ces 1, call typ
e DATA
00:22:249950188850: %ISDN-6-DISCONNECT: Interface BRI1/2:1 disconnected from un
00:22:251265070892: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to down
00:22:251265061765: ISDN BR1/2: received HOST_DISCONNECT_ACK call_id 0x7
00:22:249108103168: ISDN BR1/2: HOST_DISCONNECT_ACK: call type is DATA
demo(config)#
demo(config)#
demo(config)#
demo(config)#
demo(config)#
demo(config)#^Z
demo#
demo#
demo#
demo#s d
00:23:03: %SYS-5-CONFIG_I: Configured from console by consoleialer
BRI1/0 - dialer type = ISDN
Dial String Successes Failures Last DNIS Last status
6405352 0 4 00:21:58 failed Default
0 incoming call(s) have been screened.
0 incoming call(s) rejected for callback.
BRI1/0:1 - dialer type = ISDN
Idle timer (658230 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is idle
BRI1/0:2 - dialer type = ISDN
BRI1/1 - dialer type = ISDN
--More--
00:23:34359738368: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/2, TEI 96 chang
e n
BRI1/1:1 - dialer type = ISDN
Idle timer (120 secs), Fast idle timer (20 secs)
BRI1/1:2 - dialer type = ISDN
BRI1/2 - dialer type = ISDN
02613229873 0 0 never -
BRI1/2:1 - dialer type = ISDN
Idle timer (300 secs), Fast idle timer (20 secs)
BRI1/2:2 - dialer type = ISDN
BRI1/3 - dialer type = ISDN
BRI1/3:1 - dialer type = ISDN
Dialer state is shutdown
demo#s dialer
6405352 0 4 00:22:08 failed Default
--More--
00:23:21: ISDN BR1/2 EVENT: State = 4, Old State = 4
00:23:21: ISDN BR1/2 EVENT: State = 0, Old State = 4
00:23:21: ISDN BR1/2: Physical layer is IF_DOWN
00:23:91117060095: ISDN BR1/2: Shutting down ME
00:23:90194313216: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI1/2, TEI 96 chan
ged to down
00:23:90194313216: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/2, TEI 96 chang
ed to down
00:23:94489280511: ISDN BR1/2: Shutting down ISDN Layer 3
00:23:92353401284: L3: L3_GetUser_NLCB failed, message ignored cid 0x0 cr 0x0 ev
0x211 ceBRI1/2:1 - dialer type = ISDN
BRI1/3:2 - dialer type = ISDN
00:23:32: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:23:34: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:23:36: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:23:38: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
00:23:40: ISDN BRI1/2: isdn_is_bchannel_available: No Free B-channels.
demo#conf t
demo(config-if)#
00:23:49: ISDN BR1/2 EVENT: State = 6, Old State = 4
00:23:49: %LINK-5-CHANGED: Interface BRI1/2, changed state to administratively d
own
00:23:49: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to down
00:23:49: %LINK-3-UPDOWN: Interface BRI1/2:2, changed state to down
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo(config-if)#no shut
demo(config-if)#
00:23:53: ISDN BR1/2 EVENT: State = 0, Old State = 6
00:23:53: %LINK-3-UPDOWN: Interface BRI1/2:1, changed state to down
00:23:53: %LINK-3-UPDOWN: Interface BRI1/2:2, changed state to down
00:23:53: ISDN BR1/2 EVENT: State = 4, Old State = 6
00:23:53: %LINK-3-UPDOWN: Interface BRI1/2, changed state to up^Z
demo#
00:23:54: ISDN BR1/2: L1 is IF_ACTIVE
00:23:54: ISDN BR1/2 EVENT: State = 4, Old State = 4
00:23:54: ISDN BR1/2: Incoming call id = 0x0008, dsl 10
00:23:234087329924: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/2, TEI 65 change
d to up
00:23:54: %SYS-5-CONFIG_I: Configured from console by console
demo#
demo#
demo#
demo#sh isdn
00:24:17179869184: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/2, TEI 65 chang
ed to down st
Global ISDN Switchtype = basic-net3
ISDN BRI1/0 interface
dsl 8, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 9
ISDN BRI1/1 interface
dsl 9, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 9 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 0
ISDN BRI1/2 interface
dsl 10, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 65, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
I_Queue_Len 0, UI_Queue_Len 0
Layer 3 Status:
Active dsl 10 CCBs = 0
The Free Channel Mask: 0x3
Number of L2 Discards = 0, L2 Session ID = 10
ISDN BRI1/3 interface
dsl 11, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 11 CCBs = 0
ISDN BRI1/4 interface
dsl 12, interface ISDN Switchtype = basic-net3
Layer 1 Status:
demo#
dialer-group 2
interface BRI1/3
demo#
demo#
demo#
demo#wr
demo#sh run
version 12.1
hostname demo
ip subnet-zero
no ip domain-lookup
interface Tunnel0
no ip mroute-cache
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
no ip address
no ip mroute-cache
shutdown
interface Serial0/1
no ip address
no ip mroute-cache
shutdown
interface BRI1/0
no ip address
encapsulation ppp
dialer-group 2
interface BRI1/1
dialer-group 1
interface BRI1/2
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer-group 2
interface BRI1/3
no ip address
no ip mroute-cache
shutdown
interface BRI1/4
no ip address
no ip mroute-cache
interface BRI1/5
no ip address
no ip mroute-cache
shutdown
interface BRI1/6
no ip address
no ip mroute-cache
shutdown
interface BRI1/7
no ip address
no ip mroute-cache
shutdown
ip classless
no ip http server
demo#debug isdn eve
demo#conf t
demo(config-if)#
own
to down
demo(config-if)#
d to up
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo(config-if)#^Z
version 12.1
hostname demo
ip subnet-zero
no ip domain-lookup
interface Tunnel0
--More--
ged to down
ll type is DATA
ll type DATA
d to up
e to up
e DATA
e to down
demo#
demo#
demo#
demo#conf t
ll type is DATA
ll type DATA
demo(config)#
demo(config)#
demo(config)#
demo(config)#
demo(config)#
e DATA
demo(config)#
demo(config)#
demo(config)#
demo(config)#
demo(config)#
demo(config)#^Z
demo#
demo#
demo#
demo#s d
--More--
e n
demo#s dialer
--More--
ged to down
ed to down
demo#conf t
demo(config-if)#
own
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo(config-if)#
demo#
d to up
demo#
demo#
demo#
demo#sh isdn
ed to down st
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Layer 1 Status:
demo#
demo#
demo#s ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(10a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 04-Feb-02 09:47 by kellythw
Image text-base: 0x80008088, data-base: 0x80816698
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
demo uptime is 23 minutes
System image file is "flash:c2600-i-mz.121-10a.bin"
cisco 2611 (MPC860) processor (revision 0x00) with 24576K/8192K bytes of memory.
Processor board ID JAD061008FJ (154101789)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
8 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
regards
Manish Shamjee
siljugpillai
Hi Manish,
This has to do with ISDN Layer 3. Give the command "debug isdn q931" and check the cause for disconnection from the link "cause i = 0x ". Then go to the following link and check the disconnection cause.
http://www.cisco.com/warp/public/471/isdn_q931_ts.html
Most of the times the problem will be at exchange end. They usually do the test using ISDN phone. But this doesnt mean that the data is through. They have to do some settings on the ISDN switch to enable data.
Hope this will help
regards
