ISDN PPP Multilink dialer load threshold
hallo
I have a main office with a cisco 2600 router connected to BRI interfaces.
Remote offices use cisco761 router to connect to main office cisco 2600.
The main office router must only respond to remote calls.
I need bandwidth on demand so when the load on a B channel passes a threshold a second B channel will be used.
* This is part of the cisco2600 config
interface BRI1/0
description 'connected to Bassano -Set'
no ip address
no ip directed-broadcast
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn send-alerting
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer1
description 'connected to Bassano'
ip address 192.168.101.1 255.255.255.0
encapsulation ppp
dialer remote-name bassano761
dialer pool 1
dialer idle-timeout 300
dialer hold-queue 20
dialer-group 10
no cdp enable
ppp multilink
bandwidth ?
dialer load-threshold ?
dialer load-interval 30
* This is part of the cisco761 config for a remote office :set user altavilla2621
set system bassano761
set switch net3
cd
set number 10770444276132
set timeout 500
set encapsulation ppp
set compression stac
set ppp secret host
eurocoop
eurocoop
set ip routing on
set ip rip update off
set bridging off
set ip address 192.168.101.2
set ip netmask 255.255.255.0
set ip route destination 192.168.0.0/24 gateway 192.168.101.1 propagate on
set ip route destination 10.0.0.0/24 gateway 192.168.101.1
cd
cd
set ppp multilink on
set multidestination on
demand 1 threshold=0 duration=1 source=lan
demand 2 threshold=48 duration=1 source=both
timeout 1 threshold=0 duration=500 source=lan
timeout 2 threshold=48 duration=300 source=both
WHICH ARE THE VALUES FOR THE FOLLOWING PARAMETERS IF I WHANT THAT THE SECOND B CHANNEL GOES UP WHEN THE FIRST REACHES 60Kbps ?
bandwidth ?
demand 2 threshold= ? duration=1 source=both
timeout 2 threshold= ? duration=300 source=both
THANKs
Silver
Re: ISDN PPP Multilink dialer load threshold
For 60% load, your threshold should be set to 255 * 0.6 = 1531. I dont think you need to set bandwidth as well.
Thanks.
You need to enter following command if you want the first link loaded to (threshold=60) 60kbps for continuously 300 secs (duration=300) before 2nd b channel will be dialed.
demand 2 threshold=60 duration=300 source=both
Here is the link which explains how to use that command and what are thoes parameters means.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/750/700cr44/700crisd.htm#xtocid102068
Ok for the cisco760 but for cisco2600 dialer interface what are the values for:
- bandwidth
- dialer load-threshold
Can I use "bandwidth 128" and "dialer load-threshold 120" (60*255/128) ?
217
